The OFFICIAL "I have a wheel offset / tire fitment question!" thread
Old Sep 1, 2015 | 10:26 AM
  #856
bbasae's Avatar
bbasae
19x9.5 -12 front and 19x 11.5 +12 will this fit on g37S? if not what mm spacers do I need to fit it? thank you
Old Sep 2, 2015 | 08:40 AM
  #857
You need offsets that are much more positive, those wheels without any spacers will be sticking way out from the fenders.
Old Sep 2, 2015 | 03:53 PM
  #858
Roasty's Avatar
Roasty
Hey guys - I am a newbie, and just joined. I have had my 2008 G37s Couple for a couple of months now and have saved up for some wheels. I am a little confused at what fitment I should get.
Sticking with 19" wheels.
With some guidance, I am looking at either 19x8.5 +32F 19x9.5 +28R, or 19x9.5 +28F 19x11 +45R. Not sure which I should get. I would like it to be flush, but i don't want to have to ever get a camber kit. Planning on some coilovers in early 2016.
Looking at the Vossen VFS1 wheels in case that makes a difference.
Any help would be much appreciated!
Old Sep 2, 2015 | 06:54 PM
  #859
They have a pkg deal at element wheels, the 8.5 +32 11 +45 will work on your S coupe as long as you don't go too wide w/ the tires in back. A slightly stretched 275/35/19 should work ok.
Vossen VFS1 Gloss Silver/Brushed Face (Flow Formed) 19x8.5 19x11 Staggered Wheels
If you go with coilovers a rear camber kit would be a minimum that I'd recommend.
Also need to confirm brake clearance prior to ordering
here's templates that will help
https://conceptzperformance.com/imag...nttemplate.pdf
https://conceptzperformance.com/imag...artemplate.pdf
Old Sep 2, 2015 | 08:21 PM
  #860
Roasty's Avatar
Roasty
Thanks for the reply and input blnewt!
Old Sep 9, 2015 | 10:42 AM
  #861
Brakery's Avatar
Brakery
Hey guys, new to the forum...long term member over at the 3SI forums. Question....Will a 18x7 40 offset fit 2011 g37x sedan?
I have searched but haven't found a concrete answer.
Thank you!!
Old Sep 9, 2015 | 07:06 PM
  #862
Thank you!!
That's a very narrow rim, are you wanting these for a narrow winter tire set?
It depends on the wheels bolt pattern, and backspacing, as a wheel that narrow may not clear the Infiniti base brake calipers.
Old Sep 9, 2015 | 07:09 PM
  #863
Brakery's Avatar
Brakery
I can get them for a hundred bucks...its the same bolt pattern...just a narrow *** rim..
Old Sep 10, 2015 | 11:21 PM
  #864
Yeah, if they're a local deal and you can do a test fit just to be sure they clear the brakes, they should be ok for a winter set.
Old Sep 17, 2015 | 04:55 AM
  #865
Miggy650's Avatar
Miggy650
hey, I'm thinking bout running a square ground force gf6 20x10.5 +30 in my sport sedan. my question is will that clear my bbk?
Old Sep 17, 2015 | 08:21 AM
  #866
Those wheels are going to poke quite a bit and you'll have to run some stretch on the tires unless you plan to go big on camber. As far as clearing your BBK, that's something you'd have to confirm w/ the vendor, the design and aggressive offset should be good for clearance but
These templates can be sent to vendor to confirm, sometimes they'll work with you if they want the sale.
Old Sep 22, 2015 | 04:15 PM
  #867
drewfinity's Avatar
drewfinity
18x8 Enkei Lusso
http://www.summitracing.com/parts/en...40bk/overview/
245/45/18 Pirelli Cinturato P7 A/S
http://www.tirerack.com/tires/tires....SPXL&tab=Sizes
Making sure this will ride smooth, look nice, fit right, and hopefully clear BBKs in the future.
Old Sep 22, 2015 | 04:49 PM
  #868
Originally Posted by drewfinity
18x8 Enkei Lusso
Enter G37 sedan w/ sport pkg. in the tirerack site, it will show you which Enkeis will clear.
Old Sep 30, 2015 | 09:48 PM
  #869
Suubes's Avatar
Suubes
18" setups
Need some help
Looking at two possible setups for 08 g37s coupe
1st Option
18x9.5 et15 265/35/18
18x10.5 et22 275/35/18
Would like to run eibach pro-kit springs.
Realize fender roll will be necessary. Worried about rolling diameter
2nd Option
18x10.5 et22 255/40/18 squared
Again eibach pro kit springs
Same concerns
Any help here would be greatly appreciated. Springs would be ideal but I am also considering Tein Basis Coilovers as well.
Thanks in advance
Old Oct 1, 2015 | 08:38 AM
  #870
Originally Posted by Suubes
Need some help
1st Option
2nd Option
Same concerns
Thanks in advance
2nd option is much better, and w/ the stretch 255s you'll probably get inside the fender edges, if not, a bit more camber should do it. The actual wheel edges will be a bit outside the fenders though, but it sounds like that's the look you're after.
I'd go w/ the coilovers too.
