The OFFICIAL "I have a wheel offset / tire fitment question!" thread
Old Nov 22, 2016 | 10:27 AM
  #1726
SRZ's Avatar
SRZ
Thanks for the pics and reply. I think I like the 285 setup with a little more room like the fronts. +40F and +45R looks really good IMO. I am not a fan of stretched or bulge look at all. I would like a squarish look. Your car on 20's looks just right.
How about 19x8.5 with 245/40 +40 & 19x10 with 275/35 +45 lowered on Swift? Is the car in the G35 link I posted semi in front and deep in back? I really like that look for some reason.
Old Nov 22, 2016 | 10:35 AM
  #1727
Here's the spec listing F14 | Forgestar For the exact fit as mine you can run the 8.5+40 on 245/40 and a 10+45 on 285/35s this will get you the exact look in the second set of pics, and FWIW my camber is right a -1.0 so a fair amount under the max negative camber spec of -1.4. I'd run a 8.5 +35 in front though or that 9"+40, this will be a bit better fit up there. And that 285 on a 10 is a great mount IMO.
Old Nov 22, 2016 | 11:02 AM
  #1728
SRZ's Avatar
SRZ
If I do a 19x9 +40 up front, what tire size do you recommend for a squarish look.
285 on a 10" looks great.
Old Nov 22, 2016 | 11:05 AM
  #1729
the93owner's Avatar
the93owner
245 or 255 would match with the 285.
Old Nov 27, 2016 | 11:39 AM
  #1730
efp11's Avatar
efp11
Winter Tire Question
I have a RWD sedan with the sport package and staggered duckfeet wheels. I bought a new wheel/tire combo (photo below) a year and a half ago and have been planning on using the duckfeet as a winter set up. I put off doing it last winter essentially because of my confusion regarding the questions below.
I searched a bit on the forums and found some recommendations to use 235/45/18s all around to avoid the wider stock size of the rears which are 245. Here's what I couldn't find though:
1.Can I put 235/45 on the rear 8.5" wheels and 225/50 on the front 7.5 wheels?
2.If so, is there any advantage to that over putting 235/45 on all 4?
Old Nov 27, 2016 | 07:07 PM
  #1731
Not really an advantage to putting 235s all around unless you find a real good deal on that particular size. For a winter set you do want to keep the tires on the narrower side for cutting through the snow, you could even run 225/50s all around too.
Old Nov 27, 2016 | 07:10 PM
  #1732
efp11's Avatar
efp11
Thanks for the answer. Wait, I can run 225/50s on the rear 8.5" duckfeet? I thought those tires would be too narrow? Is that a case where it technically can be done, but shouldn't be? Or is it completely safe?
Old Nov 27, 2016 | 07:56 PM
  #1733
Depends on the exact model of tire you're wanting, 8.5" is the widest you'd want to run a 225 width tire on. Ideally the 235 all around would probably give you the best compromise for running the same width all around especially if they have the tire you want you want for a nice price.
Old Nov 27, 2016 | 08:57 PM
  #1734
efp11's Avatar
efp11
Tire Rack has the X-ICE XI3 in 235/45/18 for $176 per tire and the same tire in 225/50 is $165. Would that specific tire be OK in 225/50 on the 8.5" rears?
Old Nov 28, 2016 | 05:21 AM
  #1735
the93owner's Avatar
the93owner
The G37 coupe sport wheels come stock with 225/45/19 on the front 19x8.5 wheels, so it's fine.
Old Dec 7, 2016 | 01:26 PM
  #1736
mjnoles1's Avatar
mjnoles1
35mm offset on stock sedan suspension
I have a 2013 G37xs Sedan. I am looking at an aftermarket wheel only for a winter setup. I hate going aftermarket as I want to keep the car how the manufacture intended. However, I am unable to locate oem wheels at a reasonable price.
The aftermarket wheel I was able to locate is TSW MIRABEAU which is 18x8, 5.114.3 bolt pattern, the specification that is really making me feel uncomfortable is the offset is at 35mm. The car came factory with 45mm offset.
How will 35mm offset change the driving dynamic at all? Will the change to 35mm for winter driving put additional stress on the suspension as I read that changing the offset too much will do this. If the driving dynamic will not change it at all then how come Infiniti decided to go with an offset between 43mm-45mm on ours cars? There has to be some reasoning for this.
Old Dec 7, 2016 | 09:55 PM
  #1737
8.5 +35 would be a great winter spec, run 225/50/18s for a good narrow footprint for a good cut through the snow. The 10 mm further out is still fairly conservative. As far as why is the OEM offset so positive, they are kept well inside the fenders to keep debris from the tires to a minimum and minimum stress on the bearings. A 10 mm shift outward on a narrow 8" wheel won't have any adverse affects.
Old Dec 8, 2016 | 04:28 PM
  #1738
mjnoles1's Avatar
mjnoles1
Thank you blnewt,
I was able to locate wheels that are more in range with our specification, which makes me feel much better. 18x7.5 with +45mm offset. Dual lug of 5x100/5x114.3 and they are Enkei
I have to drive 40 minutes to an hour to get them. One of them are bent, so that is basically trash to me. The other three he says are in excellent condition cosmetically and physically (I will bring it to a tire shop to check to make sure they are not bent). I will then purchase a 4th used one online, I already see one listed for a great price in Ebay.
I am getting a fantastic deal. So much so, I got to ask. Do they make replica/fake Enkei's? I cannot imagine they would as they are not extremely expensive even when new. These are the Enkei "Performance" line which is their least expensive line.
Old Dec 12, 2016 | 03:44 AM
  #1739
Project-vipg's Avatar
Project-vipg
I'm trying to sell my oem 2010 G37xs sedan wheels and tires. Not snow tires and only fair tread left but if you're interested let me know.
Old Dec 12, 2016 | 10:08 PM
  #1740
b12G's Avatar
b12G
Hey guys, new to the forum here I own a 2012 G37 Coupe... I have a set of Avant Garde wheels specs are:
19x9.5 +15 (front)
19x11 + 18 (rear)
I will be on HSD Coilovers soon and have front and rear camber arms, im just wondering how i can run this setup without too much camber to stay away from uneven tire wear, i know i will have some regardless as these are very aggressive offsets. just need to hear some G owners opinions lol. Need to know what tire size to run and what alignment specs also.
Thanks!
