Old Jul 14, 2016 | 11:05 AM
  #631
ChinkyChoy's Avatar
ChinkyChoy
Originally Posted by Rr1982
What is the max width and offset 19" square setup on a stock height xs Sedan?
depends on offset
Old Jul 18, 2016 | 06:40 PM
  #632
Rr1982's Avatar
Rr1982
depends on offset
Really? Hmmm
Old Jul 19, 2016 | 01:03 PM
  #633
GNTLMN_Z's Avatar
GNTLMN_Z
My current setup is staggered; 19x9.5+25, 19x10.5+45 with 245/40 and 275/35. My car is on air with -1.7f and -2.1r camber.
Now that that's clarified, I tested the rear wheels on front and the just barely hit the arms. A 5mm spacer pretty much cleared it up.
So for your question, you should be fine with 19x10+40. Since you're stock height perhaps look into a 19x9.5+35.
Personally, my next setup will be square with 275/35ZR19 all they way around on a 9.5-10" wide wheel.
Old Jul 19, 2016 | 01:55 PM
  #634
Rr1982's Avatar
Rr1982
Thanks for your valuable input!
Old Jul 19, 2016 | 04:29 PM
  #635
The problem w/ stock height is the wheel poke you will get when you run a bit more aggressive but would be fine if you lower it.
Here's an example
At Stock height
https://www.myg37.com/forums/wheels-...ml#post4052416
And lowered
https://www.myg37.com/forums/wheels-...ml#post4054631
So you're either stuck w/ poke at stock height or perfect fit when lowered, or you can run a more conservative setup that won't give you the aggressive fit that you want
Old Jul 19, 2016 | 10:31 PM
  #636
Rr1982's Avatar
Rr1982
Here's an example
At Stock height
And lowered
Very good info and pics! I was a bit more concerned about the rear of the wheel/tire contacting the suspension than a little poke out, and what width/offset would be safe,but that helps alot! Thanks
Old Jul 26, 2016 | 08:47 AM
  #637
Originally Posted by BrianG314
2011 G37xS with Niche Verona 20 x 10 +40 wheels all around with 255/35/20 Kuhmo Ecsta 4X II tires
Hey Brian, never replied to that post, looking like a nice fit, any plans to lower your G? A mild drop would really set it up well.
Old Jul 26, 2016 | 02:15 PM
  #638
evil-G-nius's Avatar
evil-G-nius
Damn those are 20's!? That wheel gap makes em look so small. Definitely needs more low. LoL
Looks good though, goes well with the body style
Old Jul 27, 2016 | 01:50 AM
  #639
BrianG314's Avatar
BrianG314
Thanks! I've kicked around the idea of a slight drop but I'm not sure at this point. Maybe if I can find a deal on some Swifts...
Old Aug 5, 2016 | 12:00 AM
  #640
Rr1982's Avatar
Rr1982
Does anybody know what exactly these wheels are she says they're not Q70 Wheels and then another video the same Wheels she says they aren't Q50 Wheels
Wheels although the heading says that they are Q50 or Q70
Old Aug 5, 2016 | 12:16 AM
  #641
It's funny the proportions on that pic, those wheels look HUGE, like 24s lol.
Those appear to be the base coupe 18" wheels, here's one on ebay for comparison
2008 2009 Infiniti G37 18" Wheel | eBay
Old Aug 5, 2016 | 12:22 PM
  #642
evil-G-nius
She is kinda cute but she is annoying!
It was apparently really hard for her to read the cards...I guess reading out loud is not her strong suit! LoL
Old Aug 12, 2016 | 05:14 PM
  #643
Mindows7's Avatar
Mindows7
Originally Posted by Twinturbo6
Tire shop didn't think I would be able to fit 245/45 and they didn't carry 245/40
I run that exact same setup lmfao, niche m157 19x9.5 +40 with 245/40/19 Pss. they fit perfectly and they dont rub at all. I actually put 15mm spacers up front and 5mm in the rear.
w/ spacers
w/o
Old Aug 12, 2016 | 05:22 PM
  #644
Mindows7's Avatar
Mindows7
Guess it's my turn to join~
Going from staggered 20s to lightweight 18s.
Wheels~Wedsport SA10R 18x9.5 +38
Tires~Kumho Ecsta LE Sport Max Performance Summers, these easily clear Akebonos too!
Love the setup. I am actually looking for some winter wheels atm and I was thinking of some 18's and this setup has me in love. what size tires? I was gonna pull the trigger on some rpf1's 18x9.5 255/45 or 265/45 but not im all over the place
Old Aug 12, 2016 | 08:04 PM
  #645
Thanks Mindows, those are 245/45/18s, but if I were to do it over I'd go w/ 255/45 or 255/40, there's enough room in front and the back even more. Depending on your offset w/ the RPFs you might even get 265/40s in there, I may try them in back when I'm ready for new tires and try a test fit in front on 265s then decide if I can run them up there too.
