The OFFICIAL "I have a wheel offset / tire fitment question!" thread
Old Aug 11, 2017 | 11:52 PM
  #2011
Originally Posted by Guccicoochie
g37 coupe rwd non sport
19" AGs only have conservative offsets, good for running wider tires but won't be right at the fender edge (the wheel edge, not the tire)
the AG 19x8.5 +35 on a 245/40 and 19x9.5 +40 on a 275 or 285/35.
The Niche have good front offsets, a 20x8.5 +25 on a 245/35 but no 20x10" wheel in the 5x114.3 bolt pattern, and the 10.5 is a +45, you could run up to a 295/30 in back with those.
If you were to do either set you'd probably want a rear spacer for Niche and front & rear spacers for the AGs to get that flush fit that you're wanting.
The other directional Niche, the Invert has much better offsets, a 20x9 +25 front on a 245/35 and a 20x10.5 +30 on 275/30 will be a much more flush fitment.
Niche Invert Silver/Machined (True Directional) M162 20x9 20x10.5 Staggered Wheels
Old Aug 12, 2017 | 02:26 AM
  #2012
Guccicoochie's Avatar
Guccicoochie
Ill probably go with the ags thanks for the info
Old Aug 14, 2017 | 11:16 AM
  #2013
GetYourWheels's Avatar
GetYourWheels
The AG M580 also come in blanks so they can also do custom offsets on the 8.5 and 9.5 options as well!
Old Aug 14, 2017 | 03:20 PM
  #2014
jholla's Avatar
jholla
new g owner.i have a 2013 g37x with the stock 17in wheels.
i would like to go to an 18 inch wheel. the two i like are
18 x 8 35 offset
18 x 8 45 offset
i am afraid the 35 offset would stick out too much and the 45 off will be too close to the strut. both are on discount tire direct so i assume they know they will fit.
is anyone here running an 8" wide wheel with either a 35 or 45 offset and can let me know how they fit?
Old Aug 14, 2017 | 10:11 PM
  #2015
18 x 8 35 offset
18 x 8 45 offset
You'll be fine with either, but the +35 will be a better fit, it won't be flush to the fender but will be out about 5/8" from your current 17x7.5" wheels. You can run up to a 245/45/18 tire but a 235/45/18 is the best mount on an 8" width. I would consider a 18x8.5" wheel on a +35 offset, this is a better size for a 245/45 tire and will be a nice fit all around.
Old Aug 17, 2017 | 06:53 PM
  #2016
55Drake66's Avatar
55Drake66
I've been lurking for a long time trying to find an answer to what I'm looking for, but have come up short.
I have a 2012 Journey coupe, and I'm looking to go up to 20" wheels. I want to run either an 8.5 or 9 for the front and a 10 for the rear. I plan on dropping on Eibach springs, and i would prefer to keep the wheels behind the fenders/flush. i don't want to poke at all, which is why I'm hesitant to run a 10.5 in the rear.
is there a particular offset for the 8.5/9-10 setup to get the look i want, or is there an offset for the 10.5 rear that will get me where i want to be?
Ive been eyeing a few of the Niche, AG 590's, and Rohana RC7 wheels. Vossens seem to be too aggressive for what I'm looking for.
Old Aug 17, 2017 | 07:01 PM
  #2017
GetYourWheels
Check out a member's setup for reference. I'd say its probably the best setup you'll want to look for and also a great reference to work with.
Originally Posted by Ryne
UPDATE!!!
Vossen VFS1 - Matte Graphite
Wheels:
  • Front: 20x9.5" +25 (Mid Concave)
  • Rear:20x10.5" +40 including 5mm hubcentric spacer (Deep Concave)
Tires:
  • Front: 245/35R20 Continental DWS06
  • Rear: 285/30R20 Continental DWS06
Miscellaneous Information:
  • 25.8lbs for the 20x10.5"
  • Clears the BBK without spacers
  • 5mm hubcentric spacers are used in the back
  • Lowered on Eibach ProKit, front and rear SPC camber kits, camber is within OEM spec but on the far negative side. No rubbing - my rear fender liner has been trimmed previously. My bumper bracket is not trimmed.
Old Aug 17, 2017 | 07:04 PM
  #2018
55Drake66's Avatar
55Drake66
That looks awesome. Thats pretty much exactly what I'm looking for. I knew i came to the right place.
Thank you! Now the search continues...
Old Aug 24, 2017 | 08:39 PM
  #2019
darksideG35's Avatar
darksideG35
thinking about running 20x10.5 +30 square setup on my g37xs coupe that will be lowered on swift springs. what size tires would be best for this? 275/30/20 or something with a 35 series sidewall? came across this pic on the forums of a 275/30/20 on a 20x10.5 +25 but lowered on eibachs which sit slightly lower than the swifts do on the awd coupe.
Old Aug 24, 2017 | 09:23 PM
  #2020
That's Simpson's coupe, unfortunately most of the pics are vaporized thanks to Photobucket
A 10.5 +30 will be a better setup as far as clearance, you could run the 275/30s which will be much closer to your OEM diameter vs. the 275/35 which is about an inch taller and may have a bit more clearance hurdles there. You could also run a 265/30 which will give another 5mm room to the fender, that combines w/ the 5mm more room for the offset will get you a good cushion and a bit less prone to tramlining. Only downside is 265/30/20s aren't nearly as common so the tire you want may not be available in that size
Old Aug 24, 2017 | 10:29 PM
  #2021
darksideG35
appreciate it, i really liked the way that Simpson's coupe turned out. i was looking into tires earlier and there wasnt hardly as big of a selection in the 265/30 as compared to the 275/30. probably will go with the 275/30, now just need to figure out which tires to run
Old Aug 24, 2017 | 11:24 PM
  #2022
The newest Continental Extreme Contact Sports are getting superb reviews, here's a link you might want to check~
https://www.myg37.com/forums/wheels-...act-sport.html
Old Aug 31, 2017 | 08:12 PM
  #2023
chrispyy's Avatar
chrispyy
I ordered 20x10.5 Vossen VFS1 wheels +25 all around for my G coupe Sport. Will it clear my sport brakes? I should have confirmed this earlier.. please tell me it does.. lol
Old Sep 2, 2017 | 02:41 PM
  #2024
They should but I would contact the vendor ASAP and ask for confirmation, hopefully they haven't shipped them out yet.
BTW, what tires are you planning to run? 275s are going to be real tight there without some camber.
Old Sep 6, 2017 | 03:59 PM
  #2025
mliakira's Avatar
mliakira
Will I have to do any fender modifications for a square 19x9.5 +25 WORK Kiwami on a G37x sedan? I'm obviously going to drop..
I have used the search function and even Google dork commands for the entire internet!
Thanks
