Old Jun 30, 2021 | 10:24 PM
  #8716
SupraOfDoom's Avatar
SupraOfDoom
I changed from Black open ended to Red. I'm quite happy with how much better they look to me.
Old Jun 30, 2021 | 11:03 PM
  #8717
Lugnuts are very attractive, what with the center cap and calipers.
Old Jul 5, 2021 | 02:07 AM
  #8718
AnotherVQ's Avatar
AnotherVQ
On the 3rd of July I got a rear brake pad change and new retrofit headlights.
Headlight info:
  • New OEM assemblies with paint job
  • Osram CBB
  • STi-R Clear Lenses
  • Diode Dynamics 90mm HD Switchback Halos
  • Diode Dynamics Cool White parking lights
  • VLEDs V6 Triton Extreme Amber blinkers
I'm going to upgrade the rotors and pads so I bought cheap pads and left the rear right rotor how it is in the picture.
Headlights:
Remote start: https://i.imgur.com/XkJPvbP.mp4
Spoiler
Brake rotor and pad:
Spoiler
Old Jul 7, 2021 | 01:37 AM
  #8719
PhatherPhish's Avatar
PhatherPhish
Today I began installing Z1 differential bushings, so I ended up staring at the rear subframe for about 2 1/2 hours.
Went through an entire air hammer chisel
Got them out though
Attached Thumbnails What did you do to your Sedan today?-3ef55000-d2b8-41cc-8fcd-7581afd43559.jpeg
Old Jul 7, 2021 | 10:03 AM
  #8720
BoomerSpeed01's Avatar
BoomerSpeed01
Originally Posted by ChefMatt
Installed shifters this morning, they look great behind the flat bottom wheel.
I know this post is about the paddle shifters, but I absolutely love that steering wheel!!
Where has good quality parts for the chrome stereo *****?
Old Jul 15, 2021 | 12:56 AM
  #8721
AnotherVQ's Avatar
AnotherVQ
I replaced my old Scosche charger with this one:
The old one had multiple issues:
  • Too small for my new phone. Old phone was V30+, new is S21 Ultra. This caused it to droop easily, especially when hitting a bump too hard.
  • Foam pads kept coming off, even after trying to glue them back on. The way it's made makes it difficult to really glue them back on well.
  • It was very annoying trying to get the clip adjusted just right to the point it holds the phone securely but it's easy enough to take the phone out, and as a result that's how the foam pads got messed up (hitting bumps too hard while it was securely holding phone).
For that reason and because this is the only other option made for the proclip I have, I am trying the one that automatically grabs the phone.
I'm not 100% sold on it now that I have it, and it's difficult to hardwire this with the things I currently have down there unless I want to connect the USB cable to the Garmin adapter I have hidden away near the BCM.
I'm probably going to just leave it like this, because I don't need anything in that area with the cigg lighter, the new adapter is very small and actually fits in there and tucks away well, and even if I get a custom mount for AirLift in the future I can just get one that has a 12v socket on it.
I did buy a right angle USB C adapter and a 6" USB C cable to replace the really long cable with a right angle termination which was included with the charger. Now it looks a lot neater than having a long cable hanging around and I didn't have to ziptie it up and leave it hanging behind the charger.
I also replaced the cabin air filter.
Old Jul 16, 2021 | 11:16 PM
  #8722
hexotic's Avatar
hexotic
DIY Cheapskate/Mod
Finally got a retune. The motordyne intake manifold really shows with that gradual drop off starting above 5200. It gives that kick down low and in the mid, where it matters in my opinion.
Made power across the curve. Picked up 50b-ft at 2950 rpm and 20 HP. The uprev ARC features are a little silly, but the rolling launch control is very welcome, and the rolling antilag launch is just fun. 301 AWD ponies is more than enough to have a blast.
Top is the old tune with just ypipe back exhaust and short rams. Note they start and end at different RPMs. I asked for a more conservative tune with the new upgrades, so I'm sure there's a bit more that can be squeezed out, but I'm not trying to set any records here lol.
Old Jul 16, 2021 | 11:57 PM
  #8723
iCrap's Avatar
iCrap
How does launch control work on the auto AWD? brake stand? and what does rolling launch actually do?
Old Jul 17, 2021 | 12:05 AM
  #8724
hexotic's Avatar
hexotic
DIY Cheapskate/Mod
Oh, I misworded that. It's like a rolling launch, and then there is an anti-lag-sounding launch if you hold down the cancel button. To launch from a standstill though, I normally brake hold. I don't like to launch it too often.
I fixed it.
Old Jul 17, 2021 | 05:27 PM
  #8725
STownSaint's Avatar
STownSaint
Knocked out the shift boot and **** install, big thanks to RMB5190 for the muscle, moral support, and vice grips.
This was me as a passenger in his 6th gen Mustang:
The result: OEM 350Z shift **** in black (the base of the **** is exact same shape and size as the G35/37 one) and Redline shift boot in black suede (3-panel). Also had to cover the shifter bezel in 3m brushed metal vinyl to hide the shift pattern. Overall very happy, kept a factory appearance, no more plasticy shift boot making noises during long road trips, finally the shift pattern is on the **** itself (where I’ve always preferred it), and to me the black gives the cabin a nice contrast.
Old Jul 19, 2021 | 07:55 AM
  #8726
RMB5190's Avatar
RMB5190
Two dudes grunting in a small cabin over a ****...one working the base while the other took care of the head. We struggled but in the end....got it off.
Magical
Joking aside, the stock shifter was a d.ck. Enough loctite to hold a NASA rocket together. Turned out super clean though; the black ties in with the other colors of the center console. OEM Z **** was a good choice; retained the OEM look but definitely a solid upgrade compared to the stock shifter.
Ha ha! The Mustang rolls out! Not sure if you're scared or having fun... More than likely both but it sure is addicting going WOT in that car.
Old Jul 19, 2021 | 09:38 AM
  #8727
BULL's Avatar
BULL
Moderador
I'm sure a ported HR plenum would yield closer numbers up top or is the one you installed ported?
Old Jul 19, 2021 | 09:46 AM
  #8728
That turned out a whole lot better than my initial pessimism was predicting, black on stone and all that. Well done. Particularly the detail with the matte silver wrap on the bezel.
Old Jul 19, 2021 | 10:14 AM
  #8729
hexotic's Avatar
hexotic
DIY Cheapskate/Mod
It's the motordyne one, it's a ported HR manifold. A VHR one would give more up top, another 20 HP or so, but I would lose about 15 in the mid. I prefer it this way. Plus, this lets me run a single catch can.
Old Jul 19, 2021 | 10:29 AM
  #8730
BULL's Avatar
BULL
Moderador
SO a plain HR manifold would make the VHR suffer. I totally get your point of view, VHRs are useless under 4k rpm which.
I can just imagine a motordyne VHR auto on a 3.69 rear tuned, would make city driving really interesting. (I know you're AWD)
