Official~Best offsets for running FAT tires!
Old Feb 14, 2018 | 12:14 PM
  #1336
PNW_IPL's Avatar
PNW_IPL
For meaty you need a 255 front and at least 275 out back. 235 is skinny.
Old Feb 14, 2018 | 03:21 PM
  #1337
Super aggressive offsets there, are you talking about widths (I hope).
Old Feb 15, 2018 | 11:30 AM
  #1338
b-drizzy's Avatar
b-drizzy
yeah those are the widths of the wheels they are +12 all around lol
I consider that fat for me lol probly not for you guys though
my last setup was pretty stretch
was running
front -225/35/ 19x9.5 +12
rear - 245/35/ 19x10.5 +22
Old Feb 15, 2018 | 11:31 AM
  #1339
PNW_IPL's Avatar
PNW_IPL
I consider that fat
was running
your perception is wrong. This is NOT the thread for you. We do not want to see that crap here. Move along stance boy.
Old Feb 15, 2018 | 08:18 PM
  #1340
Nico-derm's Avatar
Nico-derm
So cruel but true.... I've missed this place.
Old Feb 16, 2018 | 07:02 AM
  #1341
future62's Avatar
future62
Those are stretched sizes for those tires man. You need like 255-275 up front and 285-295 out back.
Old Feb 16, 2018 | 08:47 AM
  #1342
Actually the thread title is a bit misleading, b-drizzy nailed the aggressive offset part
Running super aggressive offsets tends to eliminate the ability to run FAT tires
Maybe title should be Reasonable offsets w/ FAT tire thread.
Old Feb 16, 2018 | 01:22 PM
  #1343
PNW_IPL's Avatar
PNW_IPL
well if going off the title I concede. The hellaflush guys are indeed aggessive so my apologies on that end. However this should be retitled to reflect
Old Feb 16, 2018 | 09:34 PM
  #1344
Yeah, let's just do it then
Old Feb 19, 2018 | 11:17 AM
  #1345
b-drizzy's Avatar
b-drizzy
lmao you guys are funny
all good if I got the wrong thread for my question
Ill keep searching
thanks..
Old Feb 28, 2018 | 08:57 PM
  #1346
StarKiller's Avatar
StarKiller
Be careful there, what front tire are you running?
Might have to run 255/40 all around, it will stretch enough to tuck inside the rear fender edge but not stretch enough to alter the diameter enough to cause problems w/ your AWD. If you run tires w/ a front to rear diameter variance over 1% you may cause the AWD light to come on at higher speeds and could cause some damage to that system.
all good G. Use the forum for help. Try camber if not 275 if fails sell em and go square like X should be.
Thank you both for your help I think I got everything sorted out. Went with 25540s on all 4s. No rubbing and the tire tucks in!
Old Feb 28, 2018 | 10:03 PM
  #1347
Glad it worked out there Star!
Old Apr 6, 2018 | 08:53 PM
  #1348
awestrella14's Avatar
awestrella14
Yeah, the +23 offset in back is the killer. Member Ryne did the staggered wheel w/ same tire size on his AWD coupe and it actually worked well. I think the 255/40s all around is your best bet as far as keeping everything inside your fender edges and not messing w/ your AWD system. You could possibly run a 265/35 in back but then you'd need a 235/40 front and those sizes aren't that common, so finding tires you like might be a chore. 275s can work w/ extra camber but IMO keeping alignment close to spec is more important, especially w/ the more complex AWD setup.
I am going to buy Nismo wheels for my G tomorrow and was wondering who Ryne is or how I get some pictures of his car. Any help is appreciated! If not what specs will I have to run to make this work?
Thanks
Old Apr 6, 2018 | 10:20 PM
  #1349
Nico-derm's Avatar
Nico-derm
Coupe or sedan? Nismo rears are a little too aggressive for a sedan is all...
Old Apr 6, 2018 | 11:12 PM
  #1350
Yeah, I wouldn't consider the staggered Nismos if I had a sedan, and if you have AWD that needs to be considered as well.
