Old Sep 17, 2025 | 09:54 AM
  #10531
This morning I took the car to the shop for my annual NYS Inspection. It passed. And yes those are aftermarket cats, don't look too closely, thank you.
While the car was on the lift, the technician and I went over everything visible and accessible for the underside. Typical weeping around the steering rack, and there's a barely perceptible weakness in the driver side sway bar end-link, but otherwise everything was A-OK. Occasionally I'd hear a rattle underneath, and I think we found it with the little cross member under the Fast Intentions pipes in the middle of the car. There was like 1mm clearance. So I had him remove the cross member and reinstall with a couple of washers, for a little bit of added space. No more rattle, knock on wood.
Old Sep 17, 2025 | 10:58 AM
  #10532
socketz67's Avatar
socketz67
Community Builder
Originally Posted by JZ39
Probably bc it works 😁. You get multiple pre-wipes to remove oxidation, a nice sanding handle with Velcro to attach two different grits of wet sanding paper and the final sealant wipes.
You have to have faith though. When you get done wet sanding the plastic is completely hazy and looks like total crap. Then you run a wipe over them and instantly they become 100% clear. Quite amazing.
Next I’m going to try their trim restorer on my FX50.
So their solution uses a wipe vs spray paint? Interesting. I have used the Maguaris (spray paint) on my kids cars and it looks amazing for about 8-9 months, then it starts to regress and you need to get all the old paint off before you can redo. Not easy to get that crap off.
If the lights aren't too bad, a little WD40 on a paper towel works wonders after a wash. I use this on my wife's car and occasionally on my G's driver's side light as it will start fading if it spends too much time outside.
Old Sep 17, 2025 | 11:00 AM
  #10533
socketz67's Avatar
socketz67
Community Builder
I hate to think about how much time I would spend tinkering under the car if I had a lift. Hard on the body at our age working under there suspended on jack stands.
Old Sep 17, 2025 | 02:18 PM
  #10534
A personal lift would be amazing. I've never rested the car on jack stands. But I do have a pair of Race Ramps that I use. They're a must have for a lowered car.
While you're not wrong about getting old and getting under the car, I'm personally freaked out crawling much further under it than the oil pan. It's some kind of claustrophobia, I'm guessing, but a relatively mild one.
Off topic, but if you want to see some crazy claustrophobic space, google "lemon squeeze at Mohonk Mountain House". It's an old luxury resort in New Palz, NY. And the Lemon Squeeze is a crazy trail through the rocks. Emerging at the top outcropping is super rewarding. I honeymooned at Mohonk 27 years ago.
Old Sep 17, 2025 | 02:19 PM
  #10535
rotarymike's Avatar
rotarymike
Moderator in Moderation
Before I came down to CHS for grad school I was a coop member for an SCCA garage that had a lift and all the bigger welders, tire changing/balancing machines, presses, etc. and it was glorious.
I do NOT gracefully lay on the concrete under a car on jackstands any more.
Old Sep 17, 2025 | 02:24 PM
  #10536
rotarymike's Avatar
rotarymike
https://saxontours.com/blog/tisa-roc...gq0f5HdQaB5UQ-
or my personal limit, widebody commercial aircraft fuel tanks (the wings). Did this work for years.
Old Sep 17, 2025 | 02:58 PM
  #10537
JZ39's Avatar
JZ39
20 Year Member
I think I did my FX50 headlight restoration a few years ago and it’s still perfect to this day. Really amazing stuff.
Old Sep 17, 2025 | 09:44 PM
  #10538
hexotic's Avatar
hexotic
DIY Cheapskate/Mod
I used the Griots garage restoration kit with the ceramic wipe at the end that magically makes the lenses hyper clear. Its still looking good 3 years later.
Old Sep 18, 2025 | 08:10 PM
  #10539
socketz67's Avatar
socketz67
Community Builder
I am a vet, so I have access to the lift/tools on the base that's 15 miles away; you need to schedule the time, so that always makes me nervous because I am not into racing through things and like to "piddle" once I'm engaged.
As such, I still just prefer to do everything in my garage. Laying on the concrete, sore shoulders and neck in the morning :-)
Old Sep 22, 2025 | 09:20 AM
  #10540
rotarymike's Avatar
rotarymike
Same, same distance away. And we have to get a new visitor pass every time we access the base, so add 1.5 hours to your trip for them to run NICS every darn time you show up.
I'd suck it up, with a combo of ramps, real garage jacks, and truck jackstands I could still get things done. However - I have no level spot in the driveway and the G won't fit through the garage door, so...
Always some excuse, it seems.
Old Sep 29, 2025 | 07:33 AM
  #10541
CRiME's Avatar
CRiME
I have the utmost respect for you, Mike. I am now 42 years old but I have been fascinated by aircraft since I was a kid. Was not until I got older that someone told me the primary fuel tanks are in the wings. Did some research and found that a 747 can hold about 57,000 gallons of fuel. My jaw dropped. I said to myself "how, and where?" LOL. And then, of course, I asked myself "I wonder if there is a guy that has to go in there for maintenance. And now I have found that you were one of those guys. Thank you for your service.
Old Sep 29, 2025 | 09:10 AM
  #10542
rotarymike's Avatar
rotarymike
You reek of jet fuel for days LOL, even through a bunny suit.
And the VA says I was never exposed to jet fuel as part of my job... sigh. Never mind the pictures of me soaked in it.
Old Oct 2, 2025 | 06:37 PM
  #10543
thescreensavers's Avatar
thescreensavers
So my battery was completely dead the other day, I have a jump pack and cables in my trunk out of arms reach laughing at me. So with no way to open the trunk I was stuck at home till wife came home. Adding a long ziptie solves the issue with opening the trunk you can reach it from the pass through.
I got a new battery, and we are back in business but my dead battery plan failed but now I'm prepared for next time!
Old Oct 3, 2025 | 05:00 PM
  #10544
socketz67's Avatar
socketz67
Community Builder
So you fished the zip tie with a small loop in it through the passthrough? Interesting. There was a guy on Reddit recently asking for something similar. I think I recommended one of those wooden or plastic back scratchers as the end is hooked and can be used to yank that lever down.
Old Oct 3, 2025 | 05:17 PM
  #10545
thescreensavers
I added the ziptie after my debacle, it's really up in there I feel like even with that I probably wouldn't be able to open the trunk hah
