Official~Best offsets for running FAT tires!
Old Feb 19, 2016 | 07:04 PM
  #1066
Originally Posted by tigerlui
Hi there, i have a question here. I have a '10 G37S Sedan, lowered on Tein-S springs.
Currently, i am sitting on STR607 20x9 (+30)F/ 20x10.5R (+45) , with 245/30/20 and 275/30/20 and they fit fine.
I am looking into a set of used wheels. They are 20x10 +20 square set, with 255/35/20 tires mounted on. Will the rear fit?
Not without some heavy camber at the minimum, and the front will be even tighter.
Old Feb 19, 2016 | 07:09 PM
  #1067
Originally Posted by StreetShotz
From what I can gather a 20x9.5 +40 up front and a 20x10.5 +45 in the rear.
For tires a 245/30R20 and a 295/30R20 for the rear.
Opinions, experiences?
If you plan to do some track duty you want to run a bit more camber, shoot for a -1.7 to -2.0, this will open up a bit more tire for you to run.
If you want a 9.5/10.5 stagger I'd run 9.5 +30 to +35 front on a 245/35 and 10.5 +40 on a 285/30, you'd probably have room for a 295 as well depending on how wide the tire brand actually runs.
Be sure to run a 35 series in front and a 30 in back, this will keep your rolling diameters close front to back.
Also be sure to confirm big caliper clearance for the front wheel, with a +35 you should be ok for most wheels but some need even more room.
Old Feb 19, 2016 | 07:19 PM
  #1068
Originally Posted by 4DRZ
From your experiences, what is the most negative camber you can run front and rear without having to worry about cupping the tires? I run Tein Basis and will probably be running 245/275 19 RE-71R or something similar for mostly street, but a handful of track days. It looks like I might need rear adjustable camber arms is there is way more negative camber in the back right now on the snow tires.
Seems like camber in the -1,7 to -2.0 is a good setup for some track days mixed in w/ mainly street driving. As long as your toe is in spec and you can rotate your tires (at least side to side) every 7k miles you should expect reasonable wear.
Old Feb 19, 2016 | 10:45 PM
  #1069
StreetShotz's Avatar
StreetShotz
Thats great info.
Sadly the wheel sim looking at are 20x9 +32 or +20 and 20x10.5+45 or +27
Would I be able to run these with no rolling, cutting, crazy camber?
Old Feb 19, 2016 | 11:03 PM
  #1070
VRG37S's Avatar
VRG37S
Thats great info.
Yep the 20x9 +32 for the front will work fine
20x10.5 +45 will work fine for the rear
With these offsets u should be able to run a 255/285 combo no prob without rubbing or any fender modifications
Hope that helps
I run a 20x9.5 +35 and 20x10.5 +37 with a moderate 1.2 drop with a 255/285 tire combo and I don't rub on fenders or anything.
Old Feb 19, 2016 | 11:21 PM
  #1071
StreetShotz
Hope that helps
Thats a massive help.
I do plan on running on coils (KW V3 or similar) and need usable ground clearance so wont be super low.
Old Feb 19, 2016 | 11:49 PM
  #1072
The +45 in back will allow you to run more tire, like VRGs' coupe, you'll be fine w/ 285s. I ran 295s on my 10 +45 on my sedan and the coupe has more room to the outside, so 295s would work as well And my camber is low, around -1.0, so running more camber for some track duty you'll have even more room.
Old Feb 23, 2016 | 09:15 PM
  #1073
jthibodeau89's Avatar
jthibodeau89
My car is a 2012 G37xS Coupe. I'm looking at the Forgestar CF5V in 20x9.5 +40 (or 20x9 +35) and 255/35 P-Zero tires FR and 20x10.5 +45 with 295/30 P-Zero on the rear Rear. From what I have read this should be no problem with my mild coilover drop. Forgestar is confirming that the Ksport Supercomp 400mm BBK will fit, but I think it is no issue diameter wise, just a concern with offset clearance.
With all the room to the inside of the coupe rear, is it possible to fit a 325/25-20 P-zero (13.5" section width) on 20x12 +80 wheels? Forgestar is also check caliper clearance on this , but it is likely just a dream.
Old Feb 24, 2016 | 12:10 AM
  #1074
You'll have serious clearance problems to the inside w/ that 12" with that much positive offset. Those K sport calipers should clear pretty easy as far as to the spokes, they aren't as fat as the Akebonos since they're a longer 8 pot setup.
You could run a 9.5 +30 in front on 255s and an 11" +40 w/ 295s or +45 w/ 305s. The 255/35 & 305/30 is a decent combo, it's 0.65% larger in back so over time you'll get that variance closer to zero.
Old Feb 24, 2016 | 09:06 AM
  #1075
VenomGT9's Avatar
VenomGT9
We need some pics up in this thing!
305+ perhaps
Old Feb 24, 2016 | 10:00 AM
  #1076
jthibodeau89
Thanks for the advice on the 305/30. I was thinking that it was too big of a step, but didn't consider the wear bringing it back closer to spec.
I may mock up the 325/25 tire and 12" +80 wheel to see where the issues lie. I'm not against pulling the finder liner and making a custom CF/Kevlar liner.
I'll definitely post up pics in the coming months as this comes together.
I'm coming down off of a GTR addiction. I turned in my corporate lease after a 1 yr love affair with 2 different 2015 GTR's (gawd I love working here). I've decided to turn a G37xS into a GTR stalker for the East TN mountain roads. First comes the susp/wheels & tires/LSD, then BRAKES, and finally the powertrain. My target is 600whp.
This forum is a wealth of information. Thanks for the help.
Old Feb 24, 2016 | 11:16 AM
  #1077
Ryne's Avatar
Ryne
The Steering Wheel Guy
The max negative side of OEM spec, maybe a touch extra. I'd say -2. Tire cupping is more so a product of bad suspension, such as blown shocks/struts. Toe also has a much larger impact on tread wear than camber.
Old Feb 24, 2016 | 02:33 PM
  #1078
steezy's Avatar
steezy
Originally Posted by Chi-City-G
Nitto NT05:
255/35 front
275/35 rear
Can you give full specs and offsets of this?
Old Feb 24, 2016 | 02:37 PM
  #1079
steezy's Avatar
steezy
Hope that helps
Are you lowered? This it possible to run run this setup with 2 inch drop?
Old Feb 24, 2016 | 02:40 PM
  #1080
steezy's Avatar
steezy
Hope that helps
Can you post a picture of your setup?
