The OFFICIAL "I have a wheel offset / tire fitment question!" thread
Old May 2, 2016 | 09:55 PM
  #1411
Originally Posted by WhtaBeautXs
Hey all,
I'm having tire issues with my set up. Since my car is awd the light keeps flashing. I'm running a staggered set up 20x9 and 20x10.5. The tire sizes are 225/35 and 255/35. The best solution would be to get a 225/40 in the front but they don't make a tire that size.
What are my options other than taking the staggered wheels off?
Yeah, your combo is over 3% different diameter front to back. Do NOT drive your car anymore until you get this taken care of. Might have to rent a car for a couple days but will be cheaper than replacing your AWD setup.
You could keep your front tires and run a 265/30/20 in back (0.23% variance), a 255/30 in back will be 0.68% off, or get all new tires if you have room at the fender (which it looks pretty tight) a 235/35 front 275/30 rear will get you to 0.07% difference.
You need to have that variance under 1%, and well under 1% is much better!
Old May 2, 2016 | 10:12 PM
  #1412
SurreyG's Avatar
SurreyG
I would take Brad's advice on this one. This is the only reason I decided to stay clear of staggered setup on a AWD G setup, I'm sure it's been done successfully multiple times, but I worry about if the tires begin to wear that it will again knock the AWD sensors into blinking mode.
Old May 3, 2016 | 09:08 AM
  #1413
Black_G's Avatar
Black_G
looking for some insight on what wheel size to run.
I know I want to end up with the Niche Sport M130 Targa wheels. I'm just not sure on what size will fit.
These are going on a 2008 G37 coupe with a stock ride height.
I want these in a 20" rim but will a 20 x 10 fit front and back? If they will fit in the front but not the back, what size could I fit up front? I'm OK with running a staggered setup, concave does not have to match front to back either.
http://www.wheelfire.com/scontent/Wh...-700&SKU=18804
Old May 3, 2016 | 10:08 AM
  #1414
VenomGT9's Avatar
VenomGT9
They will fit front and back but choose an offset in the 30s for the front and lower in the rear or find a 9.5 front/10.5 rear
Old May 3, 2016 | 11:32 AM
  #1415
Black_G's Avatar
Black_G
Any suggestions on where to order the,? That wheelfire.com site looks like total **** and is not easy to navigate IMO
Old May 3, 2016 | 11:58 AM
  #1416
VenomGT9's Avatar
VenomGT9
If you're set on 20s, I recommend going with a different brand wheel...Niche is rather cheap and not good quality. Yes, others run them fine and some never have issues, but not worth the risk.
An easy upgrade and getting super affordable would be a set of GTR stocks...CBAs can be had under 1k and DBAs just a little over.
Wheels & Tires - GT-R Life
TONS of folks selling their stocks on here for stupid cheap, made by Rays and forged which means quality and even lighter than Niche.
Old May 3, 2016 | 12:37 PM
  #1417
Black_G's Avatar
Black_G
Thanks, I appreciate that input and I'll look into them before I buy anything. I probably won't pull the trigger on something until August or September
This car isn't going to be about performance, its really just about looks. Its my wife's car and she is about to get something new so this will be what she takes to the car shows with me.
On the front i was going to get a 20x8.5 and on the back 20 x 10.5. What offsets would you recommend?
Old May 3, 2016 | 02:10 PM
  #1418
VenomGT9's Avatar
VenomGT9
Try to find a 9.5 up front offset in the 30s, 10.5 rear you can get away with upper 20s in offset
Old May 16, 2016 | 10:05 AM
  #1419
WhtaBeautXs's Avatar
WhtaBeautXs
Thanks for the help bro!! Much appreciated as I got all 4 new tires. I ran the 235/35 front and 275/30 rear. No rub due to the suspension set up I have. Looks better as well. I'll post pics as soon as I give it an altitude adjustment lol.
Old May 16, 2016 | 02:14 PM
  #1420
MADDSLOW's Avatar
MADDSLOW
I'm looking to purchase a 2014 AWD Q60S, and I currently have 20x9 +30 TSW Sochi rims on my 2010 G37x coupe. Will I have brake clearance issues with the larger brakes?
Old May 16, 2016 | 02:35 PM
  #1421
VenomGT9's Avatar
VenomGT9
No issues but are you intending to run square setup on RWD or changing the tire sizes?
Old May 16, 2016 | 05:10 PM
  #1422
Since you have the wheels on hand you can use these templates to confirm fit
https://www.myg37.com/forums/brakes-...templates.html
Old May 18, 2016 | 01:47 PM
  #1423
Drewdrool's Avatar
Drewdrool
Hi there, I'm looking to getting a set of wheels from Vordoven for my 08 G37 coupe Journey. Specs I'm looking at is 19x9.5 +22 in the front and 19x10.5 +12 in the rear. But is it possible to run 19x9.5 +22 all around? And what tire sizes would I need to use so that I wouldn't be rubbing. Im on stock 18's and stock height right now but will be purchasing coilovers once I order wheels.
Old May 18, 2016 | 01:51 PM
  #1424
VenomGT9's Avatar
VenomGT9
Why do you want a square set up?
Old May 18, 2016 | 01:55 PM
  #1425
Drewdrool's Avatar
Drewdrool
They're actually out of stock on the 10.5 size, so I was playing with the idea of running a squared set up..lol
