Official~Best offsets for running FAT tires!
Old Jul 21, 2014 | 02:40 PM
  #826
Originally Posted by Mattimus
Hi guys, I could use your help getting my odd wheel specs into the fat boys club. I was given some 3 piece wheels with a Porsche pattern that I am running adapters for. After the adapters, I will have the below specs:
19x8.5 +21 Fronts
19x9.5 +31 Rears
I'd like to get a set of tires with a somewhat square profile. My coupe will be on coils with camber arms. I figure I could possibly get a 285/30 or bigger rear, but not sure about the fronts. Any help is greatly appreciated.
FWIW, Here is what is going on.
245 or 255/40/19 front 275 or 285/35/19 rear should work well.
Old Jul 21, 2014 | 07:29 PM
  #827
Mattimus's Avatar
Mattimus
Thank you again blnewt. Always so full of useful information.
Old Jul 21, 2014 | 08:44 PM
  #828
Really looking forward to seeing those awesome wheels on your G, it's going to look
Old Jul 31, 2014 | 08:50 PM
  #829
Mattimus's Avatar
Mattimus
Well, here you go. I ended up getting the 255/275 combo. Starting to think I should have done the 285 instead. I just put the coils on today as well. I need to raise them up a tad once I figure out the best way (that rear spring setup is new to me). I also have the legit Racing Dynamics caps on their way. I'll get better pics later. Either way, I hope you enjoy.
Attached Thumbnails Official~Best offsets for running FAT tires!-20140731_191452_zpsal0we1l9.jpg   Official~Best offsets for running FAT tires!-20140731_190829_zpss71jief1.jpg
Old Jul 31, 2014 | 10:16 PM
  #830
Looks great, pretty slammed, maybe a 1/2" higher
Looks like the 275s fit pretty tight, you think there's another 5mm back there for 285s?
Old Aug 1, 2014 | 10:05 AM
  #831
Mattimus's Avatar
Mattimus
I should be able to get another 5mm once I remove the temporary 5mm spacer that's in there (my OEM studs were a little long for the wheel/adapter). That's the max rear setting for the Megan's but I found a way to raise it just a hair. I was too tired at the end of the day to keep going at it. And I still need to get my camber set and all that jazz. Slowly but surely...
Old Aug 2, 2014 | 07:45 AM
  #832
G37Some's Avatar
G37Some
I went with 275s also and starting to think I should have gone wider after seeing some massive 325's on a GTR the other day. with -2* camber like I currently have It looks like i can easily get 295s (at least on the outside clearance) but we'll see after I get the wheels perfectly flat to 0* camber, camber kits arrived yesterday
Old Aug 2, 2014 | 11:48 AM
  #833
MiPwnYew's Avatar
MiPwnYew
Not super aggressive, but I love the 285/30/20 Hankooks on my 10.5" rears.
Old Aug 9, 2014 | 12:32 AM
  #834
Ryne's Avatar
Ryne
The Steering Wheel Guy
I don't think you want to go zero degrees camber in the rear since that is outside OEM spec. Rear camber should be between -0.75 and -1.75. Zero camber in the rear would have a "negative" effect on handling.
Old Aug 10, 2014 | 03:44 PM
  #835
kdawg8526's Avatar
kdawg8526
time for new tires i currently running 275/35/19 on a 19x10+30 and it just barely clears by a couple millimeters i wanna go 285/35/19 im currently -1.7 degrees of camber how much more camber do you guys think ill need to push to make it work. its for a sedan btw
Old Aug 10, 2014 | 04:58 PM
  #836
Assuming you're going w/ the same brand & model of tires going out another 5mm you'll need camber in the -2.5 range give or take. If you go to a different brand/model tire it could be a fair amount wider/narrower so hard to say
How come you don't want to stay w/ your 275s that currently sound like a perfect fit?
Old Aug 10, 2014 | 07:40 PM
  #837
G37Some's Avatar
G37Some
I also have 19x10+30 and 275/35/19 hankook ventus v12 evo2. I'm dropped about 1.2" in the back and I know for sure I can fit 285s without rubbing... currently I'm at -2* camber exact. fwiw I have a coupe though.
...clearance will be tight though.... less than a pen cap.
Old Aug 10, 2014 | 09:44 PM
  #838
Ryne's Avatar
Ryne
Apples to oranges really. You have more camber than he does and he has a sedan. If you are saying your clearance would be that close, he would be hitting the fender with the same camber/tire specs. Camber would need to be increased to the 2.5-3 degree neighborhood. It seems like it would make sense to stick with what has been working, especially considering you are in OEM specs for camber and are maximizing tire life.
Old Aug 10, 2014 | 09:55 PM
  #839
kdawg8526's Avatar
kdawg8526
i guess for braggin rights wanted to go wider. but guess i might just stay 275's tires are gonna be different. right now im running bridgestone potenza re050a horrible treadwear i was gna go continental dw
Old Aug 10, 2014 | 10:13 PM
  #840
G37Some's Avatar
G37Some
yeah disregard that then.. when I wrote that I wasn't thinking the sedan had different clearance.
