Old Mar 31, 2018 | 04:04 PM
  #4801
Vossens and summer tires are going on the car today. It's kind of an involved process, swapping wheels, because I only run these 15mm spacers in the winter, and have to remove those as well. But I've been doing this for enough years now that it's pretty routine. That said, it's far more exhausting as I get older. Particularly moving wheels from the basement up to the garage and back... and jacking up one corner of the car at a time as safely as possible... etc.
It's 50°F today. Probably not going to break 40°F for the next week or two, so I still won't be driving it much. But I've got an inspection due, and I still have to get my rear suspension noise resolved. I drove the car yesterday, and after about 10 minutes, that noise made me want to scream.
Anyway, half the car done, I'm taking a break and clearing my head (so to speak)
Sure am looking forward to seeing that TPMS light go away after the correct sensors are back on the car.
Old Mar 31, 2018 | 04:58 PM
  #4802
llebcire's Avatar
llebcire
Sure it will look great!
Question out of curiosity: does the TPMS light impact VDC? When I was looking for wheels for my Accord there were discussions that if the TPMS light was on due to an error, then the traction and stability wouldn't work right. Didn't know if that was universal safety thing or a Honda thing.
-Eric
Old Mar 31, 2018 | 05:24 PM
  #4803
Not that I know of. My TPMS light is lit all winter long, for the last four winters, and I never noticed any issues with TC.
Old Mar 31, 2018 | 08:43 PM
  #4804
turbo_dreams's Avatar
turbo_dreams
Installed my HPS post-MAF tubes that I got for a steal on Amazon's warehouse deals. They required some extensive trimming and I wasn't impressed with the fit at all. If they hadn't been so cheap, I would have returned them. Oh well, they're in now.
Old Mar 31, 2018 | 08:57 PM
  #4805
IAG37's Avatar
IAG37
Honestly, I wasn't happy with the fit on mine either. Had to do some trimming as well and it was still a pain to get on.
Old Mar 31, 2018 | 10:42 PM
  #4806
iCrap's Avatar
iCrap
-Eric
This is only a Honda / Acura thing. And its not that it won't work right, it just wont let you disable it if the TMPS light is on (the button wont work)
I hate TPMS, especially in the G. It dosen't even work when your tires are low (20ish PSI) and you have to buy stupid overpriced sensors to make the light go away. I like the way Audi does it.... No sensors and it uses the ABS / wheel speed sensors to figure out if a tire is low.
Old Apr 1, 2018 | 12:11 PM
  #4807
Speedylifsavr's Avatar
Speedylifsavr
Couldn't pass up the gorgeous weather today to finally wash my car. Also cleaned up my father's headlights and installed LEDs so he can see again at night.
car looks great ! great choice on the wheels.
Any tips to installing that spoiler. I purchased the same one and did a test fit. seemed like it needed a little coaching to get the curve with the trunk. Did you use a heat gun or anything?
Old Apr 1, 2018 | 12:29 PM
  #4808
iCrap's Avatar
iCrap
Peel the tape off while pushing it against the trunk. it does bend a tiny bit and when you push on it it will fit the curve of the trunk better.
Old Apr 1, 2018 | 12:46 PM
  #4809
projectpanda13's Avatar
projectpanda13
My long distance commute and alignment killed my tires. Going to have to temporarily run my spare wheels up front and move the current front wheels to the back.
I also went ahead and installed my SPL rear camber and rear end links. I haven’t had enough time to finish installing the front upper control arms. Maybe I’ll finish today.
latez
Old Apr 1, 2018 | 04:21 PM
  #4810
slartibartfast's Avatar
slartibartfast
Just as fear is the mind killer, toe-in is the tire killer. Unless you're lowered, you don't need the front upper control arms. Unless you just want more negative camber, like me.
Old Apr 1, 2018 | 06:50 PM
  #4811
projectpanda13
I’m currently lowered on H&R springs and just wanted the peace of mind knowing that I can adjust the camber and caster as I need. But I want to run a bit of camber in the front for sure though maybe -1.5 to -2 degrees.
I was struggling to remove the last nuts on each side.
latez
Old Apr 1, 2018 | 06:52 PM
  #4812
slartibartfast
Adjustable front arms was my first mod so I could run -2 degrees camber.
Old Apr 2, 2018 | 09:27 AM
  #4813
Clynt405's Avatar
Clynt405
Start button
Originally Posted by Calidoso
Hello everyone,
Been on this page for about 2 weeks or so now. I used to own an Infiniti M35 and went to the NICO Forum. One of the threads that I enjoyed to read but not one I find here is a "What you do to you G today?". Now I put it here because I myself own a Sedan but I definitely want to see what everyone does to their models. My idea is just a way for everyone to see how much love their vehicles are getting on a daily basis and continue to push ideas to other new members like myself. Let's see if others will like it too.
*** IF YOU HAVE A COUPE, HERE'S YOUR THREAD~
https://www.myg37.com/forums/newthre...ewthread&f=239
With that being said, I will start.
Just installed my Custom LED Red GTR Button. Made be another member who was phenomenal during the process. Grojas112 thanks.
Stupid iPhone does show how nice the colors look. Went with Red, Yellow and Green. Engine in white and Start/Stop in blue
so what happens with keys and normal ignition?
Old Apr 2, 2018 | 09:30 AM
  #4814
Clynt405's Avatar
Clynt405
latez
oh no! The wrath of the vise-grip.
Next time spray PB blaster, heat, and applying blunt trauma to the nut via a socket to protect the 6 pt nut.
Old Apr 2, 2018 | 10:59 AM
  #4815
projectpanda13
The previous owner had partially rounded the nut off and didn't leave much for the socket to grab. I heated the driver side up to get it off. I am sad at how scratched up the shock tower is. Would have a 6 pt socket impact work? I wonder if that could have saved my time and effort?
Latez
