The OFFICIAL "I have a wheel offset / tire fitment question!" thread
Old Dec 17, 2015 | 11:53 PM
  #976
Originally Posted by Mr_Mer
Those numbers apply for coupe as well (on stock height, for now)?
At stock height you'd be better w/ +30 to +35, as you go lower and run a bit more camber you can run less positive on your offset. Coupes have a bit room inside the fenders since they are a wider body.
Old Dec 18, 2015 | 01:21 AM
  #977
mrig37's Avatar
mrig37
Hi guys I have a question and would like to know if someone has this set up.
So for my sedan 2013 G37 I'm going to be buying the Enkei RPF1
My question is do you guys think 19x 10 +22 square is a good firm or should I go with the 19x9.5 +22 fronts and 19x10 +22 rear? I will also be getting stance coilovers. ..
Old Dec 18, 2015 | 09:00 AM
  #978
That's way aggressive for a sedan, even for a coupe. Look for offsets in the +35s for the 9.5s and +40s for the 10s
Old Dec 18, 2015 | 04:59 PM
  #979
Alexis Rivera's Avatar
Alexis Rivera
Thanks..☺
Old Dec 18, 2015 | 06:59 PM
  #980
mrig37's Avatar
mrig37
Thank you I believe the 19x10they have it in 42. And 9.5 like in the 30s somewhere
Old Dec 18, 2015 | 09:47 PM
  #981
Baby Jumpman's Avatar
Baby Jumpman
19x9.5 +20 after spacers. Square setup, dropped on springs in this pic.
Old Dec 18, 2015 | 10:12 PM
  #982
Looks good jumpman, what tire size are you running, and any extra camber (looks pretty mild).
Old Dec 18, 2015 | 11:53 PM
  #983
Baby Jumpman
245/40 and in I'm at -2 degrees. While a +20 offset might seem aggressive it is doable. I believe CC is running a +25 offset.
Old Dec 18, 2015 | 11:55 PM
  #984
mrig37's Avatar
mrig37
I might go with a +22 9.5 front and 10 +22 rear should be fine
Old Dec 21, 2015 | 12:34 PM
  #985
ZahyMatar's Avatar
ZahyMatar
Thinking about getting a set of 19x9 coupe wheels for my G37x Sedan. Wondering how that would look?
Old Dec 21, 2015 | 09:32 PM
  #986
Would look great!
Old Dec 21, 2015 | 10:09 PM
  #987
ZahyMatar's Avatar
ZahyMatar
Would look great!
Found a guy selling 2 19x9 coupe wheels for a great price. I'm gonna hop on that and buy the other two on eBay.. Should cost around $700 for a square set
Old Dec 21, 2015 | 11:40 PM
  #988
Running (4) 19x9s is ideal on your X, and having the 9" rim you could run 255/40/19s all around if want a bit wider setup.
Old Dec 28, 2015 | 11:55 AM
  #989
JUMBO PALACE's Avatar
JUMBO PALACE
I was planning on picking up some 19x9.5 wheels with 245/40/19 tires for my 2012x coupe Getyourwheels informed me there would be some stretch with this setup and I'd rather not go that route. Safety and performance first. Should I step down to 8.5 and run the 245s or keep the 9.5s and step up to a 255 tire? I see a lot of people suggesting 245s and I don't want to buy anything too large for the car, but I was hoping to keep the 9.5s for looks. Currently considering 35mm offset thanks to blnewt's advice.
Old Dec 28, 2015 | 11:56 AM
  #990
JUMBO PALACE
Think I found my answer to my questions about the 255s
