The OFFICIAL "I have a wheel offset / tire fitment question!" thread
Old Feb 23, 2016 | 12:28 PM
  #1156
mrig37's Avatar
mrig37
Back then in my 05 g35. I had 19x8.5 with 245/35 and 19x9.5 with 275/30 perfect fit and looked great
Old Feb 24, 2016 | 03:51 PM
  #1157
DennisG37's Avatar
DennisG37
So I was looking into possibly getting Work Wheels, but they do not come in custom offset. So my question is: Would the 19x9.5 +25 offset (all around) work on the G37x Coupe? Any rubbing? I remember seeing on of Lt8Che's setups, which was 18x9.5 +30, but would that extra 5 make a difference? Thanks!
Old Feb 24, 2016 | 10:02 PM
  #1158
He was running 265s, you can run as narrow as a 245/40 safely on a 9.5 so a 255/40 would be the same fit at the fender as Lt8ches' setup, and going w/ a 245 would give you an additional 5mm to work with.
Old Feb 24, 2016 | 10:11 PM
  #1159
Is this calculator legit?
For a 19" wheel, the difference between each degree of camber is 33mm. That seems excessive. The way the calculator works, it takes the angle from the bottom lip of the wheel. That doesn't make sense, as the pivot point is around the hub, not the bottom lip.
Either way, this gave me false hopes, I think.
Camber Offset Calculator | GTSparkplugs
Taking a look at that I entered 27" for the tire diameter (it's close to our OEM diameter) and at 1 degree of camber it lisfed 0.47, at 2 degrees camber it listed 0.94. I think this is in inches, so that would be aprox. a 1/2" of tuck per degree of neg. camber. That sounds about right, as that would be 13mm.
Old Feb 25, 2016 | 01:25 PM
  #1160
DennisG37's Avatar
DennisG37
Hey blnewt, thanks for the response. Do you happen to know if 265 would work with the +25 offset?
Old Feb 25, 2016 | 02:09 PM
  #1161
Probably need to run a bit higher camber, might shoot a PM to Lt8che and see what he says since he's run that setup firsthand.
Old Feb 25, 2016 | 02:15 PM
  #1162
bri's Avatar
bri
I'm planning on putting a square set of tires 245/40-19 Ventus Evo 2 on 370Z sport wheels (9" wide front, 10" wide rear). foresee any issues? I know that max width is supposed to be 9.5" on the tires but it's just one step higher. On the sedan I think it will also fit better into the wheel well since the Z wheels are slightly too inset in the front and slightly poke in the rear.
Old Feb 25, 2016 | 03:59 PM
  #1163
Shoot a PM to Jfisher, he has the Z wheels setup and should have good info, I think a 255 will work in back and that would be a better mount.
Old Feb 25, 2016 | 04:39 PM
  #1164
Ryne's Avatar
Ryne
The Steering Wheel Guy
I have this same tire setup currently with my TSW wheels. Staggered wheels with square tires. I went with the 255 width as Brad described as a good middle ground for the front and rear widths.
Old Feb 26, 2016 | 10:05 AM
  #1165
tigerlui's Avatar
tigerlui
Hi there, i have a question here. I have a '10 G37S Sedan, lowered on Tein-S springs.
Currently, i am sitting on STR607 20x9 (+30)F/ 20x10.5R (+45) , with 245/30/20 and 275/30/20, front has 20mm spacers on.
I am looking into a set of used wheels. They are 20x10 +20 square set, with 255/35/20 tires mounted on. Will the rear fit?
Old Feb 26, 2016 | 10:55 AM
  #1166
So your current front w/ spacers is a 9 with a net +10 offset, that should have crazy poke. If that's the fit you're looking for then the 10+20 will fit, but IMO it's quite a bit too aggressive, the tires might just tuck but the wheels will be quite a bit out from the fenders.
Old Feb 26, 2016 | 12:33 PM
  #1167
tigerlui's Avatar
tigerlui
I might have it mix up, the Front is net +15 offset with 245/30/20
Im not sure will the rear fit at all, being +20 instead of +45. It is .5 inches (12.7mm) shorter overall, i guess.
Im looking for a similar setup like below. see attachment for my current picture.
Thank you sir
Attached Thumbnails The OFFICIAL "I have a wheel offset / tire fitment question!" thread-11850618_10152938121021651_6854619089915401001_o.jpg
Old Feb 26, 2016 | 10:19 PM
  #1168
Thank you sir
If you want that exact setup with those STR wheels they have offsets that are much easier to fit. The 5 spoke STRs in that pic you can run a 9" +35 on 245/35/20s and in back a 20x10.5 +40 on 285/30/20s
Here's those wheels
STR Racing Wheels ? STR 607
Old Feb 27, 2016 | 08:38 PM
  #1169
Mr_Mer's Avatar
Mr_Mer
Would 19X10 +30 all around fit a G37 lowered on Eibach springs, with 4 matching 245/35/ZR19 or 265/35/ZR19?
Old Feb 27, 2016 | 09:07 PM
  #1170
the93owner's Avatar
the93owner
For a coupe that would be a good fit, a little aggressive on a sedan. The 245's would be a stretch so if you're looking to go meat a 265 or 275 will work also.
