Official~Best offsets for running FAT tires!
Old Apr 19, 2017 | 10:00 PM
  #1246
Nice! You're going to like those treads! Slartibartfast was referring to those track NT05s, those extreme performance Summers can be pretty slick when wet once they get worn. The Michelin Pilots are very good in rain all the way to the wear bars, so no worry
Old Apr 20, 2017 | 08:47 AM
  #1247
Nico-derm's Avatar
Nico-derm
Keep in mind the Pilots run a bit wider than most, so you still might be tighter at the fenders but if you don't mind running a bit more camber you should be fine (and you might just be fine as-is)
Being a coupe I imagine he will be fine... should have a little bit more space back there then our sedan's. Personally I went with the S-04's, have about 3500 miles on them and have no complaints. I didn't want to wait on PSS backorder at the time.
Old Apr 20, 2017 | 08:56 AM
  #1248
Right you are Nico, coupe will have about 12-15mm more fender room, I was assuming sedan and had that in my head the whole discussion. Now I look back and see that pic link w/ that hot blue coupe, you could even run positive camber now
Old Apr 20, 2017 | 08:58 AM
  #1249
Nico-derm's Avatar
Nico-derm
I still believe the 295 will be a better fit for his wheel... the idea of 305's in nice but you won't gain much, if any traction with the bulge
Old Apr 20, 2017 | 02:20 PM
  #1250
295s is a better mount on a 10, and with that extra hp of being boosted I'd be nervous about sidewall damage w/ a 305 on a 10 if you're really doing some pushing w/ that G.
Old May 2, 2017 | 12:01 PM
  #1251
crash0veride's Avatar
crash0veride
Got em mounted up and on the car finally. Ended up going with just the Pilot super sports. The PS4's are seemingly almost impossible to obtain right now in the 295/30/20 size.
Thank you for the help blnewt! The fitment of these were absolutely on point.
Here are a couple pictures:
Old May 2, 2017 | 04:21 PM
  #1252
Awesome! Glad you're happy w/ the fit, and that shot from the back is a hell-yeah!
Old May 7, 2017 | 06:49 PM
  #1253
future62's Avatar
future62
I've just gone through 10 pages and I give up.... I have an S sedan, looking to drop it on coilovers with 19s. I know how to choose offset and rim width to get flush.... just want to know what are the widest tires I can run without having to roll fenders or w/e. 255/285? I'm probably going to leave 1 finger gap all around.
Old May 7, 2017 | 08:01 PM
  #1254
Was running 295s in back on my zero-gap sedan, that was a 20x10+45.
I had a couple mm to the fender lip running camber at -1.0
Here's a link of that setup (i'm now running a square 18" setup)
https://www.myg37.com/forums/picture...ml#post3575335
Keep in mind the tires can run wider or narrower depending on brand and model. Most tire companies are good about listing their actual section widths so you can compare.
Old May 10, 2017 | 10:40 AM
  #1255
future62's Avatar
future62
Thanks, that is good info. Do you have a link to your current setup? I was also thinking about running square so I could rotate tires.
Old May 10, 2017 | 02:17 PM
  #1256
Here you go, tires are 245/45/18s but getting 285/40/18s for the back tomorrow.
https://www.myg37.com/forums/wheels-...ml#post4036538
Old May 17, 2017 | 02:25 PM
  #1257
Ok, I was part of the fat club, went to the square club but had to get back to fat, went from 245/45/18s all around to 285/40/18s in back all on 18x9.5 +38s
Old May 17, 2017 | 03:29 PM
  #1258
VenomGT9's Avatar
VenomGT9
atta boy
Old May 19, 2017 | 05:38 AM
  #1259
Project-vipg's Avatar
Project-vipg
Anybody know of a company that makes a square setup close to 19x10.5 et0 or 19x10.5 -10 ? I can only find staggered setups or custom made wheels
Old May 19, 2017 | 08:59 AM
  #1260
I posted a couple Work sets in that other thread that are 10.5 +12, not quite that aggressive but almost
