Official~Best offsets for running FAT tires!
Old Jun 27, 2014 | 05:42 PM
  #796
rays's Avatar
rays
Originally Posted by Linwozzle
295 rear
Old Jun 30, 2014 | 03:09 PM
  #797
FrozenBloodPump's Avatar
FrozenBloodPump
Figured I'd post up.
Gram Light 57xtreme's
19x10.5 +43 305/35 R19
19x9 +35 255/40 R19
Tires:
Rear - Nitto NT05R
Front - Nitto Invo
No rubbing, no grinding. Just bolt and go. You'd probably have to cut down the rear bumper mounting bracket if you haven't already.
Camber is within spec at all four corners.
Old Jun 30, 2014 | 04:40 PM
  #798
Thats pretty balla!^^^^
Big 'ol drag radials too, nice job!
Rear fenders rolled?
How much clearance do you have from the inner lower arm to the tire?
Old Jun 30, 2014 | 05:29 PM
  #799
FrozenBloodPump
Just the factory roll. plenty of clearance from the lower arm. The bolt however is closer. There is about 3MM of clearance. I drove it hard around some tight bends and the tire didn't flex enough to rub.
If you want to run 305's, this is the setup you want. +43 on the offset and no wider than 10.5.
Old Jun 30, 2014 | 06:15 PM
  #800
G37Some's Avatar
G37Some
305 is crazy. wow. drag radials none the less...
*claps*
Old Jun 30, 2014 | 07:23 PM
  #801
Are the 37 coupes' flat-rolled like the sedan in the back? I know the 35 coupes weren't so that's what I was going by.
Awesome combo, bet that bad boy sticks like roofing tar
Old Jun 30, 2014 | 07:42 PM
  #802
FrozenBloodPump
Yeah, Infinti hooked us up in that regard. Those tires stick like nobodies business but I'll be buying 1-2 sets a season.
Old Jun 30, 2014 | 07:46 PM
  #803
kdawg8526's Avatar
kdawg8526
thinking about what spacers to get for 19x9 +47 will 20mm clear the front fenders 245/40/19 i know 15mm will work for sure
Old Jun 30, 2014 | 08:13 PM
  #804
Robert_K's Avatar
Robert_K
Looks great!
Old Jun 30, 2014 | 09:18 PM
  #805
FrozenBloodPump
20mm spacers will put you at +27. A lot of folks (including me) run the vossen +25's on 245's. They clear (barely) but you have to be careful of hitting bumps with the wheels turned. You will hit your fender and bend them depending on how low you are.
Old Jul 1, 2014 | 02:54 AM
  #806
rays's Avatar
rays
19x9 +35 255/40 R19
Tires:
Rear - Nitto NT05R
Front - Nitto Invo
This is the setup I want what are you lowered on?
Old Jul 1, 2014 | 10:19 AM
  #807
FrozenBloodPump
I'm on KWv3's
Old Jul 1, 2014 | 02:10 PM
  #808
I'm on KWv3's
BTW, looks like there's quite a bit of fun in your garage, nice
Old Jul 2, 2014 | 12:31 AM
  #809
Diego@Vossen's Avatar
Diego@Vossen
Natalie is tucking 305/25/20 on her G sedan now
20x9.5 +25 255/30/20 & 20x10.5 +45 305/25/20
More pics to come. The fitment is very tight, I was concerned it was gonna lay on the fender but tucks perfectly. At normal drive height there is no rubbing at all which surprised me lol.
Old Jul 2, 2014 | 02:44 AM
  #810
kdawg8526's Avatar
kdawg8526
that's sick whats the rear offset on wheels
