The OFFICIAL "I have a wheel offset / tire fitment question!" thread
That's what I was thinking. I was looking at that one guys square setup in the thread you mentioned about and he's running a 9.5 with a 35 offset so I figures the 9 with a 32 would sit like a quarter of an inch in. My ideal setup would be a 9.5 +40 though I think. Haven't seen those offsets yet but I think that's where I stand. Probably go extended study's and some 10mm hub centric spacers in the rear.lmk what you think. Thanks again bro
Hey man. Would it be to much trouble to ask you to upload a photo of how your car sits? Preferably down the side so I can see how flush they sit? Thank you
sorry man...don't have any pics like that, this is the best I can do till later. I'm guessing I would need a 10mm in the rear to be flush with fender. The front looks like a 15mm-20mm would be needed to be flush. I'll get pics showing how tucked it is. I'll also measure the height so you can get a better idea of how it sits.
Wow. Very clean looking sedan bro! That's 9.5 +40 all the way around right? I like the set up a lot. I'll just do some good extended studs in the front with some 10mm spacers if I'm not happy. Looks like they're good to me though. Thank you for the pictures as well, sir.
i have some 19x8.5 and 19x9.5 wheels on my G. not sure what the offsets are but i was just wondering what tire sizes to go with. I dont want it to be too stretched. Also, im going to drop it about 1-1.5 inches in the near future. any suggestions would be appreciated.
As far as a reasonable tire that won't be stretched on those rims, you could run as narrow as a 225/45/19 or as wide as a 255/40/19 front and a 245/40/19 to a 285/35/19 rear, those are all within the recommended rim width range for those two widths of 19" rims. Now it comes down to how much room your wheels' offsets will allow. They should be stamped on the inside of the wheel.
its a coupe rwd. i bought the rims off some guy who had 275/35 on the rear and 225/35 on the front. i currently dont like the look of the fronts at all.. not enough tire and the gap is huge. ill look at the offsets when i get a chance to take the rims off. Im also thinking of going less wide on the rear. Maybe a 255-265/35 or 45
Have you considered lowering your G?
Please help. I have a G37XS coupe. I am looking at Gramlight 57xtreme. I would like at a staggered set up (19x9.5, 19x10.5). Can you please recommend the correct offset and tire size?
19x9.5 - Available offsets are 25, 35, 43
19x10.5 Available offsets are 25, 35, 43
I am planning to lower my car in the future with Auto Fortune 500s. About the same height as Eibachs.
Thank you.
Thank you.
Thank you.
Thank you.
https://www.myg37.com/forums/private...ith-tires.html
I want to have a set VFS2 vossen for my G coupe. i live in Oklahoma very bad road condition. therefore, I would love to go with 19". is it possible to run 9.5 +28 front, 11 +45 rear? tires 245/40/19 275/35/19. ?
thanks
thanks
