The "4 door Z" build (4DRZ)- 13 G37S 6spd sedan
Old Nov 29, 2018 | 01:54 PM
  #931
4DRZ's Avatar
4DRZ
First drive today with the new snow tires on just a dusting of snow. I think the rear gears may make this winter interesting. I spun the tires with very little throttle starting out. I may have to start exclusively in 2nd gear now. Time will tell how this works out once we get a real snow storm...
Old Dec 8, 2018 | 11:59 AM
  #932
4DRZ's Avatar
4DRZ
Well, I am still waiting for a good snow storm to test out these new snow tires. We got a couple of inches the other day but I didn't make it out before the plows. (DOH!) Since these new rear gears and soft snow tires amazingly allow me to break the tires loose in the 1st 5 gears (!?!) I think this could be interesting. I have a bad feeling that with the new rear gears the new snow tires will now work about as good as really clapped out snow tires. I really hope I am wrong about this.
Old Dec 8, 2018 | 12:04 PM
  #933
I think you're worries are unfounded. We have to deal with twice the annual snowfall you get, but then I don't drive mine in the winter as much as you, so it's hard to compare with forum comments.
Be gentle with the throttle, and you'll be OK.
Old Dec 8, 2018 | 12:25 PM
  #934
4DRZ's Avatar
4DRZ
Well, that sounds boring.
Old Dec 8, 2018 | 12:35 PM
  #935
That's true. But now that you've got a little one in your life, there's a whole new consideration to winter stunts. Stay safe.
I still don't think you answered the question about wheel hop with your snows on dry pavement. Kind of curious. My guess is you'll be hop-less, and the summer hop is those high-end summer tires.
Old Dec 8, 2018 | 01:16 PM
  #936
4DRZ's Avatar
4DRZ
I think the grip plays a part. When I was swapping tires and it was very cold (ie. summer tires were hard as rocks and not much grip) there did seem to be a bit less wheel hop.
Old Dec 10, 2018 | 10:37 AM
  #937
4DRZ's Avatar
4DRZ
The last time I had my car on the lift I sprayed some rust proofing underneath in anticipation of all the salt it will see this winter. I was surprised by how much surface rust was on the rear subframe, drain holes in front of the rear wheels, and jack points that got scuffed up again by being up on the lift multiple times this year. I sprayed some rust proofing on the jack points, but I am not sure how well that will hold up. It will probably get rubbed off the next time the car gets lifted.
Old Dec 16, 2018 | 10:34 PM
  #938
4DRZ's Avatar
4DRZ
I was at Advance Auto Parts today and picked up some free (coupons) Sea Foam. Has anyone tried this stuff? The guy there swears by it. He said the next time I change my oil I should put 1/2 a can in the oil, let it idle for 10 min. and then drain it. He said I would be surprised by how much gunk it pulls out of the engine. Anyone try that? It will be a while before I need an oil change, but I will probably be down to 1/2 a tank of gas and dump in the Sea Foam in a couple of weeks. I am curious to see if it makes any difference. I used Lucas Oil Injector cleaner a couple of times before and that seemed to help slightly.
Old Dec 17, 2018 | 12:29 AM
  #939
jpowersjr2's Avatar
jpowersjr2
Sea Foam is amazing. Used it on several vehicles.
Old Dec 17, 2018 | 10:27 AM
  #940
Baadnewsburr's Avatar
Baadnewsburr
I used it once about 80k miles ago ..its wasn't bad, the smoke show was quite short though, but definitely seems to burn something off...might be because I kept up on regular maintenance anyways...I have one sitting in the garage and have been meaning to run it through sometime soon but I've been too busy ...I'm assuming it might have a greater effect now that I'm at a much higher mileage...i almost feel like its a good way to check for exhaust leaks at the very least so worth it
w
haven't tired the Lucas injector cleaner but have tried the redline equivalent twice in the last 30k miles...didn't really notice a difference...I have a bottle of Techron in the car I keep forgetting to dump in too
Old Dec 17, 2018 | 10:55 AM
  #941
I ran Seafoam through the upper engine on my old Maxima. The billowing white smoke that filled the neighborhood... that was epic. Didn't make my car run any better or worse afterwards, and truth is it was running fine when I did it. At the time, there were a number of Seafoam conversations going online, and I got looped into doing it. I think conversations like that are typical in an group discussing an 8 year old car.
I didn't do the oil mix, however. I'm interested in reading what you do here.
Old Dec 17, 2018 | 11:35 AM
  #942
4DRZ's Avatar
4DRZ
Well that's interesting. Did you guys get a ton of smoke after you put sea foam in the gas tank?
Old Dec 17, 2018 | 12:21 PM
  #943
IIRC, it was 2/3 sucked into the upper engine, and 1/3 in the tank. The smoke was all from the intake.
Old Dec 17, 2018 | 12:41 PM
  #944
4DRZ's Avatar
4DRZ
Hmm... how did you go about dumping it into the intake?
Old Dec 17, 2018 | 01:07 PM
  #945
I had to really step back and think about this. It was a while ago.
The Maxima has a Variable Air Intake System. To support the VIAS, there was a vacuum connection off the intake used to actuate a large butterfly valve separating the two-shelf, aluminum upper intake manifold (UIM). I ran a section of hose from there to the driver seat, where I could meter how much Seafoam I was sucking in, while also maintaining some throttle pressure so it wouldn't stall.
