The OFFICIAL "I have a wheel offset / tire fitment question!" thread
Old Mar 28, 2017 | 11:21 PM
  #1876
Bennyjoel's Avatar
Bennyjoel
I want to run a 285 in the rear is it Possible ? 19x10 +33 ... I shoulda went 11 in rear but nothing I can do now lol... everyone recommending 275/35/19 but I'd like the extra true to look a little more aggressive in the rear
Old Mar 29, 2017 | 08:51 AM
  #1877
Yes, should have adequate clearance for the 285, it's only 5mm more. You could probably even squeeze a 295 in there.
Here's a G coupe running 10.5 +25 on 275s , and that would be about 6mm out with the 10.5 width, 8mm out for the offset minus 10mm for the narrower tire, so 4mm in from this setup if you ran 295s on your 10+33s
https://www.myg37.com/forums/brakes-...ml#post3891573
Old Mar 29, 2017 | 10:16 AM
  #1878
Bennyjoel's Avatar
Bennyjoel
I actually really love his look , it's very clean but I'm lowered on tien s tech . Will I need to shave the bracket ? Also by going 285 or 295 will it be too wide that like Ima almost be bogging out at start lol ? very curious question 😂
Old Mar 29, 2017 | 11:11 AM
  #1879
T_Hoff25's Avatar
T_Hoff25
Do you know the type of offset I would need if I went the 20x9 route on 255's?
Old Mar 29, 2017 | 02:03 PM
  #1880
Z97's Avatar
Z97
Do you mind me asking the offsets and front size on this?
I'm looking for F14s on my coupe but can't find crap on the internet lol
Old Mar 29, 2017 | 06:12 PM
  #1881
Bennyjoel's Avatar
Bennyjoel
I'm glad not a lot of Gs run f14s ! makes me feel a little different . lol I have 9.5 +27 and rear 10 +33 ... looking to fit a wide tire in the rear though ... if I had to redo it I'd go 11" in the rear though
Old Mar 29, 2017 | 06:43 PM
  #1882
Z97's Avatar
Z97
It's a good looking wheel and the work cr kais I feel are over played and don't match the lines of the 08 sport non ipl
Is your camber and all still in spec? Looks a tad bit tucked from your pics.. just curious how close it is in relation to the fender if you look above it.
Looking at Race golds :P
Old Mar 29, 2017 | 07:46 PM
  #1883
Bennyjoel's Avatar
Bennyjoel
It's tucked because of the stretch when I had my stocks on with spacers and the right tire size it was really flushed... I have camber arms but I can't recall what it was set at , it's not much. I went for that stock wheel fitment as far as offset goes but didn't account for the tires lol so when I swap tires to 285/295 and 245 In front it's gonna be really flushed .
Old Mar 29, 2017 | 09:16 PM
  #1884
I've ran 295s on my G sedan on 20x10s, the actual launch was pretty similar to narrower tires (didn't bog it down) but having the wide steamrollers in back really gave a planted feel in the corners. For your coupe the 285s would probably be the best mount on those 10s and still give you a bit of space to the fender, and some tires run wider than others so that would give you a bit of wiggle room.
Old Mar 29, 2017 | 10:38 PM
  #1885
Stachuu's Avatar
Stachuu
Hey guys, I'm buying this tire setup front- 255/45/18 & rear 285/40/18 for my g37x that has swift spring.
I will still need to buy rims, I need some advise what size on front and back?
or should I go with 255/40/18 & rear 285/35/18?
Old Mar 29, 2017 | 11:25 PM
  #1886
the93owner's Avatar
the93owner
Do you have the OEM 18" wheels? If so, those tires are way too large. If you are set on 255 and 285, you would need wider wheels to match.
Old Mar 29, 2017 | 11:28 PM
  #1887
Stachuu's Avatar
Stachuu
I have currently stock 17" wheels with 225/50r17 tires
Old Mar 29, 2017 | 11:49 PM
  #1888
the93owner's Avatar
the93owner
Well then you definitely need 18" wheels since they are size 18 diameter.
Old Mar 29, 2017 | 11:56 PM
  #1889
You'll want the 255/45 & 285/40 set for best AWD compatibilty and to keep your diameters closest to OEM.
For your X sedan you'd want 8.5 +30 or 9 +35 front 9.5 +40 or 10 +45 rear (give or take 2mm on all offsets)
Old Mar 29, 2017 | 11:58 PM
  #1890
Stachuu's Avatar
Stachuu
Right, I wanted to know is wheel size for front and back to adequate tires I'm getting, I don't want wheels sticking outside of the fender line.
So would I need to get wheels size 18x9 30? front and 18x10 25 rear?
