Old Nov 2, 2017 | 07:13 PM
  #901
Bionicman's Avatar
Bionicman
That should be fine, 19x8.5 +45 is not very aggressive and you shouldn’t run into any clearance issues inside or out. For reference, I’m running 19x9.5 +35 on all four corners.
Lookin good! What size tires are you running?
Old Nov 2, 2017 | 08:24 PM
  #902
the93owner's Avatar
the93owner
245/40/19 all around
Old Nov 3, 2017 | 08:40 AM
  #903
Bionicman's Avatar
Bionicman
I must say, in browsing 60 pages of wheel/tire setups, I was pretty surprised to not find a single example of 19x8.5 wheels with 255/40-19 tires. It seems that most folks here have chosen to stretch narrow tires onto wide wheels.
Old Nov 3, 2017 | 10:02 AM
  #904
future62's Avatar
future62
I have 255/40 on 9.5s... I wish I had gone with 8.5s. I would recommend doing that... just make sure you have a nice offset. 8.5 at +20-25 lowered is about ideal IMO.
Old Nov 3, 2017 | 10:14 AM
  #905
Bionicman's Avatar
Bionicman
Intriguing . . . are you running 18" or 19" wheels? and what's your offset?
Old Nov 3, 2017 | 10:18 AM
  #906
Bionicman's Avatar
Bionicman
I just spent some time discussing the matter with a guy at TireRack and he could guarantee fitment of the 19x8.5 (45mm offset) wheels I was looking at with a 245/40-19 tire, but NOT the 255/40-19 tire that I would really prefer. He stated that the rears would be no problem, but I may rub up front at full lock. I'm thinking I may need to get the car in the air and take some measurements if nobody has ever attempted this . . . or just go for it and add spacers up front if it's a problem.
Old Nov 3, 2017 | 02:31 PM
  #907
future62's Avatar
future62
I am running 19x9.5 with +25 in front (to clear BBK with spacers) and +35 out back. I am pretty low as well. It looked like it was going to rub but it didn't with stock camber out front and back. The wheels did poke out a good bit in front, but if you go with 8.5s at the same offset it will be just about perfect. And 255s will give you some curb protection.
Old Nov 3, 2017 | 05:28 PM
  #908
Here's one of the best fitments IMO, a 9.5 +40 on 255s all around
https://www.myg37.com/forums/g37-sed...ml#post4164814
Old Nov 3, 2017 | 08:21 PM
  #909
Rollo's Avatar
Rollo
I will likely go 255s on my next set of tires...stuck with the 245s this time because I had recently replaced the rears when I decided to go square. I am using 4 rear g35 rays that are 19x8.5.
Old Nov 6, 2017 | 07:57 AM
  #910
Bionicman's Avatar
Bionicman
Wow, I don't say this lightly, but ZahyMatar probably has the nicest looking sedan I've ever seen. The wheel / tire fitment is outstanding.
Old Nov 6, 2017 | 08:00 AM
  #911
Bionicman's Avatar
Bionicman
Good to know, thanks! Do you by chance know the offset of those wheels?
Old Nov 6, 2017 | 09:04 AM
  #912
The rear 19" G35 Rays are 19x8.5 +33 great G37 Sedan offsets
Old Nov 13, 2017 | 07:09 PM
  #913
pwntu's Avatar
pwntu
Hey guys,
I have OEM g37s 19's on my car and wanted to know the best tire setup. They are 19x9 all around, the rims are 4 rear's. Looking for a meaty setup, would 265 45 19 be okay?
Old Nov 13, 2017 | 07:50 PM
  #914
Originally Posted by pwntu
Hey guys,
That's going to be well over the 3% that's the recommended line to stay under. Those 265/45s are almost 6% taller at almost 1.75" taller than the baseline 245/40 size.
If you want to run 265s a 265/40 would be 2.3% taller and the 265/35 1.57% shorter, so those would work out quite a bit better as far as that diameter discrepancy.
Old Nov 17, 2017 | 01:38 PM
  #915
6spd_Hayes's Avatar
6spd_Hayes
6spd, welcome to the site!
Going to be a tough fit, the 10+38 in front will have very little room at the upper bend of the spindle. My 18x9.5 +38s have a bit more than a 1/4" clearance at that point, so you'd be right at it w/ the 10s. If they were 19s or 20s it would be a bit easier as that bend in the spindle gets further out as you get larger in wheel diameter. And 275s in front might need to have the front fender edge flat-rolled like the rear. You rear wheel won't be a problem at all though.
Check our site calculator, it's simple but accurate~the 18x7.5 +45 vs. the 18x10 +38 will result in 24.75mm more to the inside and 38.75mm out.
I went ahead and pulled the trigger...
Enkei NT03RR, 18x10+38 square. 19.4 pounds each.
Bridgestone Potenza RE-71Rs, 275/35-18
Project Kics R40 Neo-Chrome lugnuts.
I did wind up running a 5mm spacer up front, because the spokes touched the caliper. I am VERY happy with the setup, the lightness, and the new grip. These will be for race purposes only...
