Official~Best offsets for running FAT tires!
Old Mar 28, 2013 | 11:38 AM
  #286
dagon68's Avatar
dagon68
Old Mar 28, 2013 | 11:47 AM
  #287
kdawg8526's Avatar
kdawg8526
holy shytt
Old Mar 28, 2013 | 12:01 PM
  #288
Robert_K's Avatar
Robert_K
LOL!!! It moved a little...
Old Mar 28, 2013 | 12:04 PM
  #289
JMS2000's Avatar
JMS2000
Originally Posted by dagon68
Needs some spacers... lol
Old Mar 28, 2013 | 12:26 PM
  #290
soundmike's Avatar
soundmike
^ good heavens.
Originally Posted by Robert_K
Yeah... And I want a square set-up. I'm not about that HellaGay, crazy, non-functional, stance, shit. /end rant. LOL
I ran right around -2.2 two setups ago. Toe was in check and with rotations (i.e. directionals where you can flip 'em side-to-side by dis/remount) camber wear was not a issue.
Might be worth looking into if you're set on the 295s. I'd run 295s myself if given the opportunity. Brad is such bad influence in these here parts.
Old Mar 28, 2013 | 12:30 PM
  #291
WARAT's Avatar
WARAT
Stretch this!!!
Old Mar 28, 2013 | 02:01 PM
  #292
Dang 305's would be insane! Im running 295's on a 10.5 with stock camber/alignment. I did take mine in for an alignment and the checked it. Said it was still within specs and not needed. Im getting close to needing new shoes so I may try a 305
Go for it, you'll be immediately promoted to king of this thread
Agree^^, and you started me turning to the dark side Mike
Originally Posted by WARAT
Stretch this!!!
LOL, looks like he's running zero camber and about 425/30/20s
Oh and as far as clearance, it wasn't a control arm but a body mount that I was referring to, but there's at least an inch space so it's all good back there.
Old Mar 29, 2013 | 02:53 AM
  #293
Robert_K's Avatar
Robert_K
Cough! Click me! Cough!
In all seriousness... I think someone has a 305 on their sedan in the Vossen thread.
+1!
Old Mar 29, 2013 | 03:00 AM
  #294
kdawg8526's Avatar
kdawg8526
sunnyg had 305's on his sedan
Old Mar 29, 2013 | 03:17 AM
  #295
Robert_K's Avatar
Robert_K
I knew someone was/had. Need to get him in this thread!
Old Mar 29, 2013 | 08:16 AM
  #296
Yan141's Avatar
Yan141
Stretch this!!!
danggggggg
Old Apr 2, 2013 | 12:40 AM
  #297
Robert_K's Avatar
Robert_K
Only thing I like to stretch is the vag.
Old Apr 5, 2013 | 10:20 AM
  #298
Robert_K's Avatar
Robert_K
OK... Talked with TireRack so far and they don't have a BFG Comp-2, 255/40 in stock. However they do have a 255/35 & 285/35 in stock. Thoughts gentlemen?
Old Apr 5, 2013 | 11:59 AM
  #299
kdawg8526's Avatar
kdawg8526
you should go with 255/35 the sidewall will be jus perfect
Old Apr 5, 2013 | 01:50 PM
  #300
soundmike's Avatar
soundmike
Personally, i think 255/35-19 is too short. Are you dead set on the BFG's?
How much wider can you go with the front tires so the ratio/overall height is closer to OEM?
