Old Sep 20, 2019 | 01:35 PM
  #7186
jaydee23's Avatar
jaydee23
Wash clay and mothers cmx
Quite happy with both the ease of application and the results of mothers cmx. It's really dumb proof. Not sure about applying it on a wet car though. Seems odd to me. I applied it on clean and dry car.
Old Sep 20, 2019 | 10:27 PM
  #7187
PNW_IPL's Avatar
PNW_IPL
RAri got tints today!
Old Sep 21, 2019 | 10:32 AM
  #7188
Nice pic. Wide angle, everything open, clean and colorful. Very cool.
Old Sep 21, 2019 | 08:46 PM
  #7189
SupraOfDoom's Avatar
SupraOfDoom
En and I met half way and now I have my car back from Thaitanium. Video clips tomorrow I in the exhaust thread I think .
Old Sep 21, 2019 | 08:58 PM
  #7190
jaydee23's Avatar
jaydee23
Thanks Rochester
Installed Cusco bar today after reading the rediculous amount of almost pointless threads on here about the installation.
Anywho...
And the Japanese directions don't really say much translated..
Old Sep 21, 2019 | 10:21 PM
  #7191
SupraOfDoom
I didn't think instructions were necessary...
Old Sep 22, 2019 | 10:09 AM
  #7192
PNW_IPL's Avatar
PNW_IPL
The right side bracket can be tricky with that wire loom. Love the cusco bar. Hows it feel?
Old Sep 22, 2019 | 02:50 PM
  #7193
iCrap's Avatar
iCrap
I had my car aligned by a new shop, which actually works on modified cars as opposed to the regular chain tire shops. They asked me what I wanted to do with the alignment / if i wanted OEM specs and I said just do what you think is best for performance as long as it tracks straight, this is what they gave me: Good / bad? It seems to handle well and track straight
ALSO, I did the epoxy diff bushing fix. However I was only able to get any into the lower part of the bushing, not the upper part. I assume that's all that matters. Has anyone else that did this fill up both parts of the bushing?
Old Sep 22, 2019 | 03:09 PM
  #7194
jaydee23's Avatar
jaydee23
I had zero issues with install
Both sides the same
Snap ..essentially break..the loom mount from the car
Slide fsb mounts under loom and tighten to 28 ftlbs
Zip ties looms to fsb mount
Install bar
PUSH bar down heavily over the mounts while you tighten bar bolts
Done
There is a lot of play in the mount for the bar bolt. Not pushing down results in random vertical placement. Pushing down left a nice small space between engine cover and bottom of bar which will help avoid rubbing on the top.
It's feels better driving. It feels like it takes bumps with less bounce.. But who know. I also think my car rides smoother at night so... It's that sort of effect
Off to ceramic coat the wheels today!
Old Sep 22, 2019 | 04:14 PM
  #7195
PNW_IPL's Avatar
PNW_IPL
Looks good. Should corner a little better.
Old Sep 22, 2019 | 06:14 PM
  #7196
jaydee23's Avatar
jaydee23
Ceramic spray calipers and wheels
Planned on doing all 4 wheels and calipers of course
As the day progressed I thought doing a comparison on the non treated rears was a good idea
Scrubbed down calipers and wheels and applied the mothers cmx. Everything finished very smooth slick and shiny. We will see how it holds up.
I had other responsibilities to tend to so decided against doing the rear wheels and calipers today.
Old Sep 22, 2019 | 06:26 PM
  #7197
PNW_IPL's Avatar
PNW_IPL
Paint perfection correction
Old Sep 22, 2019 | 11:04 PM
  #7198
cmckenzie15's Avatar
cmckenzie15
Installed front and rear spc camber kit with toe bolts. Alignment tomorrow morning.
Old Sep 23, 2019 | 01:02 PM
  #7199
2GoRNot2G's Avatar
2GoRNot2G
Calipers and wheels turned out great. Curious to hear an update in a few weeks to see how they are repelling the brake dust.
Oh, and don't forget to clean and blacken your fender liners while you're in there. People always seem to forget about those when detailing their cars.
Old Sep 23, 2019 | 02:15 PM
  #7200
cmckenzie15
Drove to the alignment shop this morning and boy was it scary. Wheel was turned 90 degrees to the left to go straight and my traction control light was on the whole time. Before I installed the SPC kit my car was tracking to the left so I had to have the wheel slightly turned to the right to have it track straight. I just picked the car up and everything is basically dead on with the alignment but the car still tracks to the left. Is this still an alignment issue or could it be my tread wear. I went in for service at the dealership and they gave me this printout of my tires. Also the rear end seems completely unpredictable, any small bump or angle in the road it catches and wants to shoot out that way.
Alignment before SPC Kit
Alignment Today, top was driving to shop bottom is after alignment with SPC KIT
Tread wear from Saturday 9/21
