The "4 door Z" build (4DRZ)- 13 G37S 6spd sedan
#781
Made me think, so I went and measured my hockey puck. (That sounds so stupid, LOL.)
Yeah, this thing you found, this Super Puck , it's better. I want one.
Have you used it yet? An-n-n-d, Whoops! For $5.49 Amazon Prime... I just bought it.
- Same diameter, at 2.8".
- However, the hockey puck is 1.0" high, whereas this is 1.3"... which would give me better clearance seated in the middle of the jackstand bowl.
- My puck is also less deep and less wide... which is an annoyance I've never done anything about.
#783
I did the Amazon Prime thing too because it was cheaper than a hockey puck and a lot less screwing around trying to cut up a hockey puck.
I have used it a few times and it is great. The cutout could actually be a touch deeper, but then again, maybe it is good where it is at so that the pinch weld takes some of the weight.
It is easier to line up the jack pad adapter with the pinch weld and then put the jack under it and bring it up to it rather than trying to line up the jack pad adapter by pumping the jack with the pad adapter sitting on top of the jack.
Rochester (06-11-2018)
#784
Looking forward to it.
The way I see things with this Super Puck... I spent a year talking you into your rear gear upgrade, until you finally spent over $1500 on a what must have been a nerve-wracking decision for an awesome mod.
So, now we're even.
[edit]
Bought it. The material is too soft, making it really easy to rip it up.
Hard pass. Genuine hockey puck, FTW.
So, now we're even.
[edit]
#785
Ugh damnit. Seeing your pinch welds/jack points all nice and clean makes me want to bend mine back straight. I gave up on mine a while ago, even with the puck (of which I have two).
I have a red TBW undershield. It still uses the clips, and I'm wondering if the rivets are really any better.
#786
The metal rivets definitely provide a much more solid attachment point. Now I also don't have to worry about the original plastic pop rivets breaking every other time I remove them. The ones on top of the radiator are even more fragile.
#788
When you were doing this, did you consider black instead of white?
#789
I have black rustproofing spray that I also plan to use in some areas underneath, but the jack points were originally white so it looks OEM. Especially since I painted a bit beyond the jack points into other areas that were white and needed it. Black would look pretty strange there when it is up on a lift.
4DRZ (06-16-2018)
STownSaint (06-26-2018)
#792
Hot damn! That's exactly what it's like when I drive my girls to school!
JK JK. You're clearly braking more aggressively, and driving better overall, than those two Vettes. Just goes to show how straight-line power is only part of the game. Very impressive, 4DRZ.
Do chicks dig guys with driving skillz? You seem to have it going on.
4DRZ (06-21-2018)
4DRZ (06-21-2018)
#794
Not gonna lie, was fully expecting one to “pick up its pace” outta pride and park it somewhere unintentionally. Not that I wish bad things to happen, your driver training comment put me down that path.
Nice smooth lines sir.
4DRZ (06-21-2018)
#795
You guys are right- being able to pass Shelby Mustangs, Corvettes, and M3's at Road America is not something my car would normally be able to do, especially with the ultra long straights. However, with the right work on the car (and I think more importantly on the driver) we make miracles happen.
