Old Jan 14, 2020 | 02:52 PM
  #7501
iCrap's Avatar
iCrap
I think I put it on in 2017? It wasn't like that only a few months ago, I know that for sure since I had taken it off to remount it (one side had started to lift).
So not really sure what happened. It does see a lot of sun now, my current work parking lot has no garage and barely any shade.
Old Jan 14, 2020 | 02:55 PM
  #7502
2GoRNot2G's Avatar
2GoRNot2G
Originally Posted by iCrap
It was almost 70 today, so decided to finally wash my car and clean up the inside a bit. Start it up, sounds like a tractor, WTF! there is a buzzing noise coming from the Y pipe area, i sprayed soapy water all over it and I can't see any bubbles so not really sure where it's coming from. Might just replace the Y pipe... it's the only original part of the exhaust left at this point. Any suggestions?
Also noticed the carbon has started to (crack?) on the ebay decklid spoiler. That sucks.
Did you have someone apply a quality clear coat on this before installing it? With most carbon fiber parts, the manufacturer supplies the parts with just the resin finish coat and not a UV resistant final clear coat. Since you are going for that bare carbon fiber look and aren't painting these parts, it is very important to have the parts clear coated with quality UV resistant clear coat. I have Carbon Fiber parts from several different manufacturer's on my car and I asked all of them when I purchased the parts if they were clear coated and the only one that had a final clear coat finish from the factory was my AutoKitsX rear diffuser. So I had my paint guy clear coat all of my carbon fiber parts before I installed them.
It doesn't look like the part in your photo is delaminating yet, so I would think that it could be cleaned up (wet sanded & buffed out) and then clear coated and it should look as good as new.
Old Jan 14, 2020 | 03:19 PM
  #7503
iCrap's Avatar
iCrap
No, i just installed it as is. I'm going to pull it off and sand it down an clear it, i still have some automotive clear left from when I did my bumper
Old Jan 14, 2020 | 06:16 PM
  #7504
2GoRNot2G's Avatar
2GoRNot2G
Just be very careful not to sand all the way through the resin and into the carbon fiber weave. If you hit the carbon fiber when sanding then it will be very noticeable even after you clear coat it.
Old Jan 14, 2020 | 07:03 PM
  #7505
KImChee's Avatar
KImChee
Installed my Infiniti Illuminated Door Sills tonight
Old Jan 14, 2020 | 07:32 PM
  #7506
That's pretty cool. Can't deny it.
Old Jan 15, 2020 | 02:44 PM
  #7507
OldG2NewG's Avatar
OldG2NewG
Started tearing down these wheels. Got some ideas but not sure what I want to do with them color wise.
If I hydrodip them the possibilities are endless lol
Old Jan 15, 2020 | 04:59 PM
  #7508
That looks like a fun project.
What are your options with the 35 little wheel bolts? Is that even a thing? I think it would have to be. You know... style, finish, weight, compound... stuff like that.
Old Jan 15, 2020 | 05:07 PM
  #7509
OldG2NewG's Avatar
OldG2NewG
Yeah there are quite a few finishes for the bolts like polished and gold but I'll probably keep them black for cost purposes.
Old Jan 15, 2020 | 07:37 PM
  #7510
hjmata07's Avatar
hjmata07
Installed interior LEDs and carsmo *****
Old Jan 15, 2020 | 08:02 PM
  #7511
ngolbuff's Avatar
ngolbuff
Originally Posted by RobC7
Did you have a washer on it?
I installed everything they provided me. The lower bolt went on just fine. The second bolt above it went in and came to a stop about 1/8" from being snug. Backed it out and the end was rounded off from hitting the backside stop of the diff. Nothing against Bell, I just ended up using the stock bolts just fine and discarding the long ones they provided me.
Old Jan 18, 2020 | 03:53 PM
  #7512
hexotic's Avatar
hexotic
DIY Cheapskate/Mod
Originally Posted by ngolbuff
Fits great and my Easy Flow oil drain fits inside the opening perfectly.
Thanks for showing me the drain plug, ordered one instantly,
Old Jan 19, 2020 | 11:54 PM
  #7513
Huaniitoo's Avatar
Huaniitoo
Originally Posted by PNW_IPL
New look unlocked. These wheels are so light in compare.
what's your wheel setup? its sooo clean
Old Jan 20, 2020 | 04:11 PM
  #7514
KImChee's Avatar
KImChee
I replaced my clock with a junkyard clock, and now it illuminates again.
Old Jan 20, 2020 | 08:51 PM
  #7515
ngolbuff's Avatar
ngolbuff
Its been one of the better purchases for the cars for my house. Sure, people may complain that it is a little slower which is true. I take that time to check tire pressures, clean up the inside, grab a cold drink, etc.
