Official~Best offsets for running FAT tires!
Old Mar 27, 2013 | 12:04 PM
  #271
Robert_K's Avatar
Robert_K
Thanks! Man so tempted to run the 295's but I think the 285's would be the safe route.
Old Mar 27, 2013 | 12:10 PM
  #272
kdawg8526's Avatar
kdawg8526
how much camber are you running in the back blnewt?
Old Mar 27, 2013 | 12:42 PM
  #273
It would be great if you had a shop that could test fit 295s, know anyone??
You could always camber up a little if you were real close.
Not much, drivers side is -.6 and passenger -1.2 degrees.
Old Mar 27, 2013 | 12:52 PM
  #274
kdawg8526's Avatar
kdawg8526
damn thats close to stock thanks for the info try to get some **** shots of those tires
Old Mar 27, 2013 | 01:05 PM
  #275
Robert_K's Avatar
Robert_K
The hard part for me is timing and being in Iraq. Like to know if anyone is running the same setup.
Old Mar 27, 2013 | 01:30 PM
  #276
Here's a few pics in this single post, if you want some more I think I have a couple~
https://www.myg37.com/forums/3562453-post176.html
Old Mar 27, 2013 | 11:15 PM
  #277
Robert_K's Avatar
Robert_K
I think I'm going to stick with the 255/40 & 285/35. Maybe once they burn up and I can confirm a 295 fitment with the Swifts I'll do it.
Can someone confirm the wheel studs are; 12x1.25 pitch.
Old Mar 27, 2013 | 11:31 PM
  #278
Probably the safest plan And 285s are still fat enough to be in this thread, lol.
And yes, those are the stud specs (just checked my box for my wheel locks and they're 12x12.5)
Old Mar 27, 2013 | 11:57 PM
  #279
kdawg8526's Avatar
kdawg8526
do you think 305/30 is possible on a 10 inch rim
Old Mar 28, 2013 | 07:35 AM
  #280
Robert_K's Avatar
Robert_K
I'm not sure on a 10" wide wheels but I know I've seen someone stuff a 305 on a sedan.
I bet a 305/30-19 +50 might work. That's a big tire for a sedan.
Old Mar 28, 2013 | 09:19 AM
  #281
soundmike's Avatar
soundmike
I think ultimately it's really a matter of playing with camber. ;-)
Old Mar 28, 2013 | 09:21 AM
  #282
5mm out from where I am w/ a 20x10 +45, so a +50 would work, there's a back control arm (I think that's what it is) that may start coming in to play w/ inside interference but not sure.
Old Mar 28, 2013 | 09:41 AM
  #283
Robert_K's Avatar
Robert_K
Yeah... And I want a square set-up. I'm not about that HellaGay, crazy, non-functional, stance, shit. /end rant. LOL
Old Mar 28, 2013 | 09:42 AM
  #284
dagon68's Avatar
dagon68
Dang 305's would be insane! Im running 295's on a 10.5 with stock camber/alignment. I did take mine in for an alignment and the checked it. Said it was still within specs and not needed. Im getting close to needing new shoes so I may try a 305
Old Mar 28, 2013 | 10:40 AM
  #285
Robert_K's Avatar
Robert_K
Do it! LOL
