The OFFICIAL "I have a wheel offset / tire fitment question!" thread
Old Feb 24, 2017 | 06:40 PM
  #1801
voha123's Avatar
voha123
Hey guys summers around the corner so I'm in the process of buying some wheels.
I have decided to go with Niche Forms, I talked to the local shop and they suggested the following set ups
19" x 8.5/9.5
20" X 8.5/10
Im leaning towards the 20" set up, but I am worried that the 8.5 will look out of place. The wheels comes in 20x8.5,10,10.5. Should I go 10F/10.5R ?
Thanks
Old Feb 24, 2017 | 07:41 PM
  #1802
the93owner's Avatar
the93owner
19" x 8.5/9.5
20" X 8.5/10
Thanks
The 20x8.5 will be fine for the front, nothing wrong with that. It will allow you to run a more even tire setup in terms of overall diameter. 245/35/20 front and 275/30/20 rear. That will give you a staggered look (semi-concave front and deep concave rear) but if you want a square look (deep concave all around) go with the 10 or 10.5.
Old Feb 24, 2017 | 09:06 PM
  #1803
voha, do you have a coupe or sedan, and big sport brakes, or plans to upgrade to them?
This will determine what wheel offsets/widths you can run.
Old Feb 24, 2017 | 09:53 PM
  #1804
voha123's Avatar
voha123
Thats my dilemma right now, 8.5/10 vs 10/10.5
Its going to be my first big purchase for my car and I don't want to regret it, haha.
Old Feb 24, 2017 | 09:54 PM
  #1805
voha123's Avatar
voha123
I have a 2012 G37Xs coupe, which I think come with the big sport brakes?
Old Feb 24, 2017 | 11:33 PM
  #1806
With AWD you need to be very selective regarding which tire combos to run if you go staggered. Having the big sport calipers also can limit you in the front depending on your wheel selection. If you don't plan to lower your coupe the 19s will typically look better as the fender gap will "appear" to be smaller. Also the slightly taller sidewalls w/ the 19s will result in a more comfortable ride (depending on the tires you run). A 19x9.5 +35 running up to 275/35/19 tires will fit well, and you can do a true 4 wheel rotation to extend tread life. The wheels should clear the big brakes but that's something you MUST confirm w/ the vendor. Brake clearance can be tricky w/ some wheel designs.
Old Feb 25, 2017 | 01:34 PM
  #1807
voha123's Avatar
voha123
I do have plans to lower on coils in the near future, the wheels do clear the big brakes, and the tire measurement he gave me were I believe 1.1% so the it would work with the AWD. Im fairly set on 20" since I want a bigger wheel than what is on my car right now, but I'm not sure whether to go with 8.5/10 or 10/10.5. Im not even sure if the 10 will work on the front?
Old Feb 25, 2017 | 01:49 PM
  #1808
What tire sizes did he give you, if you start w/ a 1.1% variance and your rear tire is already slightly smaller than your front you may have issues since the rears wear faster. With 20s there are combos that are much better than 1.1%.
Old Feb 25, 2017 | 08:01 PM
  #1809
Mach370's Avatar
Mach370
I have a 2010 G37S coupe (Akebono), lowered on Tein H-Techs
F19x8.5+15
R19x9.5+20
What size tires should I be running? I was thinking, 245/40/19F and 265/30/19R?
Old Feb 25, 2017 | 09:59 PM
  #1810
voha123's Avatar
voha123
20" Niche Form
275/30 R20
245/35 R20
Falken Fk510
Old Feb 25, 2017 | 10:15 PM
  #1811
the93owner's Avatar
the93owner
F19x8.5+15
R19x9.5+20
Try 275/35/19 in the rear. 265/30 is too short compared to the front
Old Feb 26, 2017 | 04:45 PM
  #1812
voha123's Avatar
voha123
Now I'm considering going square set up, 20" X10 all around.
so i can rotate tires, but I'm wondering if the 8.5/10 might give it a better look ?
Old Feb 26, 2017 | 08:11 PM
  #1813
the93owner's Avatar
the93owner
Depends what kind of look do you want. 20x10 square will be dual concave while staggered will look flat/semi concave in front and deep concave in rear.
Old Feb 27, 2017 | 06:06 PM
  #1814
voha123's Avatar
voha123
another wheel question,
went to the shop today, guy suggest the following set up
20X10.5 +30 mounted on 255/35R20
Is this an acceptable set up, he did some calculations and said they should fit, I just want to double check
Thanks !
Old Feb 27, 2017 | 06:31 PM
  #1815
the93owner's Avatar
the93owner
Thanks !
Just make sure the wheels will fit over the big brakes. 20x10.5 +30 is fairly aggressive, but if you're lowered I think you can pull it off. You might need to trim some fender brackets for extra clearance. Also the 255 tire will be stretched on a 10.5 wheel.
