Official~Best offsets for running FAT tires!
Old Jul 19, 2015 | 02:28 PM
  #1036
Originally Posted by johnnyn
245/35/20 on 20x9 with +35 offset. How wide do you think I could go in the rear without rubbing issues? I wanted 285 but I was unsure. 275 seemed safer
With that offset you could probably run a 295, prior to my new tires (which I had to get 285s since I was on vacation and couldn't wait for the 295s to be shipped in) I was running 295s on 10+45 and the coupe has a bit more width in back, you could run 285s for sure.
Old Jul 19, 2015 | 02:39 PM
  #1037
johnnyn's Avatar
johnnyn
Good to know for my next set up thanks. I'm anxious to get these wheels on and share some love in this thread!
Old Jul 19, 2015 | 11:34 PM
  #1038
johnnyn's Avatar
johnnyn
Here I go!
Niche Lucerne
20x9 +35 245/35/20
20x10 +40 275/30/20
Old Jul 20, 2015 | 12:24 AM
  #1039
Nice choice in wheels Johnny, really go well w/ your coupe and the coilovers look to be well balanced front to rear. Have you had it aligned yet?
Looks like you have about 10mm to go out so 295s probably would have squeezed right inside But the fit looks good, and you can always add some small spacers for a final flush up if you want.
Old Jul 20, 2015 | 12:56 PM
  #1040
johnnyn's Avatar
johnnyn
Thank Newt. I really love how my wheels turned out. I've gotten an alignment done when I first installed the coilovers. I do want to lower the fronts and rears maybe a quarter or 1/2inch. I'd like my tires to be just a little tucked.
The wheels could definitely poke out some more. You make me regret not going 295s now
Old Jul 24, 2015 | 12:52 PM
  #1041
StAtiXz6's Avatar
StAtiXz6
Sup guys. Spur of the moment choice I just installed some Toyo Proxes 255/40/19 and 285/35/19 on Forgestar F14 wheels on my coupe. Im not crazy about the look as of yet and looking to see if anyone has any pics to show what their drops look like on them. I came from having 245/35/19 and 285/30/19. The car as of right now sits 1.25 inches higher then my original setup. Just looking for ideas before I pull them off
Old Jul 24, 2015 | 04:08 PM
  #1042
ToXIc's Avatar
ToXIc
made this to keep the sedan/coupe info separate because of different fitments....
https://www.myg37.com/forums/g37-sed...fat-tires.html
Old Jul 24, 2015 | 09:35 PM
  #1043
Can you post some pics of your G in its' current state?
Those sizes are very common around here, here's one example
https://www.myg37.com/forums/wheels-...ml#post3475967
Old Dec 18, 2015 | 11:42 AM
  #1044
Suubes's Avatar
Suubes
Do 18's really look that bad on G's? Seen some really nice looking 19 inch combinations early on in this thread
What do you guys think about
18x9.5 +15 255/45/18
18x10.5 +22 275/40/18
On eibachs
Its either that or 20's and in Chicago i am really concerned about some of these massive pot holes chewing through 20's on low profile tires
Old Dec 18, 2015 | 10:01 PM
  #1045
On eibachs
18s look just fine,especially if the wheels are higher quality. Staffer Lt8che runs 18s on his turbo setup.
Those sizes are a bit aggressive IMO, you'll have some wheel poke, I'd try 5 to 10 more positive mm w/ those tire sizes you're planning.
Old Jan 12, 2016 | 10:31 PM
  #1046
Roadrash666's Avatar
Roadrash666
On eibachs
Enkei Kojin
18x8.5 +35 fr 245/45/18
18x9.5 +30 rr 275/40/18
On Eibachs
Attached Thumbnails Official~Best offsets for running FAT tires!-20150525_175235.jpg
Old Jan 14, 2016 | 09:28 PM
  #1047
changbang's Avatar
changbang
Hey guys, I recently just bought these works gnosis that came off a bmw 335. 19x9+31 19x10.5+32. I know I'm going to need adaptors to run them. I was wondering if I can run 295. What do you guys think? Right now I'm on stock 19s lowered on HSD coils
Old Jan 14, 2016 | 10:39 PM
  #1048
changbang's Avatar
changbang
Old Jan 14, 2016 | 11:57 PM
  #1049
Depends on how thick the adapter is, a 15mm adapter will put you at 9 +16 front and 10.5 +17 in back, that's going to take some work to get that net offset to fit. Probably a combo of camber and stretch at a minimum, and maybe fender work as well.
Old Jan 15, 2016 | 01:15 AM
  #1050
mkn23's Avatar
mkn23
i have a 2009 g37 sedan with akebonos, would a set of BBS RS-GT 18x8 +18 front & 18x9 +18 rear be too aggressive for the sedan? and what are the limits of pulling/flaring the guards?
