Official~Best offsets for running FAT tires!
Old Jan 8, 2018 | 07:43 PM
  #1321
PNW_IPL's Avatar
PNW_IPL
Originally Posted by StarKiller
Well they were only on the car for 75mi currently in storage as the Mn winter is in full effect. lol thx for the quick answers!
all good G. Use the forum for help. Try camber if not 275 if fails sell em and go square like X should be.
Old Jan 8, 2018 | 08:55 PM
  #1322
would that increase tire wear? mind you it's also a X.
Be careful there, what front tire are you running?
Might have to run 255/40 all around, it will stretch enough to tuck inside the rear fender edge but not stretch enough to alter the diameter enough to cause problems w/ your AWD. If you run tires w/ a front to rear diameter variance over 1% you may cause the AWD light to come on at higher speeds and could cause some damage to that system.
Old Jan 8, 2018 | 09:12 PM
  #1323
PNW_IPL's Avatar
PNW_IPL
yea I think he did like 0 research before staggering and having tires that far off LOL
Old Jan 8, 2018 | 09:14 PM
  #1324
StarKiller's Avatar
StarKiller
the plan was to run 2454019 with the 2753519 to stay within parameter
Old Jan 8, 2018 | 09:55 PM
  #1325
Yeah, the +23 offset in back is the killer. Member Ryne did the staggered wheel w/ same tire size on his AWD coupe and it actually worked well. I think the 255/40s all around is your best bet as far as keeping everything inside your fender edges and not messing w/ your AWD system. You could possibly run a 265/35 in back but then you'd need a 235/40 front and those sizes aren't that common, so finding tires you like might be a chore. 275s can work w/ extra camber but IMO keeping alignment close to spec is more important, especially w/ the more complex AWD setup.
Old Feb 10, 2018 | 12:06 PM
  #1326
turbohounds's Avatar
turbohounds
It's time I need to start thinking about summer tires, and after reading 89 pages I still need help. I'd like to run less stagger for autocross/track this year. My car is a 2008 journey coupe, lowered on Eibach springs.
My current setup is 285/20-30 on a 10.5" rim, 33mm offset in back and 245/20-35 on a 8.5" rim, 25mm offset in front. I tried the 285's up front and they fit and turn lock to lock, but I suspect first bump would take out the front fender. I need help choosing a rim that will work up front to pair better with the 285 in back.
Consensus looks like I could get away with 19" rim, 9.5" width, and offset in the range of 25-30mm? What would everyone recommend? What offset would pull the outside edge inboard?
Can I fit a 275/35ZR19 in front without tearing up the fenders, or would a 265/35ZR19 be better? I can find Toyo Proxies in the 275 width, but would have to go to Michelin Pilot Sport Cup 2 for the 265 width. This would be for track only setup, although I have to drive 40 miles each way to get there ...
Old Feb 10, 2018 | 12:09 PM
  #1327
PNW_IPL's Avatar
PNW_IPL
I ran 19x10 +30 275 35 no issues. Pretty low as well. I was running 295 30 out back on 19x11 +20 and it was too aggressive. +30 would have worked or if I raised my car an inch it would have but I didn' want to do that.
Old Feb 10, 2018 | 01:05 PM
  #1328
projectpanda13's Avatar
projectpanda13
Toyo Proxes T1 Sport comes in a 265/35zr19 size also the R888 too.
Latez
Old Feb 10, 2018 | 03:54 PM
  #1329
future62's Avatar
future62
turbohounds... coupe or sedan?
The rim is kind of irrelevant outside of being safe for the tire. It's mainly about the offset, tire width and camber. On my sedan I am running 255 @ +25 up front and it just clears with stock arms. +45 would probably enable 275-285 on the outside if it clears the spindle. I have seen people fit 275s up front so I'm pretty sure the spindle clears.
Man that is a lot of meat.
Old Feb 11, 2018 | 12:06 AM
  #1330
PNW_IPL's Avatar
PNW_IPL
255 40 275 35
Eventually going 275 35 up front with 10mm spacer.
Old Feb 11, 2018 | 02:14 AM
  #1331
ngolbuff's Avatar
ngolbuff
[QUOTE=PNW_IPL;4182451]
You must have the super rare Ferrari sport version G37. I hear there wasn't many made.
Old Feb 11, 2018 | 02:15 AM
  #1332
PNW_IPL's Avatar
PNW_IPL
[QUOTE=ngolbuff;4182468]
you know it man!! You know rari!
Old Feb 11, 2018 | 09:03 AM
  #1333
turbohounds
Coupe. I'm aiming for as much meat as I can get. Turn baby turn!
Old Feb 13, 2018 | 07:30 PM
  #1334
saywat?'s Avatar
saywat?
"whats the retail on one of those?"
"LESS than you can afford pal.....G-rarriiiiii!"
Old Feb 14, 2018 | 11:55 AM
  #1335
b-drizzy's Avatar
b-drizzy
any one running 235/35/19 with a 265/30/19
offsets 9.5 and 10.5
just got a set recently and want to go meaty this time with some minor poke
I need to see some piks on a sedan see how it sits
thanks.
