View Poll Results: What brand of oil do you use in your G coupe/sedan?
Motul (300v or 8100)
56
4.06%
German Castrol
44
3.19%
Amsoil
46
3.33%
Redline
49
3.55%
Royal Purple
79
5.72%
Mobil 1 Synthetic
653
47.28%
Pennzoil Platinum
133
9.63%
Valvoline SynPower
31
2.24%
Eneos Synthetic
22
1.59%
Quaker State
0.72%
Lucas Oils (synthetic)
0.43%
Schaeffer Synthetic Oil
0.29%
Nissan Ester Oil
171
12.38%
Conventional 5w30 "dino oil"
77
5.58%
Voters: 1381. You may not vote on this poll
The DEFINITIVE oil thread
Old Feb 11, 2011 | 11:44 AM
  #376
Fezzik's Avatar
Fezzik
redline here as well.
Old Feb 11, 2011 | 12:02 PM
  #377
123u's Avatar
123u
I did my first oil change was at 3500 miles using regular oil at the dealership. $50 buck with 5% discount. same here the oil is still not dirty...almost as good as new. 5000 mile interval synthetic oil change is reasonable the way i see it. definitely going with mobil 1 5w30 fully synthetic DIY route.
Old Feb 11, 2011 | 12:10 PM
  #378
Merged. Again.
Old Feb 11, 2011 | 12:38 PM
  #379
moonsky's Avatar
moonsky
Originally Posted by Chris11LE
Spoke to my dealer last week about this, he asked what year car I had (2011) and said that for 2011 its not required. Assuming that he meant other years it might have been required, I checked the owners manual for 2010 and noted the same text as in the 2011 manual: Nissan suggests using <yada yada="">
Maybe we spoke to the same dealer (Beshoff). My question was more focused on the prepaid maintenance plan. He told me that the plan used to include Nissan Ester Oil for 2010 and older G37 models, but they removed that coverage when the 2011 models came out.
One technical paper I found claims that ester-containing (1% by mass) PAO-base 5W30 oil combined with the non-hydrogenated DLC coating used in the VQ37VHR engine produces super low friction. The same low friction is not observed when using different DLC coating, or different oils (conventional or PAO without ester) with the same coating. From all reports, the Nissan Ester Oil is conventional oil with ester additive, so it's likely that it's the added ester not the base stock that makes the difference. Since the amount of friction without using ester-added oil is not higher than normal, I think it makes sense that Infiniti is not requiring but only recommending it.
</yada>
Old Feb 13, 2011 | 01:55 PM
  #380
Steveo47's Avatar
Steveo47
Using motul 8100xmax right now. Does not fix the vvel tick. Gonna try 300v when it warms up
Old Feb 25, 2011 | 04:21 AM
  #381
briann510's Avatar
briann510
I cant believe how many people apparently still use Mobil1.
Old Feb 25, 2011 | 06:23 AM
  #382
Chris11LE's Avatar
Chris11LE
Yeah the m1 thing surprises me too....i think the best m1 for our cars is the 0w40 but I don't want to run that while the car is under warranty.
I agree the ester thing is an additive not base stock...valvoline and pennzoil have said two of their products meet or exceed nissans requirement and those products are not ester based so it must be something in their additive packs
Old Feb 28, 2011 | 12:06 AM
  #383
anorudo619's Avatar
anorudo619
advisor at infiniti informed me that ester is no longer required. it has to do with reprogramming your computer which eliminates the ticking. dealer use a syntec blend; review the code on your maint doc
Old Feb 28, 2011 | 07:56 PM
  #384
Steveo47's Avatar
Steveo47
^^ it was never required, it just stopped the ticking noise
Old Mar 13, 2011 | 07:14 PM
  #385
novaleadfoot's Avatar
novaleadfoot
just switched to PP 5w30...dealership uses Castrol synthetic blend for their regular oil...for premium oil change, they use Nissan Ester or PP
Old Mar 29, 2011 | 12:49 PM
  #386
tbone8801's Avatar
tbone8801
I've used the Nissan ester oil after the dealer ship service manager told me they had knocking problems with this engine in europe with non ester-oil products, but he wasn't for sure if this was accurate and I always take the dealership with ??.
Old Mar 31, 2011 | 05:00 PM
  #387
superleggera's Avatar
superleggera
Redline is the best of both worlds
Fully synthetic and is ester based like like nissan ester oil.
Old Jun 21, 2011 | 08:17 AM
  #388
FastassG37's Avatar
FastassG37
What's the vvel tick ??
Old Jun 21, 2011 | 08:18 AM
  #389
FastassG37's Avatar
FastassG37
What's wrong with mobil 1
Old Jun 21, 2011 | 08:21 AM
  #390
FastassG37's Avatar
FastassG37
I was told by dealer to use regular cheap oil. That was the best for the motor
