*SOUND CLIP* of the Infamous Muffler Rattle
Old Apr 29, 2008 | 02:24 PM
  #106
madmikeg37's Avatar
madmikeg37
Talking new muffler build.
Originally Posted by Ahujadaddy
yeap, thanks. was it you who originally posted about the new build after gettin off the phone with consumer affairs?
Yes it was me, finally someone who believes me.
I told you guys about that februrary build date.
Thank goodness for INFINITI customer service, I would still have the same rattle.
(It's kind of ironic I have an FI cat back & pss hfc's on order)
so it's goodbye crappy muffler.. hello sweetness.
Old Apr 29, 2008 | 06:40 PM
  #107
Ahujadaddy's Avatar
Ahujadaddy
^^ right on bro! gonna go same route once i get a NICE "February build" muffler.
Will post after i get the muffler put on tomorrow morning... i have a bad feeling like something will go wrong tho =(
Old Apr 30, 2008 | 02:59 PM
  #108
tmartin316's Avatar
tmartin316
ahujadaddy - which dealer do you go to?
Old May 6, 2008 | 04:18 PM
  #109
Ahujadaddy's Avatar
Ahujadaddy
^^hey man, was nice seein u at the meet the other day. Didnt get a chance to hang out much, did u arrive late?
I went to IoA -- Talk to Tracy in the Service Dept... Pat is the Tech that works on my car.
Old May 6, 2008 | 06:09 PM
  #110
shabbo's Avatar
shabbo
I get the same muffler rattle on a cold start at about 1100 rpm everytime. Peninsula infiniti dismissed the problem because they were not able to reproduce it.....obviously because they could not reproduce a cold start. I"m going to have to leave the car there overnight and start the engine in front of them.
It's not a performance limiting issue....but sounds aweful when it happens. I'll probably change the muffler to an aftermarket dual. But I don't like the Riceout look so whatever it is, it has to be tasteful...
Old May 8, 2008 | 02:34 AM
  #111
beestea's Avatar
beestea
I took my G37 in once for the rattle sound while idleing and the dealer just "adjusted some of the heat shielding" which did nothing and obviously I still have the issue. I've been waiting to see if they have a fix before I take my G in to service again, and obviously there still isn't a fix.
I noticed that whenever i turn my car off, it TICKS like crazy, for at least 30second to a minute... I am pretty sure its coming from under the car and not the engine. The sound is identical to the rattle i hear when the car is idleing.
My question is, is it possible that the metal used on the exhaust is some really cheap, lightweight aluminum that is constantly heating up/cooling even when the car is running causing the ticking/rattle.
Im just thinking this because I've never heard a car tick so much after shutting it off as my G37, and the two sounds are so similar.
Old May 8, 2008 | 09:28 AM
  #112
tmartin316's Avatar
tmartin316
yea for sure --- i got there really late (2pm), was at a wedding... and then i wasnt able to make it up to CP (not sure if you went)
maybe next time!
Old May 14, 2008 | 05:28 PM
  #113
jjgarrot's Avatar
jjgarrot
Angry Me too, brutal (bad pun)
I'm taking my car in Friday to have the same problem fixed. Mine was a sort of a buzzing vibrating noise, primarily in the morning when the car was warming up and the engine was idling at around 1300 rpm.
I'm wondering if there's actually a "defect", or if the higher compression and increased HP on the G37 is too much for what is likely the same exhaust system as the G35.
I'm going to let them replace it, but I plan to look into a custom system soon. Any recommendations would be much appreciated.
John
Old May 15, 2008 | 08:52 AM
  #114
tmartin316's Avatar
tmartin316
my dealership just let me know yesterday that my new part came in (it is indeed the new part number) and I can come in anytime to have it installed... can't wait! hope it fixes it for good this time...
Old May 16, 2008 | 04:36 PM
  #115
KAHBOOM's Avatar
KAHBOOM
Super Moderator of Pwnage
John
The muffler/ exhaust system on the G35 is different than the G37.
The G35 had just a single inlet to the muffler and a single midpipe. The G37 has a dual midpipe and muffler inlet from the y-pipe back.
Old May 16, 2008 | 10:54 PM
  #116
jjgarrot's Avatar
jjgarrot
Thanks
Thanks, I appreciate the info. FYI - The problem must be fairly pervasive. When I dropped my car off this morning, the service rep looked at my paperwork and said "Oh good, your parts are already here. They're now on back-order; I know this because I had to order two more this morning and I could only get one."
Did you hear that they're going to be coming out with a bi-turbo version next year? Supposed to be a 500 HP monster, 0-60 in under 4 seconds.
Old May 19, 2008 | 04:35 AM
  #117
MaDd's Avatar
MaDd
sigh... my exhaust note is progressively getting worse.. at first i only heard it for a bit in my garage when the sound echoed.. then i started noticing it outside, today i warmed the car up for 20-25 seconds and drove off.. i heard the noise for almost a minute while driving with the music on. later tonight, i heard it while parking after driving on the freeway for an hour
damn you infiniti!! gonna make a video clip tomorrow
Old May 19, 2008 | 01:31 PM
  #118
Kevo111's Avatar
Kevo111
Weird Exhaust Sound
Almost every time I start my G37 the exhaust makes a weird sound. It sounds like a rattle or something like a ping. It also makes this sound when I accelerate.... I was wondering if anyone has had this problem or heard anything about it.... Thanks
Old May 19, 2008 | 01:34 PM
  #119
KAHBOOM's Avatar
KAHBOOM
umm
https://www.myg37.com/forums/showthr...wpost&t=180963
Old May 19, 2008 | 01:35 PM
  #120
SOLISIMO's Avatar
SOLISIMO
Welcome to the board. Do a search for exhaust rattle, you will find hundreds of threads on this. Long story short its a defect from the factory which they will warranty but many are having to go several times as the replacements end up rattling too.
