Official~Best offsets for running FAT tires!
Old Apr 22, 2013 | 03:28 PM
  #346
xorbitman's Avatar
xorbitman
AWD with different size spacers and tires?
Originally Posted by LegitMW
How'd you clear the back brakes with an O disk . Is your offset including spacer specs?
Did I read this right? You have an Coupe X AWD and you went with such an aggressive set-up? Is this not recommend for X drive? From what I hear you need to be careful on an X drive as you can really screw up the x drive system and it's costly to repair. Not to mention that your highway ride could be dangerous according to some?
Old Apr 22, 2013 | 03:30 PM
  #347
xorbitman's Avatar
xorbitman
Different tire sizes on an AWD?
Originally Posted by idajones
Hi would this fit in this thread?
Specs are front = 20 X 9.5 +13 R-Disk / rear = 20 X 10.5 +16 O-Disk
Work Gnosis -Gs2 in BKB (burning black)
Tires are Hankook V12's 245/35-20 and 285/30-20 my car is AWD. Rear Fenders were pulled about 1/2 cm and running -1.5 camber front and -2.00 camber rear. May lower and camber rears more but I am happy with the setup right now.
Car runs nice - ride is actually smoother that my winter setup on Blizzak's and stock 18's I'm also dropped on BC coils (for the time being - looking into a custom coil/cup kit in the future).
Sorry car was a bit dirty but it is all washed up now!
Old Apr 23, 2013 | 04:17 PM
  #348
idajones's Avatar
idajones
So... wanted to post more pictures but got flooded with a massive rainstorm last week and car's even dirtier than ever (but no engine/flood damage luckily!) I'm planning to take it to my buddy to get it washed and detailed either this weekend or next.
Hey xorbitman I believe this is okay I've done a lot of research on the AWD and running a staggered/aggressive set-up. Basically, as long as the wheel rolling diameters are the same they are okay. I am running 245/35 and 285/30 as mentioned earlier and the difference is minimal (about (-0.07%)).
If another member can chime in if I posted anything incorrect that would be great! I know there aren't as many AWD models as there are sports.
Thanks!
Old Apr 23, 2013 | 11:51 PM
  #349
xorbitman's Avatar
xorbitman
Thumbs up Awesome set-up
How are you able to drive over speed bumps without bottoming out?
Thanks!
Well I have admit it looks awesome and if it works that's amazing. I guess the one thing that we have in our favor with respect to x is that unless you use the snow mode, the regular mode of our system starts as a rear wheel drive and progressively shifts the power to the front if there is a loss of traction.
How much did you drop the car by and on your BC coils? I would love a K-sport coil-over that uses a bladder system as air suspension that is controlled by computer (Digital). Goes up 2"in 1 sec...the whole 4" in 2 - 4 seconds depending on weight. That's much better than traditional bladders cause there is a maximum drop that is inherent in the way its designed. The car will never touch the ground even if the compressor is empty. The stay at the height that you program in. And you can raise it over speed bumps in parking lots and high curbs etc. Also since you're on coils, are you able to raise yours for winter driving? In Canada, the xS model comes with 19" Enkei wheels. 9J in the rear. I'm thinking of eventually going with wider tires once the OEMs are worn out and lowering them on coils just an 1"drop just like the drop on springs so I won't rub and won't need a camber kit. So I was wondering what you think of this: 15 in the front and 20 in the rear H & R wheel spacers? Do you thing I could 20 front and 30 rear or is to aggressive?
Old Apr 26, 2013 | 10:54 PM
  #350
Robert_K's Avatar
Robert_K
Just wanted to share my Forgeline's shipped today! TIA.
Old Apr 27, 2013 | 08:25 PM
  #351
Parad1gm's Avatar
Parad1gm
2012 G37x
20x9 +35 / 20x10.5 +45 Incurve S5's
245/35/20 front, 285/30/20 rear
Mild drop on Swift Springs
Old Apr 27, 2013 | 08:59 PM
  #352
Chevyboy_Erik's Avatar
Chevyboy_Erik
Originally Posted by Parad1gm
2012 G37x
I hate you....
Thats the exact same wheel set-up i want for my sedan >
Looks real nice btw
Old Apr 27, 2013 | 10:48 PM
  #353
Robert_K's Avatar
Robert_K
Looks great Parad1gm!
Old Apr 27, 2013 | 11:53 PM
  #354
Parad1gm's Avatar
Parad1gm
Originally Posted by Chevyboy_Erik
I hate you....
Looks real nice btw
Thanks guys! Appreciate it!
Old Apr 28, 2013 | 10:35 AM
  #355
Glad to see you made it to the "FAT" side, welcome & car's looking
Old Apr 30, 2013 | 02:43 PM
  #356
adilxxr's Avatar
adilxxr
hey fellas new to the g37 scene but looking to make a few upgrades this year. I have a new set of t1s 20x9.5 F &20x10.5 R offset 25mm all round. what would I have to do to fit this on an 08 coupe without rubbing and ride issues ( tires, camber, rolling, etc).. I also have an order in for some BC/BR coils for a drop or should I just do springs. wanna drop about 1-2" all round. advice much app...DOMO
Old Apr 30, 2013 | 05:14 PM
  #357
Depends on the tire width, but those offsets look pretty good for the coupe. Not sure how wide you can go w/ that offset, hopefully one of the coupe guys can chime in.
Coils FTW, you can get just the height you want and have some flexibility in damping force.
BTW, welcome!
Old Apr 30, 2013 | 05:34 PM
  #358
kdawg8526's Avatar
kdawg8526
parad1gm did u need a camberkit?
Old May 2, 2013 | 02:58 AM
  #359
jktinen's Avatar
jktinen
can anyone suggest a setup for an 09 x sedan lowered on swifts? I was thinking TSW nuremberg 19s. Want to keep it square but FAT
Old May 2, 2013 | 03:12 PM
  #360
ScrewstonNismo's Avatar
ScrewstonNismo
Originally Posted by Roland958
Here's mine
09 journey sedan
370z rays forge sports rims.
F 19x9 + 20
R 19x10 + 30
Tires:
F 245/40R 19
R 275/40R 19
Suspension:. Eibach spring
WHAAAAT! That looks ballin'!
