Old Aug 4, 2025 | 12:11 PM
  #10486
2010sedanS's Avatar
2010sedanS
Thank you very much!
Old Aug 4, 2025 | 03:47 PM
  #10487
socketz67's Avatar
socketz67
Community Builder
Originally Posted by JZ39
So that explains why I couldn’t find the Stoptech rotors that I’ve been using for years. I guess they used this opportunity to redesign their rotors and we’ll see if they are any good. Sad when stuff like this happens.
StopTech really fit nicely into that middle spot between OEM replacements and Powerstop on the low end, and the high end rotors with painted hats and unnecessarily expensive steel. Then there are the two piece rotors that cost as much as a new short block.
I just turned my StopTechs that are 4 years old and combined with the EBC Redstuff pads, they bite like a rabid dog.
I called EBC this morning to discuss the excess dust and complex bedding process I've read about online, and they said that bedding process people describe is not needed unless you will be immediately tracking the car. The dust is the bedding material, which should wear down by about the 300 mile mark.
If you look at the rotor pic below, you will see the bedding material starting to attach itself.
Old Aug 6, 2025 | 10:08 PM
  #10488
Daddy Fat Sacs's Avatar
Daddy Fat Sacs
I'm curious as to what you think about the sound and performance of the single outlet setup. I have never been a fan either, but SOHO built a custom exhaust for their new Z and discovered it performed as well or better than dual outlet, and also sounded better and less prone to rasp. I believe they also make an insert for the other side of the rear bumper so it looks more finished.
https://www.youtube.com/watch?v=1A9Vd1qP1Kk
so now that’s it’s been on for a while and I’ve had some more seat time I can honestly say it has a very close Motordyne-ish sound. Nice deep rumble. Granted I’m still on stock cats, but I absolutely love the sound. There is a bit of drone around 3-3500k rpm range would be my only gripe.
The single exit visually still hasn’t grown on me tho
Old Aug 6, 2025 | 10:18 PM
  #10489
mummy2's Avatar
mummy2
Originally Posted by ctng37
It was not stated on the listing I got it from, but the part number seems to be T99L17LG0A. I think as long as it's a 10-pin connector (our cars have 3 wires for constant and ignition 12V and ground. The rest are for other features our car doesn't have), and came from a Nissan/Infiniti (for the windshield mounting), it should fit.
Y'all can also grab the aftermarket Gentex frameless mirrors. I've had mine for years. I have the Home link and compass model. As far as I can remember, you might have to tap 3 wires. Constant, power, and ground, then tuck the wires behind the headliner.
Old Aug 6, 2025 | 10:21 PM
  #10490
Daddy Fat Sacs
Couple small details last weekend:
CF wheel
brushed black steel *****
oem GTR dome light lenses
Old Aug 7, 2025 | 06:42 AM
  #10491
JZ39's Avatar
JZ39
20 Year Member
Nicely done! Man, my audio and AC ***** were on tight when I swapped them out - had to have faith and just keep yanking! Such a big improvement.
Have you swapped out the bulbs to LEDs - looks like it.
Old Aug 8, 2025 | 12:21 AM
  #10492
Daddy Fat Sacs
Yea all lighting is led. That’s the way I felt back in the day with my Carsmo ***** on these. This go around was easier
Old Aug 8, 2025 | 08:05 PM
  #10493
JZ39's Avatar
JZ39
20 Year Member
Project Cosmetic is officially done.
Just installed oem black mirrors and the final oem black door handle on the rear driver door.
Also installed the Stillen rear spoiler in black. Very easy install and great fit.
Just need to finish ceramic coating a few panels, restore the fog light lamps and the black trim on the front grill lower mesh.
OK, so Im not
fully done, but you know what I mean…
Old Aug 8, 2025 | 09:23 PM
  #10494
That's really interesting. I like what you've done.
Can't tell from these pics, but did you swap out your antenna cap for a black one?
Old Aug 8, 2025 | 10:31 PM
  #10495
JZ39's Avatar
JZ39
20 Year Member
Nope. The antenna is still blue.
At first, I only intended to do the front grill, emblems and spoiler in black or dark gray. My grille and emblems are actually dark gray as was the original eBay spoiler that simply didn’t fit well..
Then we got black caps for the handles just for fun, and they looked better than blue, but looked kind of cheap.. So this then led to getting all new KH3 handles, escutcheons and gaskets all the way around. Before all of this we had done blackout tape on the chrome trim, but that looked cheap, so we got new oem trim and had that painted black. At the same time I got a new set of fog light surrounds painted black and got those installed.
Now, as I started the project of replacing the door handles, it was so easy to take the mirrors off and since I had to get the new spoiler painted anyways, I gave them the mirrors to paint as well.
You know how it goes - one thing leads to another…But, I believe I now have no chrome except for the front emblem, so that is a very good thing IMO. I actually never intended to do so much black, but my son liked it and after all it is “his” car…
Old Aug 16, 2025 | 07:51 PM
  #10496
Daddy Fat Sacs
Carbon rear roof spoiler. Kinda liking this one over the old one
Old Aug 16, 2025 | 08:29 PM
  #10497
socketz67's Avatar
socketz67
Community Builder
My G35S had a single exit stock, and it looked nice. I think if there was a finisher of sorts to cover the unused exit on the diffuser, it may grown on me. Looks unfinished without one.
Old Aug 16, 2025 | 08:31 PM
  #10498
socketz67's Avatar
socketz67
Community Builder
I like that spot for Carbon Fiber as it is somewhat muted by the rear glass, which provides a level of integration with the painted surface.
Old Aug 19, 2025 | 03:58 PM
  #10499
rotarymike's Avatar
rotarymike
Moderator in Moderation
Drove mine again (!) and I have to say... I really like this car now that the tramlining is gone. Still have a clunk in the front which now I may be able to diagnose since it's become a single issue.
I think this weekend I need to take a stab at adding the VLine2 I picked up probably 20 years ago at this point (exaggerating) since 9/1 in SC we can't use phones for nav any more.
Old Aug 21, 2025 | 11:54 PM
  #10500
socketz67's Avatar
socketz67
Community Builder
How did you resolve the tramlining? Did I miss a series of posts somewhere? Been buried at work so its been tough to keep up.
