The OFFICIAL "I have a wheel offset / tire fitment question!" thread
Old Dec 12, 2014 | 11:31 PM
  #481
Originally Posted by Buckeye43017
Found a real nice set of rims off a G35 coupe for my G37xS Sedan.
They are:
20x8.5 (35 offset) with 245/35/20 tires front
20x10 ((40 offset) with 275/30/20 tires rear
Also, my sedan is on the stock suspension.
Trying to find info on here about the brake clearance and fit, as well as the diameter for the all wheel drive, but cant find on here....
Opinions??
The best size for those wheels & AWD would be 235/35/20F 275/30/20 R
this will give you a front to rear variance of only 0.07% or virtually zero, can't do any better than that w/ a staggered fit. The 245/275 combo will be at -0.97% which is under 1% but having the rear tire smaller will result in even more variance as time goes on since the rears wear faster. If you like the rims I'd run them as is but when the time comes for new tires I'd go w/ the 235/275 combo.
That set will fit and clear your floating calipers. If you upgrade to a big brake kit later they might not clear as a lot of bigger wheels don't clear due to design, backspacing, etc.
Here's a template you can use to check big brake clearance if you plan on getting Akebonos later
http://infinitig37.com/tech-images/akebonotemplate.pdf
And here's a handy calculator to check different tire/wheel setups
FWIW big 20" wheels tend to look a bit "off" on vehicles at stock height, the fender gap combined w/ the big diameter rims/thin sidewalls detracts a bit compared to a dropped G w/ big wheels.
Old Dec 20, 2014 | 03:57 PM
  #482
OBG37S's Avatar
OBG37S
Nice wheels, shoot some pics our way when you get them on
Wheels arrived! Super happy with how they look! There was rubbing in the rear, but that was fixed by trimming a portion of the fender liner and a portion of the rear bumper bracket.
**Thanks for the help blnewt!!! Pics uploaded correctly
Old Dec 20, 2014 | 08:20 PM
  #483
**Had issues uploading pics. If anybody can help with this, I'll edit the post. For now see link below for pics (10 total):
https://www.flickr.com/photos/130160...5/15878519370/
Those look great
Try hosting on Photo and image hosting, free photo galleries, photo editing and then paste to your thread.
Old Dec 21, 2014 | 09:39 PM
  #484
RJ's_G37's Avatar
RJ's_G37
Recently picked up some coupe wheels. the tires are all 245/40/19. im dropped on swifts and my g37 is a journey. just wanted to make sure im good to go on them fitting or do i need to take any extra steps.. Thanks
Old Dec 21, 2014 | 10:21 PM
  #485
No issues whatsoever
Old Dec 22, 2014 | 12:41 AM
  #486
RJ's_G37's Avatar
RJ's_G37
Great thanks im gonna get them balanced but should i gey yhe alignment or can i wait on that?
Old Dec 22, 2014 | 08:14 AM
  #487
Unless you've lowered your G or jarred a pothole or something else that may have tweaked your alignment you won't need to get one. I would get an alignment every few years though as it never hurts (as long as the shop is competent, lol).
Old Dec 24, 2014 | 10:44 AM
  #488
RedlineAZ's Avatar
RedlineAZ
Hey guys, 08 G37s lowered on eibach springs, found a set of wheels with the specs below:
19x8.5 +15 / 19x10 +20
Looking for a slight poke front and rear, or very flush. What do you guys think? Also, what tire size?
Not looking for fender mods, or running any weird camber besides the natural camber, I just want to slap em on and go Thanks!
Old Dec 24, 2014 | 04:20 PM
  #489
If you want to run stretched tires those will work, the rims will be outside the fender but the stretched tires will tuck inside the fender edge. I'm not one to recommend going stretched as it exposes the rim to curb rash and may be hard to claim tire warranties if you have a failure, but that's just my 2cs. Tire sizes like 225 front 245 rear would be about right.
Old Dec 24, 2014 | 06:28 PM
  #490
RedlineAZ's Avatar
RedlineAZ
Do you think the wheel will poke too much? Any pics I can use as a reference? I tried to search for one but maybe my search skills aren't as great
Old Dec 24, 2014 | 07:03 PM
  #491
Here's a thread w/ 8.5 +17s on 245s and 10.5 +35 on 265s (the rears will net a +29 if they were 10" wide)
https://www.myg37.com/forums/wheels-...19x10-5-a.html
You might want to post your specs on this thread too, the guys in that thread are well versed in very aggressive offsets w/ stretched tire sets
https://www.myg37.com/forums/wheels-...sh-thread.html
Old Dec 24, 2014 | 07:58 PM
  #492
RedlineAZ's Avatar
RedlineAZ
Thanks man I will! I appreciate the references
Old Dec 29, 2014 | 09:45 PM
  #493
Umaro03's Avatar
Umaro03
I am on 2010 sport OEM wheels. I believe these are the spec.
Front:
Wheels: 19"x8.5". Cast aluminum. Made for Nissan/Infiniti by Enkei. Weight: 26.5 lbs. Bolt pattern 114.3 x 5 Offset +43
Rear:
Wheels: 19"x9". Cast aluminum. Made for Nissan/Infiniti byEnkei. Weight: 27.5 lbs. Bolt pattern 114.3 x 5. Offset +45
When I bought the car, it came with brand new tires. Front is 245/40/19 and Rear is 285/35/19. Will the tires fit the rear wheels?
Also, I think I can put 20MM spacers in the front with no rubbing? Do I need to put any spacers in the rear? BTW, I am on BC coilovers.
Old Dec 30, 2014 | 12:24 PM
  #494
Front:
Rear:
You're running a pretty "pinched" mount in the rear running 285s on a 9" rim, it'll fit but the sidewalls will "roll" under hard cornering providing less than optimal performance. I'd run them since you already have them but your next set should be 275/35/19s back there. As far as spacers, that's entirely up to you, if you want a balanced look go w/ your 20mm front and whatever spacer in back to get a similar fit at the fender, probably something in the 10mm range.
Old Jan 4, 2015 | 08:15 PM
  #495
kimchi29's Avatar
kimchi29
Alright picked up some new wheels
Rotiform TMB
Fronts - 19x10 et20
Rears - 19x10.5 et48
Now im not too sure what tires i should get. These will be going on a 2014 Infiniti Q50 so fitment should be similar to a G37 sedan.
Local tire shop was saying 245/35 for the front and 255/35 for the rear. I drive my car (canyons once a week) and i think that the sizes they recommend have too much stretch. Any recommendations for tire sizes? Im going more for the fat tire than stretch.
