My RB Project, going all in!
Sam, I learned that there is a 4.36 ratio available for the Frontier. We all know about the 4.08's.
Now... does that fit in the manual diff housing because it may have a larger outer gear? I dunno.
That said, I sure wish I knew WHY we have to switch diffs. Apparently the gears 'won't fit'. Hah! I can imagine someone clever grinding a casting boss back and then getting the clearance. I wish I knew, but if I had the parts to compare it would be telling.
What a timesaver THAT would be. Someone who has actually seen the inside of the auto diff, PLEASE educate me?
(In my past careers as a tech, I made things fit that NEVER should have. Bingo!)
Coop
Coop
You can really tell the extended gears...he// how fast were you going by the time you shifted into 3rd!?!
Damn I love the sound of that motor....paired w/ Fast Intentions...ahhhhh~!!! Do you have the earlier Xpipe, or have you upgraded since? LMK, I'll look into seeing what I can do for you....
Coop
Coop
Otherwise I'll just grab me an R34 4.3 diff and have it customized to fit, this shop just loves custom jobs.
and that's with a 7k rev limiter! I don't even want to know where my 5th will take me lolMy current exhaust setup (like 90% of my G right now) is custom
. Starts with a 4" single down pipe, splits into two 3" via a y-pipe then into the 2.5" CF mufflers. I'm already bugging Tony to release 3" CF mufflers
It looks like I'm stuck with 4.08's. Z1 Auto confirmed 4.363 will not fit
Older skylines also came with R200 diffs with 4.3 option, will research that. I don't think 4.08's will do it for me.
I've tried it, it absolutely does not fit correctly. Further, that part # for the 4.3 was discontinued and no longer in production - no matter as it wasnt a bolt in replacement anyway (I know, I own one).
It seemed to be off by maybe 1 or 2 MPH. And yes... you can convert to KPH
I didn't know how the speeds are measured. All my past experience was through a transmission sensor, and I know yours had been changed.
Just put a speed reduction coupler inline between the driveshaft and the diff. LOL!
There, I fixed it!
Coop
There, I fixed it!
Coop
For a quick reference... If you have an iPhone or Android, download a GPS speedometer. I didn't have a speedometer on my truck for almost a year because the sensor went out. I used this until I knew how fast I was going based on RPMs.
Hi Sam
Congrats on an intense transplant!!
I'm new here and only joined because I have a concern about your catch can setup as it shows in one of you pictures.
It looks like you have both of you valve cover vent hoses going to a catchcan which is good but if that catchcan doesn't have a third port or an air filter/breather then you have closed looped the crankcase and you will pressurize the engine and cause seals to fail.
Which could explain the front crank seal leak you mention earlier.
Also I would like to pass on some personal experience with an oil leak from the front seal.
My engine developed a leak that would keep coming back everytime I wiped it away at idle front the front of the engine.
This lead me to pull the front crank seal and take some picture to see inside.
I found I had cracked the inner oil pump gear on my greddy pump.
I would hate to see all your efforts lost to this so I felt I needed to pass this on.
Good luck with the build and I hope to see some great updates.
If you want to see more of what I have done you can see it here.
http://forums.gtrcanada.com/gt-r-pro...t-freak-3.html
