Drivetrain Reviews of clutches, gear mods, diffs, axles etc..
Review TWM Short Throw Shifter (STS) and Z1 Transmission Mount
Old Jun 20, 2016 | 08:14 PM
  #196
PG-v36_6MT's Avatar
PG-v36_6MT
Interesting...
Could that rusted doohickey on the left be one of them?
Old Jun 20, 2016 | 08:48 PM
  #197
Lego_Maniac's Avatar
Lego_Maniac
That looks right. I didn't notice one on the passenger side though, and mine wasn't rusted like that.
Old Jun 20, 2016 | 08:52 PM
  #198
Now that you're reposting that pic, I'm reminded of the WTF-is-that? reaction I had when you first did this.
I would have to get back under my car to look, but I don't recall seeing anything like that the last few times it was up on the lift. When I saw that picture, I just shut up thinking it was maybe something different between the VQ35 and the VQ37.
That's a damper? Like how? What kind of material is it? You'd think if it was a solid damper, then it would be rubber... like the shot-glass sized rubber dampers on the OEM exhaust.
Old Jun 20, 2016 | 09:01 PM
  #199
slartibartfast's Avatar
slartibartfast
Adding mass will change vibration frequencies. Can't tell if it's for passenger comfort or trans case longevity.
Old Jun 20, 2016 | 09:30 PM
  #200
Lego_Maniac
It's hidden by the transmission crossmember, so it would be easy to miss.
Old Jun 21, 2016 | 12:23 AM
  #201
SonicVQ's Avatar
SonicVQ
I'm surprised at how loud it is. Maybe too loud. I'm not sure yet. It's not like an exhaust, where you can get into 6th on the highway and things settle down. It's always loud. 85 on the highway is just loud.
Could you post a video or audio file that captures the noise? I would like to hear what it sounds like.
Old Jun 21, 2016 | 12:25 AM
  #202
SonicVQ's Avatar
SonicVQ
True... My G37 has the "dynamic damper'... this is a steel mass connected to some rubber that is designed to vibrate/oscillate 180 degrees out of phase, which cancels the vibration of our large displacement V6.
Old Jun 21, 2016 | 07:25 AM
  #203
Lego_Maniac
Does anyone still have the instructions for the Z1 mount? What are the instructions to replace the bushing? Is there a model or dimensions? I can't seem to find a download.
  1. Rebuild able design - In the UNLIKELY event that your Z1 Motorsports 370Z/G37 Urethane Transmission Mounts require servicing and the replacement of the bushing inserts, simply follow the supplied instructions and replace the bushing. The Z1 Motorsports 370Z/G37 Urethane Transmission Mount will be the LAST transmission mount your 370Z will ever need.
I wonder if there are other durometer bushings available from Energy Suspension that could be swapped in. The Z1 is 90A durometer
Old Jun 21, 2016 | 06:46 PM
  #204
Lego_Maniac
Removed it as soon as I got home from work today . Probably not the best idea because everything was HOT
If anyone wants a deal on it, pm me.
Old Jun 21, 2016 | 08:01 PM
  #205
Wow. Well, at least it's an easily reverible mod. Still... Glad I didn't bet on you, Lego. I would've lost that wager. Even worse, I would have given odds, too.
All these people unmodding the transmission mount... I imagine 4DRZ and I looking at each other thinking, WTF? But hey, props to everyone who tried it anyway.
Old Jun 21, 2016 | 08:21 PM
  #206
Lego_Maniac
I was thinking about that.
4DRZ tracks his car in a much more regular basis than most people here. I suspect he has a huger tolerance for NVH.
As for you....I suspect it's because you don't drive your car as much. You're at what, like 5k a year?? You mentioned not using your car that often for transporting the family, and IIRC, work from home, so you might be willing to take the extra NVH for the added stiffness.
For those of us that want/need to use our car on a regular basis for families, or have to slog through a daily commute, it's a different balance.
Old Jun 21, 2016 | 09:24 PM
  #207
All true, and a reasonable explanation.
The common theme between you and the others is an immediate appreciation for the NVH, but with a nagging discontent that grows and ends up taking over. I can't explain it, but instead of a growing unease, the NVH just became normal to me. I genuinely like it. I'm probably at the mid-point of ownership with my car now, and there's a real good chance I'll be installing Z1's urethane engine mounts sometime in the next couple of years.
There is no right or wrong. It's just a car.
Old Jun 22, 2016 | 03:23 PM
  #208
Waste86's Avatar
Waste86
I come from the coupe and I think you will be happy. I have both trans and motor mounts in urethane from Z1 as well as whiteline diff bushings and the NVH isn't that apparent to me. I daily my car and it hasn't once bothered me. Everything just feels much tighter and not so sloppy.
Old Jun 24, 2016 | 02:48 PM
  #209
4DRZ's Avatar
4DRZ
As I get older I am finding that my tolerance for NVH as not nearly as high as it used to be. I think the trans mount NVH also has a lot to do with the exhaust you have. With my Stillen exhaust it was only slightly louder with the trans mount. I honestly cannot tell any difference with the trans mount now. I think if you had stock exhaust and a stock suspension it might feel a little harsh or loud.
Old Jun 24, 2016 | 02:49 PM
  #210
4DRZ's Avatar
4DRZ
Did you notice more NVH added from the Z1 trans mount or motor mounts? I have the trans mount now and considering the motor mounts to take out some more slop in the driveline.
