The OFFICIAL "I have a wheel offset / tire fitment question!" thread
Old Jul 8, 2014 | 12:56 AM
  #301
blueslate11xs's Avatar
blueslate11xs
Check this thread from post #47 on out, his AWD coupe is on 8.5 +35 &
10 +40, and 245/285 tires, they're 20s but the fit at the fenders will be essentially the same as 19s. I think the F&R fit is about what you're wanting, and running 275s in back w/ a bit less positive offset on a 1/2" narrower rim should net a similar fit. I think I'd opt for the +35 in front, especially is you're not adverse to running a small spacer. Here's the thread
https://www.myg37.com/forums/build-t...x-coupe-4.html
As far as the tires, the 235/40s are only 0.18" smaller in diameter than the 275/35s and that's the critical variance, both 245/275 and 235/275 will work alright, I was just throwing that option at you since it the variance will improve over time and the 245/275 will get worse.
Ironically enough, that's the exact wheel, except I'm going silver. Based on the calculator, the 9.5 ET35 is right at 1mm further in, so that should work splendidly.
Looking at that set-up though, i may convince myself i need to go 20s. I just drive really hard (live in the mountains) and prefer to have a little sidewall.
Thanks again for all the help.
Old Jul 10, 2014 | 12:36 AM
  #302
G37fan09's Avatar
G37fan09
Originally Posted by NoLimits_Auto
It really depends on what you are looking for. Without any stretching or large amounts of camber the ideal setup would be something along these lines:
(Insert whatever diameter wheel that you fancy, 19", 20")
Front:19x9.5 +35 offset
Rear: 19x10.5 +45 offset
Now if you go lower on the wheel widths the offsets can be tinkered with but it all depends on the "look" you are going for.
The Velgen VMB5s 19s only come in 19x9.0" for the fronts and 19x10.5 for the rear. Their offsets for the front are +25 and +35. Rears are +25 and +45.
The VMB5 are great looking wheels. So if you went with the VMBs in 19 you would want 19x9 +35 and 19x10 +45 would be the fitment I went with. Again though this the ideal of safe fitment you could say. If your into the stretched tire look and lots of camber you can change the fitments.
Thanks for the info, that's what I'm looking for; flush but safe fitment, no stretched tires. Any issues with your fitment?, Do you have any pics.?
Old Jul 10, 2014 | 12:40 AM
  #303
G37fan09's Avatar
G37fan09
Originally Posted by G37Some
for the VMB5s you should get 19x9 +25 and 19x10.5 +45
I know 19x9 front +35 will not rub, but +25 would be safe (no rubbing)?
Old Jul 10, 2014 | 02:35 AM
  #304
Kuro's Avatar
Kuro
Depends on the drop
Old Jul 10, 2014 | 08:41 AM
  #305
NoLimits_Auto's Avatar
NoLimits_Auto
Check out Robert_K's car. He is running this setup if I remember correctly.
https://www.myg37.com/forums/build-t...d-g37s-12.html
Old Jul 11, 2014 | 10:03 AM
  #306
G37fan09's Avatar
G37fan09
Originally Posted by Kuro
Depends on the drop
Will drop on Swift springs, I got them 2 days agoDOMO
Old Jul 16, 2014 | 10:05 PM
  #307
STownSaint's Avatar
STownSaint
Can anyone comment on how all front GTR OEM wheels would fit & look on a G37S sedan with stock suspension?
Wheels are 20 x 9.5 45 offset, tires are 255/35/20
Seems like this size wheel should fit both front & rear pretty well, but want to see if anyone thinks they would stick out passed the fender (poke) or cause any other clearance issues.
Also, any have opinions on how this would look? Thanks
Old Jul 18, 2014 | 09:32 AM
  #308
R1cky has them and they're awesome, here's a thread, check post 2386 thru 2390
https://www.myg37.com/forums/g37-sed...50#post3722376
And a couple fresh pics
https://www.myg37.com/forums/3796779-post3113.html
Old Jul 18, 2014 | 09:22 PM
  #309
G37Some's Avatar
G37Some
I have 19x9.5 +23 in the front with 245/40/19 (or is it 245/35 i forget, essentially oem sized though just wider) and not even close to rubbing the outside. I have an fairly decent drop, bout 1.5" in the front and -1.6* camber. Eventually i'll get a camber kit and it will make the wheel and fender pretty tight if I can reduce the negative camber and bring the wheel out towards the fender again
by not even close I mean there is room, but I cannot fit my infiniti key between my fender and wheel, I can fit a pen cap though. PM me if you want pics and more info.
edit; actually heres the pic:
once i get a camber kit and reduce the camber to -.5 or 0*, the tip of that pen cap will not fit anymore. don't think i'll have to roll the front fenders, but who knows...
The OFFICIAL "I have a wheel offset / tire fitment question!" thread-wrvwymd.jpg
Old Jul 20, 2014 | 10:03 AM
  #310
goongoblin's Avatar
goongoblin
2011 G25X - Will 255/30r20 on 20"x10" offset +41 fit my car without any problems? Thanks
Old Jul 20, 2014 | 10:27 AM
  #311
Welcome to the site, tires should be 255/35/20 the 30s will be too small in diameter compared to OEM.
Your wheel specs should be in this link
Infiniti G37 Sedan Rim and Tire Specifications, weight, offset and information
Enter your oem wheels/tires in the first box and the wheels/tires you want in box 2 and measure your current setup and see if that new wheel/tire extension will work
The rears will be fine but the front may be a bit close
Old Jul 20, 2014 | 11:03 PM
  #312
witham9's Avatar
witham9
So I finally pulled the trigger this wkend.
Ordered wheels (Avant Garde M310's) and tires (Toyo Proxes 4 Plus)
20x9 +30. 245/30/20
20x10 +40. 275/35/20
Sedan with a mild drop on Eibach Pro springs...
I've done a lot of research and this should be flush all around.
Any opinions??
Old Jul 20, 2014 | 11:09 PM
  #313
20x9 +30. 245/30/20
Any opinions??
I hope you just mis-typed those tire sizes, should be 245/35/20 & 275/30/20
Offset & tire widths are just right though, look forward to pics!
Old Jul 21, 2014 | 12:54 PM
  #314
witham9's Avatar
witham9
Yes I mistyped. Thanks for the catch!!
Installation end of the week/ into next week.
Pics to follow.
Also, do you think I'll be running too much camber to not have a camber kit?
I'm trying to avoid it unless its totally necessary.(burning though a set of tires every year)
Old Jul 21, 2014 | 02:42 PM
  #315
Pics to follow.
That's really up to you, I recommend them for almost all lowered vehicles. You can always get it aligned to the best they can get and run it for a few months keeping close watch on the treadwear and then decide, but getting them first is the best way to go IMO, especially if you're doing the install and saving some money there
