Old Dec 25, 2015 | 04:12 AM
  #331
jee-sedan's Avatar
jee-sedan
I have a bone stock 2011X sport sedan with aftermarket 18x8.5 +32 wheels (square)... so is 245/45/18 the ideal tire for my setup? I like the look of the 245/40/18 better but it is around 4% off from stock, would that cause any problems other than the speedo being off?
Also, anyone have any pics of 245/45/18 on 18x8.5 wheels so I can see how the sidewalls look? Thanks!
Old Dec 25, 2015 | 09:24 AM
  #332
That's the stock rear tire size on all S sedans, here's a factory pic
Old Dec 25, 2015 | 01:10 PM
  #333
jee-sedan's Avatar
jee-sedan
Ahh that's right, I forgot the RWD sports ran 8.5 rears. Do you think 245/45/18 will fit with my 18x8.5 +32 offset wheels on all 4 corners?
Old Dec 25, 2015 | 01:31 PM
  #334
Mr_Mer's Avatar
Mr_Mer
Squared setup with 18x8.5 +43, on 20mm spacers on front, 25mm on back.
Eibach drop at the beginning of the year.
Old Dec 25, 2015 | 02:10 PM
  #335
jee-sedan's Avatar
jee-sedan
Mr_Mer are you running 245/45/18 ?
Old Dec 25, 2015 | 02:12 PM
  #336
Mr_Mer's Avatar
Mr_Mer
Indeed they are 245/45 R18
Old Dec 26, 2015 | 03:41 AM
  #337
evil-G-nius's Avatar
evil-G-nius
Well as you add spacers your offset will get less positive, so you'll be back to that +12 pretty easily, it's a quandary for sure
True. BUT, if I start inside the fenders, by adding spacers I can get closer to the flush look I want vs. being at a point where I am outside and have to worry about the fendres. I think that is the route I am gonna take. +22 with maybe 5-10mm spacer in front and idk..10-15 rear.
Old Dec 30, 2015 | 01:39 AM
  #338
t0nym4c's Avatar
t0nym4c
anyone running 19x9.5 et22 on a sedan? I'm going to run this setup in the future, but I am wondering if they'll rub. I'm going to be lowered on eibach springs. Will that be low enough to make them work?
Thanks,
Old Dec 30, 2015 | 10:11 AM
  #339
^^^^I'd shoot a PM to ChinkyChoy, those specs are real close to what he's run.
Old Dec 30, 2015 | 09:02 PM
  #340
Baby Jumpman's Avatar
Baby Jumpman
Depending on tire size they'll be pretty flush. I was running +20 offset on eibach springs and was pretty even with the fender but would tuck under compression.
Old Dec 30, 2015 | 09:36 PM
  #341
micafd3s's Avatar
micafd3s
rennen csl3 20x10
20 offset
245.35.20 tires
on eibachs
not flush..fronts more so than the rear..
does not rub with normal driving..
up for sale in the classifieds..
Attached Thumbnails HELP~All squared setups please post here!-20151230_104547.jpg
Old Dec 31, 2015 | 12:54 AM
  #342
ChinkyChoy's Avatar
ChinkyChoy
Thanks,
i am 3mm less aggressive and i sit flush on coils with 245/40 tires. you ll poke a little bit may have to run a 235 tire but like other have said will probably tuck under compression maybe some camber can help prevent rubbing
Old Dec 31, 2015 | 01:16 AM
  #343
t0nym4c's Avatar
t0nym4c
Thanks for all the input guys. I would like to run 245/40 tires with 22et. Maybe I should get my fenders rolled?
Chinky Choi
How low are you on coils? Eibachs are about 1.5 inches in the front. Hopefully you have a similar drop to that so I can gauge if this is a setup I would go with.
Old Dec 31, 2015 | 03:12 AM
  #344
Baby Jumpman
Only pic I have unfortunately, 245/40/19 on a 9.5 +20. You won't need to do any fender work.
Old Dec 31, 2015 | 03:37 PM
  #345
t0nym4c's Avatar
t0nym4c
thanks baby jumpman. Your sedan looks amazing!!!
