Official~Best offsets for running FAT tires!
Old Mar 28, 2017 | 05:43 PM
  #1216
reNeglect's Avatar
reNeglect
Finally mounted the work wheels over the weekend along with outcast splitter install..
To recap..
19x9.5 +30 Front 255/35/19 (leftover from last setup, will switch to 245 or 255 40/19 when these are done)
19x10.5 +30 Rear 275/35/19
Overall, i was planning to run 5MM spacers in the front, not needed... pokes to much with it.
Alignment specs are at -0.8 front, -2.0 Rear
Old Mar 28, 2017 | 05:57 PM
  #1217
PNW_IPL's Avatar
PNW_IPL
To recap..
Nicely Done. Id add the 5mm to match the rear poke!
Old Mar 28, 2017 | 06:28 PM
  #1218
Very nice setup there, quality shoes and looking good from the back w/ that black Fuji and spoiler.
Old Mar 28, 2017 | 07:37 PM
  #1219
VenomGT9's Avatar
VenomGT9
well done, now go wider
Old Mar 28, 2017 | 09:04 PM
  #1220
PNW_IPL's Avatar
PNW_IPL
13s!!!!!!
Old Mar 29, 2017 | 08:46 AM
  #1221
Nico-derm's Avatar
Nico-derm
Setup looks good, pretty jealous you have the ability to put on your summers.... I still have NO grass showing in my yard and we got 6 inches of snow Saturday
Old Mar 29, 2017 | 10:23 PM
  #1222
iyaman's Avatar
iyaman
Finally made up my mind that I really like the Work Kiwami wheels in Matte Bronze. I have a convertible and planning on ordering this set up.
Front: 19 x 10.5 + 22 ( kiwami also comes with +32 offset)
Rear: 19 x 11 +18 ( the only kiwami offset on the 11 inch)
Tires: I had been set on putting the 305/30 on the rear and 275/35 on the front but I will adjust accordingly if only to accomodate the above set up.
Everything is stock but planning on putting akebonos and lowering it on the coming months.
Needing your suggestions and recommendations.
Thank you blnewt, cereal 2k, ravspec and others for answering my questions.
Old Mar 29, 2017 | 10:31 PM
  #1223
PNW_IPL's Avatar
PNW_IPL
Thats gonna look so good!
If you do a lowering spring hit me up i have low mileage IPL struts to pair with them!
Old Mar 29, 2017 | 10:48 PM
  #1224
iyaman's Avatar
iyaman
Saw your ride and it looks good.. Can you please post a pic of the rear wheels/tire in relation to the fender. BTW, where in PNW? Seattle here. Thanks.
Old Mar 29, 2017 | 11:40 PM
  #1225
The front of the convertible isn't nearly as wide as the back, it's going to run real tight in front w/ a 275 on a 10.5+22, the +32 should be an easier fit unless cereal2k verified that spec.
Check this recently lowered vert running Front 20x9 +18 245/30, Rear 20x10.5 +25 285/30
https://www.myg37.com/forums/g37-con...ml#post4120858
IMO his fitment is very good for a staggered setup on that vert, the wheels are right at the fender edges (or very, very close) and the tires allow for no rubbing but still fairly flush w/ no threat of rubbing.
Using that as reference the 10.5+22 w/ 275s would be 4mm in for offset, 18mm out for wheel width and 15mm out for tire width for a net 29mm out from this front fitment or about an 1 1/8" further out, if you went w/ the +32 in front you'd have a more manageable 18mm or about 3/4" out from that reference.
In back will be tough w/a 11 +18 w/305s, it will be 6mm out for the wheel width and another 7mm out for offset and 10mm out for the tire width for a total 23 mm out from the reference but this could probably be handled w/ camber perhaps.
If it were my shopping cart and those were the only wheel widths I wanted, I'd go w/ the 10.5 +32 and the 11 +18 but hold off on tires until you can do a test fit of the wheels safely compressed on a raised vehicle (wheels lowered down on some old extra tires to protect them is one way). I'm thinking you'd probably have to run 295s at the most in back, but
Old Mar 30, 2017 | 12:50 AM
  #1226
iyaman's Avatar
iyaman
As always, thank you Brad. Looking at hottrods vert, leaning more towards your suggestion of front: 19 x 10.5+32 and rear: 19 x 10.5+22 maybe?
Old Mar 30, 2017 | 08:56 AM
  #1227
Might send a PM to hottrod, he seems pretty good at supplying pics, see if he can take a couple going straight down the side so you can see exactly how those wheels are sitting at the fenders.
Old Apr 3, 2017 | 12:00 AM
  #1228
iyaman's Avatar
iyaman
Since I'm ordering my wheels tomorrow, I did some measurement and simple computation to have an idea of the fitment. Is this a correct math?
Hub to edge of the fender is 4.5" = 114.3 mm
width of wheel is 11" = 279.4 mm
offset = 18mm
width=279.4mm/2 = 139.7mm ( middle = 0 offset)
139.7mm - 18mm offset = 121.7mm
121.7mm - 114.3mm = 7.4mm---this will poke past the fender.
Is this correct? lol
Old Apr 3, 2017 | 12:03 AM
  #1229
PNW_IPL's Avatar
PNW_IPL
TACOMA
Old Apr 3, 2017 | 12:04 AM
  #1230
PNW_IPL's Avatar
PNW_IPL
Specs are
19x10 +20 275/30/19
19x11 +20 275/35/19
