Official~Best offsets for running FAT tires!
Old Jan 8, 2014 | 07:33 PM
  #661
Originally Posted by pebkac
So, what you're really telling me is that I can't run 20x10.5 all the way around on swifts for my sport sedan right?
I'm fine with using hubcentric spacers, but wanted to avoid alot of negative camber. I dont plan on going lower than what the Swifts offer.
Please help
Alternative solution: What wheel and tire spec will have the most concave that I can safely drive an unstretched tire?
Here's an example of a couple 19x9.5 +40 that have decent concave, you could order 4 of them and run 255s on them for just a slight stretch
B2 Auto Designs
B2 Auto Designs
Old Jan 8, 2014 | 07:45 PM
  #662
pebkac's Avatar
pebkac
Thanks all.
I think that I'm going to go with 20x9 +32 245/35/20 / 20x10.5 +45 275/30/20
I have a silver G37 sedan, and I think it will look close to this on Swifts right?
Lexus IS on VVSCV7 Wheels
Old Jan 8, 2014 | 09:15 PM
  #663
dkmesa350z's Avatar
dkmesa350z
Thanks all.
Not sure what you're asking, but with the setup you've described, you will be a good bit taller and less flush than the IS with much less stretched tires. Would look good though. I'd go 255/35 and 285/30 but I like a meaty sidewall.
Old Jan 8, 2014 | 10:13 PM
  #664
Agree w/ dk, you'll be about an inch higher but will be a good fit and look nice, and also I'd go w/ 285s too
Old Jan 9, 2014 | 10:40 AM
  #665
pebkac's Avatar
pebkac
I don't like meaty sidewalls...I love the sleek look.
What other reasons should I take your tire suggestion over what I posted?
And seriously...thanks guys!
Old Jan 9, 2014 | 11:35 AM
  #666
On a 20" wheel all the sidewalls from a narrow 225 to a 305 wide tire will be the same height (if you buy the right size tires w/ the same diameters), the sidewall series will be different but the sidewall height will be roughly the same.
For example my 245/35/20s have the same sidewall height as my 295/30/20s.
The main benefit of going wider out back is the car will feel more firmly planted and it really looks nice and aggressive.
Old Jan 9, 2014 | 12:38 PM
  #667
pebkac's Avatar
pebkac
Ok guys, I'll go with your suggestion of 255/35 and 285/30. I hope it sits well with Swifts..does anyone have pics of reference to a setup like that?
Old Jan 9, 2014 | 01:36 PM
  #668
dkmesa350z's Avatar
dkmesa350z
search for Robert_K's setup. I believe he has those tire sizes or similar and his wheel specs are very similar. Also on swift springs.
Old Jan 9, 2014 | 01:52 PM
  #669
pebkac's Avatar
pebkac
Robert_K is on Swifts, but his setup is 19x9.5 +40 & 19x10.5 +45
Old Jan 9, 2014 | 06:06 PM
  #670
Robert_K's Avatar
Robert_K
Correction… I'm a 19x9.5 +40 w/ 5mm spacer netting a +35.
Old Jan 10, 2014 | 02:46 AM
  #671
mezzo's Avatar
mezzo
Green Eyes!
Been a while. Got the wheels on bout a month back finally. Theres a pic of them on the work site. Im the LP sedan G bout mid way down the page.
i put in WORK » Gnosis Series
few more pics from the shop on their site as well
http://dyno-comp.com/blog/2013/11/g3...-at-dyno-comp/
Soooo, my rears poke just a tad. We ended up going with the +40 in the end. I suppose thats why.
Rears seem to camber out a bit as well. It was aligned at the time and everything looked in spec though from what i was told.
Im thinking of having another alignment done to see if the springs settling have changed things. Im going to get a alignment report this time and share it here for feedback.
Anything i can do to get the rears to tuck in just a tad? Its really a very minor poke when i look at it so if not its not a big deal. Im considering a set of coilovers at this point as well because the drop in the front isnt where i would like it. Any recommendations? Dont want to go crazy money wise on them since im already in on the eibach springs but definitely willing to purchase something worth while
And..Changing out my ark exhaust and stock cats for a full FI setup with RHFC's tomorrow!
3.7 gears, quaife differential and a full tune next month.
Old Jan 11, 2014 | 11:58 PM
  #672
OMG_ROTFLOL's Avatar
OMG_ROTFLOL
Somebody say fat tires..YEAH ! !
Fatest tire ever mounted on a G
305/30/20 +45 Michelin Pilot Super Sports , fender to ground 26.25"
255/35/20 +32 Michelin Pilot Super Sports , fender to ground 26.00"
Old Jan 12, 2014 | 12:11 PM
  #673
Dyno-Comp - Blog
The poke looks acceptable from the pics I saw, a +45 offset would have been better but +40 and a bit excess camber should get you down the road without trouble.
As far as coils, the mid-priced Stance coils (about $1050-$1100) get good reviews and have the OEM or true single coilover rear setups to choose from. Do you have the F&R camber arms & rear toe kit, if not that's something I'd recommend, especially if you lower some more w/ coils.
G looks nice BTW
Old Jan 12, 2014 | 12:13 PM
  #674
Welcome to the club OMG, rocking the 305s puts you at the podium
Old Jan 12, 2014 | 05:33 PM
  #675
Staggered357's Avatar
Staggered357
Damn that **** sits fire... I need a g.. Maxima not enough space in rear to do that...
