Old Mar 7, 2022 | 03:35 PM
  #8956
JSolo's Avatar
JSolo
Just say no!!!!!
^^Nice hold down
Old Mar 7, 2022 | 03:38 PM
  #8957
backman_66's Avatar
backman_66
Made it nice n easy,
Old Mar 7, 2022 | 03:43 PM
  #8958
JSolo's Avatar
JSolo
Just say no!!!!!
^^So total weight saving ~#100 give or take. Can you actually notice that in driveability? The car is what, #3700 or #3800 overall. I can see things like the flywheel making a difference as you're directly connected to it via right foot, wheels maybe?
Have you done anything to the rear end? I bet shorter gears would make a pronounced difference.
Old Mar 7, 2022 | 03:48 PM
  #8959
backman_66's Avatar
backman_66
I believe the 6MT sedan is one of the lightest models and I think it weighs in the 3,600's stock. I definitely felt a difference with the lighter wheels, and now with all of the combined weight savings so far, it does feel less shifty overall. I do plan to get z1's new 4.09 final drive too It's on the list! I may try to do it all at the same time - clutch, flywheel, 4.09's, diff brace. But the brakes come first, they're in really bad shape right now. And I just ordered an FI exhaust in February.
Old Mar 7, 2022 | 03:49 PM
  #8960
RobC7's Avatar
RobC7
I heard great things about the anti gravity battery, it's a bit pricey but a cool upgrade nevertheless.
Old Mar 7, 2022 | 04:12 PM
  #8961
Curb weight on the 2013 6MT Sedan is 3709 pounds.
https://www.infinitihelp.com/models/...ifications.php
Old Mar 7, 2022 | 04:21 PM
  #8962
backman_66's Avatar
backman_66
Nice thank you for the correction! So my car would end up in the low-to-mid 3500's when all is said and done. I'm pretty happy about that for the class the car is in.
Old Mar 7, 2022 | 10:33 PM
  #8963
Disconnected AW's Avatar
Disconnected AW
Aftermarket parts.
Does anyone know where someone can get g37x09 sedan aftermarket parts at?
like a simple catback?
i can't find a single aftermarket part period.
Old Mar 7, 2022 | 10:38 PM
  #8964
iCrap's Avatar
iCrap
Have you tried google? There are literally hundreds of parts available.....?
Old Mar 7, 2022 | 10:56 PM
  #8965
AnotherVQ's Avatar
AnotherVQ
I tried to put clamps on my pcv hoses and couplers but I discovered this:
Also 63-71mm clamps didn't fit on my couplers so I have to return them and order 70-80mm clamps.
Old Mar 8, 2022 | 11:38 PM
  #8966
AnotherVQ's Avatar
AnotherVQ
Originally Posted by thescreensavers
Yup! It's an aftermarket exhaust so fitment can vary and from your pic the left tip isn't that much further out, there really isn't a way to adjust that. You can try loosen all the flanges and see if any adjustment helps that but nothing really directly to tweak it.
The exhaust will expand when hot, see what the tips look like once you drive it for a bit.
Tried to suggest this at the part that is relevant but they said the bushing isn't stiff enough and put in a stiffer one. Then they bent the exhaust with a bar. It seemed like it was fixed, and as you can see it's further from the sway bar now:
But after I got home I heard more rattling .
So I was moving the mufflers/tips around and I added some cut up plastic cards in that spot you circled as an example. It seemed to lessen it and I started noticing sound on the right side too so I added more to the left and added some to the right. I didn't have a lot of time to check because of work but I think the issue is resolved. I wouldn't mind a neater solution but I don't think the cards will fall out or get too hot based on the location and it's hard to even see these unless you're looking for it so it will probably be fine long-term.
Below is an image before I added a little more:
Old Mar 9, 2022 | 12:56 PM
  #8967
AnotherVQ's Avatar
AnotherVQ
Alright, here's a cold start and rev with the new exhaust setup. I will provide more videos after retune.
https://i.imgur.com/6d3hjSd.mp4
Old Mar 9, 2022 | 01:11 PM
  #8968
I wish you wouldn't C&P your comments into multiple threads.
Old Mar 9, 2022 | 02:11 PM
  #8969
AnotherVQ's Avatar
AnotherVQ
One is a build thread and one is a mega thread and both serve similar purposes.. I can re-word things slightly for you, I guess?
Old Mar 22, 2022 | 09:32 AM
  #8970
backman_66's Avatar
backman_66
I have joined the club, just waiting on a good day to install.... Front and rear 2-piece and Centric Posi-Quiets to go with them.
