Rochester's new G
Old Apr 27, 2018 | 03:13 PM
  #2176
ToXIc's Avatar
ToXIc
nice.. looks functional.
Old Apr 27, 2018 | 03:25 PM
  #2177
Lego_Maniac's Avatar
Lego_Maniac
I'd just be concerned it's going to get nasty after oh, say one use.
Old Apr 27, 2018 | 03:37 PM
  #2178
LOL, maybe so. I mean, the pad is designed to be used exactly this way. And apparently it's a common thing, sold everywhere, marketed as "Pad material resists engine oil, transmission fluid, coolant, brake fluid, brake cleaner, gear oil and other solvents."
But I'll believe it when I see it. Conventional wisdom says that I'm going to be hanging on to an oil-soaked pad forever and ever. And ever... hahaha.
So yeah, I've considered that, and plan on storing the pan somewhere other than where I keep the other one, because yucky.
Old Apr 27, 2018 | 11:40 PM
  #2179
4DRZ's Avatar
4DRZ
I also bought an oil splash pad that I fitted into the bottom. That might have been overkill but maybe not.
Those are designed to be used on oil catch cans where the oil goes through them instead of just sitting there soaking into them. You will solve the problem of splashing, but will create a much bigger mess when you try to pour the oil out.
Old Apr 28, 2018 | 12:42 AM
  #2180
Lego_Maniac
I use old cookie sheets to sit the pan on
Old Apr 28, 2018 | 07:56 AM
  #2181
Ah, right. In that case it's something better used for the top of my old pan. Guess I'll find out this afternoon. Going to change the oil on the Sentra today.
Hey, I'm not proud. If it's a fkd up, one-time solution, then I'm out $10 with a lesson learned. Or if it makes oil changes less of a mess, then it's a win.
Old Apr 28, 2018 | 12:38 PM
  #2182
guy from norcal's Avatar
guy from norcal
I think that's a great idea john.
Old Apr 28, 2018 | 01:32 PM
  #2183
Oil changes are hardly the stuff of legend, but changing the oil is all part of owning and caring for the car, and it's what I'm doing in the moment. Well, not specifically for the G this time, but I've got a new pan... and it's all car stuff.
Putting the little Sentra up on Race Ramps, locked down with my new wheel chocks, it looks kind of like silly overkill, but damn do those ramps give you a lot of clearance! Love these ramps.
What else... Oh, I know. The dealership that last changed the oil on this car just jammed on the wrong diameter copper crush washer, which was all torn up in the drain bolt threads. That kind of sucked, and took a while to pry loose. Oh, and the filter on the Sentra is *exactly* the same on one the G37. That was funny.
Anyway, on to the pan. First off, the open design worked out much better than the shallow top, hollow design. At least, in my opinion. And the pad worked perfectly. Not even a hint of splash. Probably not something necessary for the Sentra or the G, but certainly for the Subby.
Afterwards, during clean-up, the pan and the pad emptied nearly dry. IDK what kind of "oil resistant" plastic that pad is made of, but the oil literally drained out of it almost entirely. That was kind of weird, and unexpected from conventional wisdom.
So the pad is a keeper, and I'm just going to leave it in the pan, and store the pan out of sight under something, instead of on a shelf.
Old Apr 28, 2018 | 02:25 PM
  #2184
GdaddyNY's Avatar
GdaddyNY
Those splash pads are great. I bought them after having an Exxon Valdez type accident in the garage. I haven’t had issues since
Old Apr 29, 2018 | 08:42 AM
  #2185
SomeName's Avatar
SomeName
Lol my wife's last car was a Subaru. They have famously large drain plugs. I have a similar catch pan. The only thing I can recommend is bending up a coat hanger to drain the filter. Something like this. It ain't pretty but sure is useful. Okay I hope the pic get resized somehow cuz it looks huge on my phone.
Old Apr 29, 2018 | 08:26 PM
  #2186
4DRZ's Avatar
4DRZ
Glad that worked out. How did you keep the pad from falling out when you poured out the oil?
Old Apr 29, 2018 | 08:35 PM
  #2187
Just never tipped it beyond upright when draining. Propped up the pan and let it drain into the jug for a while, and the pad was relatively oil free.
I hear ya... not really what I was expecting either, but figured $10 was a cheap experiment, and it seems to work really well. Honestly, it's overkill for the Nissan and the Infiniti, but it was the Subaru that made me want to eliminate splatter. The Subby's next OC will be in a couple months.
Old Apr 29, 2018 | 08:39 PM
  #2188
Actual G News... car gets a NYS Inspection this Friday, and another diagnosis for my rear suspension noise. I strongly suspect I'll be having the OEM rear dampers re-installed sometime after. Can't imaging what else it could be.
Old May 5, 2018 | 07:30 AM
  #2189
Had a NYS Inspection yesterday. Passed, at 37k miles, as it should have... aftermarket cats notwithstanding. The shop also spent a lot of time (I was there) reassessing their diagnosis on my rear suspension mystery noise.
The #1 takeaway is that everything is solid, functional and safe, so there's that. As to the noise, this time around the whole shop came to the conclusion that it was coming from the right rear damper. The inner seals have become squeaky, and that's that. Curiously, with really warm temps this last week, the noise has significantly reduced. That isn't was I was experiencing last year, but it seems the problem is evolving as it ages.
So with the lessened intensity, and the assurance that everything is firm and functional, my motivation to "fix" it is tamped down. I think later this year I'll have my original Tokico dampers swapped back in.
Old May 5, 2018 | 09:02 AM
  #2190
Lego_Maniac
Do I recall correctly Tein already replaced one of the dampers?
Flipping back to the OE shocks would be a cheap and easy solution if it works.
