The OFFICIAL "I have a wheel offset / tire fitment question!" thread
Old May 16, 2017 | 01:42 AM
  #1966
RAVSPEC's Avatar
RAVSPEC
Originally Posted by Envi0us
Noob to the wheel game....I acquired some new rims (Enkei RS05RR) with the following specs:
18×9.5 + 22
18×10.5 +35
I drive a sport sedan on coils.
Whats is the nicest/beefiest setup i could run in front/rear?
I have 275/40/18s for the rear on hand but I'm thinking they are too big?
Should I go 265 in the rear?
All suggestions welcome thanks!
For G37 Sedan, these are too aggressive.
Suggest these upgrade
coil over
camber arms
toe bolts
Front: 245/35
Rear: 255/35
Old May 16, 2017 | 08:54 AM
  #1967
Like Ravspec said, those are real aggressive for a sedan. Wheels will be poking about 5/8" outside the fenders so those tires he listed 245 front/255rear are about the widest you can run without resorting to heavy camber. If they are still new and can be returned you might consider going about 10-15mm more positive w/ the offsets so you don't have a stretch fit.
Old May 16, 2017 | 11:14 AM
  #1968
Envi0us's Avatar
Envi0us
Gonna have to commit to these as I've spent a pretty penny having them refinished chrome gold. I actually tried them on the car when I was on tien s-techs 265/30 and still had a huge gap..which is why I wanted to go bigger.
Old May 16, 2017 | 08:04 PM
  #1969
Do you have any pics of them on w/ the S techs?
If you're not opposed to running extra camber you can run more tire, but you then compromise the drive somewhat and your tire wear will increase. Your camber in the -2.5 range should accommodate a 275, not sure what camber this post is running but it's a 10.5 +35 on 275s and looks pretty good at the fender, and as you can see the wheels are out about 5/8" from the fender~
https://www.myg37.com/forums/g37-sed...ml#post3932941
Old May 16, 2017 | 11:58 PM
  #1970
Envi0us's Avatar
Envi0us
Only shot I got from a friends phone.. was too excited to take pics lol.
They are also 265/35 (not 30 mentioned in my previous post)
Old May 17, 2017 | 12:02 AM
  #1971
Nice wheels^^^You should be able to make those work, can't get rid of the poke but w/ camber like I mentioned above that can help for sure! I assume you have aftermarket camber arms & rear toe kit, if not, that should be on your list.
Old May 17, 2017 | 03:35 PM
  #1972
VenomGT9's Avatar
VenomGT9
the poke really isn't even bad
even if you don't have camber arms I think the natural camber will be in your benefit
Old May 22, 2017 | 07:12 PM
  #1973
NightMarauder's Avatar
NightMarauder
NissanFan since 1989
emotion cr 2p
Front: 255/40-19x9.5 +35
Rear: 285/35-19x10.5 +40
anyone has this on a sedan?
Old May 31, 2017 | 01:18 PM
  #1974
Scott McKenzie's Avatar
Scott McKenzie
I have front 20x9 +38 rear 21x9.5 +24 its a 6MT sedan lowered on eibach pros. Will 255/35/20 & 265/30/21 work? Trying not to run more than 2-3 degrees of camber will the rear rub?
Old May 31, 2017 | 09:59 PM
  #1975
GClayt's Avatar
GClayt
I just got new tires they are rubbing on the rear fenders when I go over some bumps. I am not sure how to proceed?
These are my specs:
Front Rim: 19x9.5
Rear Rim: 19x10.5
-The offset on ebay says 22/22?
Front Tire: Yokohama S. Drive - 245/40/19
Rear Tire: Yokohama S. Drive - 275/35/19
So what are my options now? I had no intentions of adjusting the camber, but if it must be done it must be done. My G is not lowered and I won't be lowering it.
Any help is much appreciated as I don't think the tire shop will do an exchange.
Old May 31, 2017 | 11:17 PM
  #1976
PNW_IPL's Avatar
PNW_IPL
These are my specs:
Front Rim: 19x9.5
Rear Rim: 19x10.5
Get an alignment. Have shop add negative camber say -2.3 and trim fender tab and fender liner. No more rub
Old Jun 1, 2017 | 12:15 AM
  #1977
RAVSPEC's Avatar
RAVSPEC
It's very uncommon to run double staggered on G37. But yes that would work, but these spec are not suggested.
Old Jun 1, 2017 | 08:15 AM
  #1978
GClayt's Avatar
GClayt
The shop did an alignment after they put the tires on, but obviously not with negative camber.
Do you think I can achieve the required amount of camber with the OEM control arm?
Old Jun 1, 2017 | 09:02 AM
  #1979
At stock height your OEM arm won't have enough adjustment, you'd have to get a set of SPC camber bolts and SPC toe bolts to get it set up the way you want.
They are the same part#, just need two kits and here's a link on them
https://www.myg37.com/forums/brakes-...-template.html
Old Jun 1, 2017 | 10:19 AM
  #1980
GClayt's Avatar
GClayt
Thanks for your advice. So I can get away with using my existing control arms if I get the new camber/toe bolts?
Also, if I install these myself and adjust the camber to my preference do I then need to get another alignment?
Is there anything to align if I already messed with the camber or will the shop just "straighten" my wheels back out in order to align?
