Official~Best offsets for running FAT tires!
Old Aug 31, 2016 | 10:28 PM
  #1141
r377's Avatar
r377
I always thought 265 or even a 275 would be perfect fit for a 10inch rear wheel.
I have just checked E63 AMG and Boxster S and they run 285 and 295 on a 9.5 rim....
Old Aug 31, 2016 | 11:31 PM
  #1142
GNTLMN_Z's Avatar
GNTLMN_Z
I have 275/35ZR19 Michelin Pilot Super Sports on my 10.5" rears and it's definitely stretched.
Old Sep 1, 2016 | 08:55 AM
  #1143
The definition of stretched varies from person to person, much like what is flush to one guy might seemed tucked to another, etc. I like to go to the manufacturers web site, look up the particular tire specs and see the factory recommended wheel width range. Any wheel narrower than that range would be considered a pinch, anything wider a stretch. Most tires have a 1.5-2" width range so there is quite a bit of room for an acceptable mount in most cases. ****************Tried looking up the Pilot Super Sports but couldn't find the specs on their site. An example, the Toyo T1Sports on a 275/35/19 lists a 9-11" wheel width with 9.5 being optimal. Keep in mind the closer you get to the widest recommended wheel width the more stable the sidewall will be (typically) https://www.toyotires.com/tire/patte...e-summer-tires
Old Sep 1, 2016 | 08:57 AM
  #1144
Nico-derm's Avatar
Nico-derm
I have 285/30R20 on my 9.5 Rear and am really happy with the fitment.... S-04's are slightly narrower tho
Old Sep 1, 2016 | 12:19 PM
  #1145
GNTLMN_Z's Avatar
GNTLMN_Z
Very true Brad. I believe 275 PSSs are rated for 9.5-11" wheels IIRC. My definition of stretch is a sidewall that angles towards the rim edge even if it's in the manufacturer range.
Old Nov 22, 2016 | 07:24 PM
  #1146
Ko843030's Avatar
Ko843030
Figment Question
Helloooo friends! So I'm about to order a different set and could really use some advice.
Currently on 19x9.5+38 all around and going to buy 9.5 +40's for the rear and either +40's or +22's in the front (all they offer). I've got an 8mm spacer for testing, and the (now with spacer) +30 up front looks great. I can't fit another one in and still have threads, so the +22 is still a mystery.
Tires are all 255-40-19 btw and I'm reusing them. And I'm on Swift springs. I'd love the +22 if possible up front, but I don't want to order wheels and have them powdercoated if 2 end up rubbing.
Thank youuuu
Old Nov 22, 2016 | 07:31 PM
  #1147
Ape Factory's Avatar
Ape Factory
Any way you could snap photos with and without spacers of the current setup? Coupe or sedan?
Old Nov 22, 2016 | 07:45 PM
  #1148
Ko843030's Avatar
Ko843030
Haha! 'Figment' whoops. And sorry, it's a 2011 X Sedan. Forgot to include that. I actually have a few pictures but they're on my phone, which is what I'm typing on. I can try to do the photo sharing thing, or I could email you?
Anyways, the 8mm spacer hardly made a difference. I really want to risk it thinking it'll work, but also don't want to risk it. Mind sending me an email and I'll send the pics? Ko843030@yahoo.com
Old Nov 22, 2016 | 09:05 PM
  #1149
Ape Factory
Sent you an email!
-m
Old Nov 22, 2016 | 09:38 PM
  #1150
If you don't mind the wheel poking outside the fender about a 3/4" those +22s would work. You'd have to flat-roll the front fenders so those 255s won't hit. My 9.5 +38s are about 3mm outside the fender, so those +22s would be out about 20mm. IMO the 9.5 +38s are a flush fit w/ in-spec camber (at least the wheels are flush), you could run more tire to fill the fenders when it's time to replace those 255s, I think that's a better look than poking wheels, but I'm old, lol.
Old Nov 22, 2016 | 10:09 PM
  #1151
Nico-derm's Avatar
Nico-derm
Im with you there ^^^... fitment all depends on your drop and how much camber you're comfortable running. My 9.5+38 fronts aren't "hella" flush but I wouldn't try to fit a +22 on a sedan without expecting to play with the aforementioned variables
Old Nov 22, 2016 | 11:11 PM
  #1152
Ko843030's Avatar
Ko843030
You guys rock! I am on Swift springs though, so my current 9.5 +38's are actually pretty sunken at like -2 degrees of camber. The rears are perfectly flush imo while the fronts are not. Think I have hope at +22 for the fronts then?? Got a local professional fender roller as well that I could use. Thanks for the help! Fingers crossed.
Old Dec 21, 2016 | 10:12 AM
  #1153
r2dmax's Avatar
r2dmax
Originally Posted by zippndots
No rubbing sharp turn,three ppl in the car and angling in nasty driveways!!
Do you have a better side view of your car with this setup? I'm seriously considering going with 18s on mine, but I fear they will look too small for the car. Tossed between 18" and 19s
Old Dec 21, 2016 | 10:34 AM
  #1154
Nico-derm's Avatar
Nico-derm
Did you ever pull the trigger on those wheels? You are running more camber then me and that's one of those "variables" I mentioned for fitment
Post up the PICS!
Old Dec 21, 2016 | 11:07 AM
  #1155
r2dmax's Avatar
r2dmax
On a RWD Sedan, will this squared setup work?
20x10.5 +42
