The OFFICIAL "I have a wheel offset / tire fitment question!" thread
#152
So I've decided I want to run 20x10 all around, with a mild 255/35 stretch, I'm assuming a +25 will be too aggressive and stick out to far , right ? Would I be safer with a +35 or +40 instead? All these numbers are making me crazy, all I've been doing is looking through pages of forums looking for peoples wheel offsets hahaha. No bueno.
https://www.myg37.com/forums/picture...g37-sedan.html
A 10" +35 would get the same fit since she's running a spacer in front.
It's going to be tight in front but it's been done.
#153
Offset is the measurement from centerline to the mounting on the hub.
So if I go w/ a 17" x 7.5 - +45mm - thats OE.
If I were to go w/ a 17 x 17.5 +50mm, that'll stick out further (or is it inverse, it'll be pulled in?)
As such - if I were to go with an 18 x 8.5 rim - woudl the offset need to go up or down to remain flush? I appreciate your input ...
I know enough on and off about cars - but custom wheels/offsets/etc. is one thing I am definitely out of my element on.
Thanks!
#154
Ok... so if I'm understanding this correctly....
Thanks!
Thanks!
The more positive the offset the more the mounting hub goes toward the outer face of the wheel so it will pull the wheel in as you go more positive w/ the offset.
TommyBluez (04-04-2014)
#156
Thanks for that tool!
So I just calculated going from
17x7.5, +45, 225-55-17
to
18x8.0 +50, 225-50-17
Results:
Inner Clearance:
11.35mm less
Outer Position:
extend by 1.35mm
Diameter difference:
0.11" (0.42%)
Inner clearance, I'm assuming is the clearance between the flat portion of the tread and the wheel well?
Outer position would be how much further the face of the rim/tire extend past where it's at now, correct?
So ultimately - this would be a very comparable upgrade to overal diameter if I'm thinking about this correctlY?
to
Results:
Inner Clearance:
11.35mm less
Outer Position:
extend by 1.35mm
0.11" (0.42%)
#157
to
Results:
Inner Clearance:
11.35mm less
Outer Position:
extend by 1.35mm
0.11" (0.42%)
to
Results:
Inner Clearance:
11.35mm less
Outer Position:
extend by 1.35mm
0.11" (0.42%)
#158
I have a coupe with oem bbk going air soon and was planning on refinishing and re-barreling my wheels. My current wheel set up is 20x9.0 +25 R-disk and 20x10.0 +30 O-disk. I was wondering what offset I would need on this wheel with to achieve the 10.5 +15 square setup look, and what tire sizes I would need to make them fit?
#160
Also, when it comes to center bore, do wheels made for the 5x114.3 bolt pattern fit all the cars associated with it (350z, g37, mustang, wrx, camaro, etc), or are some specifially made when it concerns how the wheel will sit on the hub? Meaning, can I throw one set of wheels from a car with the 5x114.3 bolt pattern to another car with the same 5x114.3 bolt pattern. Thanks.
#162
I realize I should have asked this question here. I have a 2011 sport sedan lowered on Eibachs and I have camber kits all around. I've always been in love with the 370z sport mantis wheels. What steps would be necessary to get the 370z rear wheels to work without rubbing? I used the calculator and it said that the new setup would extend 39mm more than the OEM 18" sport wheel. This was calculated using: 18x8.5 +50 245/45/18 and 19x10 + 30 275/35/19 as the values. I used a tape measure and found that I have about 1 1/8" horizontal clearance from the 18" rim to the inner fender. 39 mm is roughly 1 1/2" inches. So I still need to clear about 3/8". I know I can get some distance back either through camber or by getting the rear fender pulled. I know I'll definitely be shaving the rear fender lining. My current camber in the rear is -1.4. Would you be able to give me an estimate on whether I would need to pull the fender (and if so how much) if I maxed the camber at no more than -2.0?
#163
https://www.myg37.com/forums/brakes-...-on-sedan.html
hinomura (04-07-2014)
