Old Dec 9, 2015 | 11:40 AM
  #301
evil-G-nius's Avatar
evil-G-nius
I do have the stock BBK that comes on the S coupe. But the coupe showed had the specs I wanna run square and I was told it was too aggressive and it would stick out from the fender. I am pretty sure the car I saw has the BBK as well and when I look at it it looks perfect! I don't want to say they have no clue, they are a vendor here, but I will be checking with other people about it for sure but I was curious if wheel design had something to do with it.
Old Dec 9, 2015 | 11:46 AM
  #302
ChinkyChoy's Avatar
ChinkyChoy
are you lowered at all? if not, then I retract my statement about them not knowing what they are talking about.
If you aren't lowered its going to look stupid
Old Dec 9, 2015 | 05:34 PM
  #303
evil-G-nius
I plan to lower. I wanted to get the wheels and everything in one shot. Simple drop on Eibachs
Old Dec 12, 2015 | 12:53 AM
  #304
t0nym4c's Avatar
t0nym4c
Anyone know if 19x9.5 15et will fit on a sedan or will it be too aggressive? I've been searching, but I couldnt find anything.
Old Dec 12, 2015 | 01:04 AM
  #305
ChinkyChoy's Avatar
ChinkyChoy
That's going to be an aggressive fit but can be done with stretch and camber.
Old Dec 12, 2015 | 01:26 PM
  #306
VQCrew's Avatar
VQCrew
Hey guys what you think about adding a 1 inch (25mm) spacer to square 19x9.5 +20s with 245 tires on a sedan?? You think just hitting it with some camber good enough? or am I gonna have to pull/roll? would that make the wheels same as 10.5 +20 right? I'm tryin to go even more aggressive for next season.
Old Dec 12, 2015 | 04:26 PM
  #307
Gregor12's Avatar
Gregor12
I think it would be similar to a 19x11.5 +20. I guess with enough camber anything will fit tho lol you're extending the front side of the wheel out 25mm so if you're trying to compare it to another wheel you'd keep the same setup (19x9.5 +20) and add (25x2)mm to the 9.5 width. A 10.5 inch wheel is an inch wider across so it would be like adding .5in to each side from the center. That would be a 19x9.5 with a 12.7mm spacer. Be careful what kind of spacers you use as well. Not something to cheap out on!
I am pretty sure this is how it works but I've been wrong before.
Old Dec 17, 2015 | 08:49 AM
  #308
Suubes's Avatar
Suubes
All
Would 20x10.5 +30 255/35/20 work as a squared setup on an 08 g37s coupe? Wheels I'm looking at are niche targas. Vendor confirmed they would clear akebonos but was concerned about backspacing. I know there are guys running +25 and +27 (Misaw page 6 and Bassy page 9) but I'm curious if anyone knows if there is the slightest bit of room to play with. I am on eibach pro kit springs
Thanks
Old Dec 17, 2015 | 06:54 PM
  #309
Originally Posted by Suubes
All
Thanks
Check Simpsons, running 275s, so your 255s should
https://www.myg37.com/forums/brakes-...ml#post3891573
Old Dec 21, 2015 | 04:12 PM
  #310
Twinturbo6's Avatar
Twinturbo6
This seems pretty aggressive but I was wondering if they would fit on a g37x sedan. https://seattle.craigslist.org/est/wto/5350536209.html
20x10.25 et 40
Old Dec 21, 2015 | 04:39 PM
  #311
kimmspeed's Avatar
kimmspeed
20x10.25 et 40
Aggressively awesome. I like those. Hope they are a fit.
Old Dec 21, 2015 | 06:54 PM
  #312
evil-G-nius
I agree. I think I would like em better in silver...be able to see more of the detail of the wheel. But they are definitely different...go for it
Old Dec 21, 2015 | 06:57 PM
  #313
Twinturbo6's Avatar
Twinturbo6
Thanks for the replies. I like the encouragement but I really need some advice as to if they would fit or not. I would like to run ksports, have maybe a finger gap and have them sit flush with out rubbing issues.
Old Dec 21, 2015 | 06:59 PM
  #314
evil-G-nius
Try e-mailing XXR with the wheel spec and tell them your car. They should be able to tell you...thats what they are there for! LoL. Good luck...keep us posted
Old Dec 21, 2015 | 07:01 PM
  #315
Twinturbo6's Avatar
Twinturbo6
Also a recommendation on tire size would be great. This is not my forte. My 335xi cam staggered so when I bought volks I stayed staggered. But my tires are gonna last maybe 15000 miles and cost 1500$ so this time I want to stay square on my wife's car.
