The OFFICIAL "I have a wheel offset / tire fitment question!" thread
Old Oct 13, 2014 | 06:30 PM
  #421
Solidus's Avatar
Solidus
Blnewt,
I have a mild drop with Ark springs in my coupe. I'm about to pull the trigger on a 19x8.5 +30 front 19 10 +35 rear. My plan is to swap my current 245/40 to the front and go with a 285/35 rear. I'm looking for a flush fit. Option two is 19x8.5 f ,19x9.5 rear both +35 . I'd love sticking with the first option but I'll bail on it based on your opinion. Experience goes a long way considering I probably won't live long enough to make ALL the mistakes that can be made.
Thanx
Old Oct 13, 2014 | 07:20 PM
  #422
Originally Posted by Mulatto
If the wheels I am considering are offered in the following sizes:
20x9 +22 or +32
20x10 +25 or +45
20x11 +28
What combination of front and rear sizes/offsets would sit the most flush without having to run spacers or stretch tires TOO much?
Coupe or Sedan?
Coupe 9+22 245/35/20 & 10+25 275/30/20
Sedan 9+32 245/35/20 & 10+45 285/30/20
Old Oct 13, 2014 | 07:22 PM
  #423
Originally Posted by Solidus
Blnewt,
Thanx
the 8.5/10" stagger will be OK w/ the tires you listed
Old Oct 13, 2014 | 08:51 PM
  #424
Solidus's Avatar
Solidus
Thanks appreciate the help.
Old Oct 16, 2014 | 08:20 PM
  #425
Mulatto's Avatar
Mulatto
Coupe or Sedan?
Coupe
Thanks blnewt!
I talked with a local dealer this afternoon and he recommended I run the 20x10 +25 front and 20x11 +28 rear and he says it won't rub. What do you think? Would that require an aggressively stretched rear tire to fit?
Old Oct 16, 2014 | 09:16 PM
  #426
Coupe
Thanks blnewt!
You'll have to run camber, stretched and poked (and maybe a fender pull)
I'd find a different dealer.
Old Nov 1, 2014 | 10:22 AM
  #427
djb13's Avatar
djb13
17's for 19's?
Can I put 17 inch wheels on my 2008 g37s that has the big brakes and stock 19's. Its for winter.
Old Nov 1, 2014 | 02:33 PM
  #428
There may be some 17s that will clear the big calipers but you'd have to search a while.
Here's the template that you can send to vendors to verify clearance.
Good Luck!
http://infinitig37.com/tech-images/akebonotemplate.pdf
Old Nov 2, 2014 | 09:36 AM
  #429
djb13's Avatar
djb13
Thanks for the help
Old Nov 4, 2014 | 01:50 PM
  #430
dtea54's Avatar
dtea54
Just wondering if anyone here is running a 275/35/19 square set up ?
Old Nov 4, 2014 | 09:52 PM
  #431
There's a couple 275 square setups here, but on 20s, so it can be done
https://www.myg37.com/forums/brakes-...post-here.html
Old Nov 5, 2014 | 01:26 PM
  #432
messier77's Avatar
messier77
Any idea if 2003 G35 Sedan wheels (17x7 +45mm) will fit without any issues or spacers needed on my base 2009 G37x Sedan (stock wheels are 17x7.5 +45mm) for use as a winter setup?
Thanks for your help.
Old Nov 5, 2014 | 03:33 PM
  #433
They'll be OK, the OEM size for those wheels is 215/55/17 but you could run the 225/55/17s on them.
Old Nov 5, 2014 | 03:52 PM
  #434
messier77's Avatar
messier77
Thank you!
Old Nov 12, 2014 | 02:47 PM
  #435
pledes23's Avatar
pledes23
Hello,
I came across a very good deal on a set of ADR M-Sport 19" rims. They are 19 x 8.5 / +35mm Offset. I have a 2011 G37x Sedan (non sport brakes) I am currently at stock height but will be looking for coilovers come spring time next year. I wanted to know if this would be a good setup for my car.
Also can I run 245/40/19 all around, I do not want stretched tires, as it is not appealing to me to view the lip of the rim outside of the tire.
I have attached a few pictures of them. One of them is hyper silver and the other 3 are hyper black (hence the very low price.) That doesn't bother me because my plan is to have them powder coated, or have the hyper silver one refinished to hyper black.
Any feedback is greatly appreciated.
