SEDAN | Official Aggressive Offsets & FAT Tires
Old Dec 2, 2017 | 06:26 PM
  #331
Coltrane1's Avatar
Coltrane1
Originally Posted by projectpanda13
I just sold sold the Forgestar CF10 in favor of these SSR MS1. These are heavier but I am willing to sacrifice the weight for the look. The tires were already on there and aspect ratio is too small. I’ll ride on them for a bit before changing them.
19x9 +24 on 245/35
19x10 +29 on 275/30
Rears needed a 5mm spacer to clear the calipers.
Fronts needed a 10mm spacer but currently has 20mm spacer on.
Congrats PP13! Those SSR's look really nice! The colored inserts matches really well with the wheat colored interior!
Old Dec 4, 2017 | 10:22 AM
  #332
dmudd's Avatar
dmudd
18x9.5 +38 Weds SA15R, 265/40 Bridgestone Potenza S04 Pole Position. Still need to lower the front a tad bit more.
nice setup. I couldn't figure out what I loved about the look then I noticed you got you window trim wrapped. looks great.
Old Dec 4, 2017 | 07:24 PM
  #333
guy from norcal's Avatar
guy from norcal
19x9 +24 on 245/35
19x10 +29 on 275/30
You made a good choice with those SSR wheels.
Old Dec 7, 2017 | 04:02 PM
  #334
future62's Avatar
future62
Man I need to see a G on aggressive 18s in person. I think I will go that route next time, though my 19s ride pretty smooth.
Old Feb 4, 2018 | 08:47 PM
  #335
Speedylifsavr's Avatar
Speedylifsavr
20x9 front +30 with 245/35/20
20x10.5 rear +45 with 285/30/20
Old Feb 5, 2018 | 08:04 AM
  #336
future62's Avatar
future62
More pics speedy, you nailed that fitment
Old Feb 26, 2018 | 12:20 AM
  #337
adooma's Avatar
adooma
Offset gurus, need some help. I bought some VSF2s in 19x9.5 +28 / 19x11 +45 .. I understand the front won't be an issue but will the rears fit without rubbing? I Have a Sedan and understand there's less space for wide wheels. Also I'm on swift lowering springs with nothing else.
What Vossen and the dealer told me is that they should fit fine but looking through threads i feel like there might be an issue.
If they rub will a camber kit be enough? Would i have to get my fenders pulled? Would the +45 make them hit the inside by the springs possibly?
Should i just sell them while they're new or try to put some 275s on them and get them on there?
This is only going to be my summer set up so with a camber kit could I put my winter rims back on with the camber kit with no issue?
Old Feb 26, 2018 | 08:43 AM
  #338
Should be ok w/ 275s, fronts are quite aggressive too, both should tuck running 245/40 & 275/35 but you may have to run a bit more camber. I fit 295s inside the fender on 10 +45 (with camber only at -1.0) so theoretically a 275 would only run about 2mm more to the outside on a 11 +45. Only caveat is some tires run wider than others. If you aren't opposed to running camber in the -2 range they should tuck. Front fenders can be flat-rolled (like your rear fenders are already) for more clearance.
If you look at the first page in this thread Tbulsara and MylilG are running 10.5 +35 to +38 on 275s and they fit ok, your 11+45 actually has about 2 to 4mm more room at the fender
https://www.myg37.com/forums/brakes-...post-here.html
Old Feb 26, 2018 | 10:12 AM
  #339
adooma's Avatar
adooma
Sounds great blnewt! You're always available to help when no one else is.
Im thinking of adjusting the rear camber as negative as I can with the oem adjustablity and then if needed I'll purchase a camber kit
Old Mar 29, 2018 | 09:16 AM
  #340
Clynt405's Avatar
Clynt405
wheels
This is dope
Old Jul 7, 2018 | 12:37 AM
  #341
18csmartinez's Avatar
18csmartinez
Clearance on fenders
Originally Posted by ToXIc
quoted from original thread
I also have 20x10.5 with +35offset in rear. I plan on dropping with eibach pro kit. My question is did you have to modify the rear fenders? Mine seem like they stick out more than yours. I also have same size tires 275/30/20. Your response is appreciated thanks.
Old Jul 7, 2018 | 12:46 AM
  #342
18csmartinez
I have the same set up as you on wheels and tires. I plan on lowering with eibach pro kit. My question is did you have to modify the rear fenders to clear the tires? Your response is appreciated thanks.
Old Jul 9, 2018 | 04:14 PM
  #343
2GoRNot2G's Avatar
2GoRNot2G
Depending on what rear camber you want to run you should be ok with 275 tires on the rear. I have 20x10.5 with +37mm offset and ran as wide as 285's on the rear without rubbing or fender mods. I did have to run around -2.5° camber in the rear with the 285's and slightly less with 275's, so you'll probably need to run around that too. I'm now running 305's on the rear with the rear fenders widened nearly 1.5".
Old Jul 11, 2018 | 09:18 AM
  #344
Trialmountain's Avatar
Trialmountain
That looks great!
Old Jul 19, 2018 | 01:17 PM
  #345
strodda's Avatar
strodda
Originally Posted by hexotic
Took the wheel decals off. Was too much for my liking.
I know this is an old pic/post, but I suppose it makes my question more relevant. But first, it looks awesome. Sits perfect for my liking and I love some meaty tires. My question is, how do you like the Swift springs and did they settle in any after some time had past?
