Old Jan 11, 2018 | 07:12 PM
  #4201
2GoRNot2G's Avatar
2GoRNot2G
  1. Lighter wheels and tires are the easiest.
  2. Next easiest are two-piece rotors.
  3. Next come pulleys.
  4. Now think about that driveshaft.
Of the four, pulleys tend to show the least improvement but are significantly less expensive than the other three options. Lighter wheels, tires, and rotors have the added benefit of improving ride and handling.
Good list there.. and for you manual tranny guys I would add lightweight flywheel at #3.
I've already done 1 and 2 on your list and have never had any luck with light weight pulleys so I would skip that. That leaves me with the driveshaft next I guess.
Old Jan 11, 2018 | 07:15 PM
  #4202
slartibartfast's Avatar
slartibartfast
I would put lightened flywheel at #5 because you have to remove the transmission. That's rather a bit of work and time. Almost as much as shorter rear gear.
Old Jan 11, 2018 | 07:22 PM
  #4203
When sorted by difficulty. Now take your list of five and rank them by effectiveness. Then rank them by NVH. And cost.
Start a new thread. Be that guy.
Old Jan 11, 2018 | 07:44 PM
  #4204
slartibartfast
Cost and difficulty drive choice of most mods by most people.
I accept NVH increase of trans mount because mod was cheap and easy to install.
I added coupe wheels and wider tires. I'd love forged wheels for light weight, but damn, they're expensive. I have to balance tire weight with tire traction. Traction is king for me.
I want to buy 2-piece rotors: they're rather easy to install, but damn, they're expensive.
If I had a 6 mt, I doubt I'd install a lighter flywheel because of the work to pull the trans despite the relatively low cost. A lightened drive shaft is equivalent to 2-piece rotors to me.
Sorry I'm not playing your game. Any list I make has my biases built in. Including the original list I made. However, I look forward to reading your lists using your criteria. I like to see how other people think.
Old Jan 11, 2018 | 07:52 PM
  #4205
I'm thinking similar things, but too much OT for a "what did you do today" thread.
Old Jan 11, 2018 | 08:38 PM
  #4206
Kevin Lesniak's Avatar
Kevin Lesniak
Bruh Idk how to use this site at all so I'm just winging it, does anyone at all know if the g37 coupe bumper fits on the sedan? I have a 2013 sedan
Old Jan 11, 2018 | 09:22 PM
  #4207
Hi Kevin, welcome to the site, unfortunately no body parts swap from sedan to coupe
Old Jan 12, 2018 | 04:14 AM
  #4208
Dan Harris's Avatar
Dan Harris
Installed the Injen SRI.
Old Jan 12, 2018 | 09:02 AM
  #4209
Hi Dan, welcome to the site, same SRIs as I've had for several years now, expect your mpg to go down since you'll get addicted to the growl
Old Jan 12, 2018 | 05:44 PM
  #4210
2GoRNot2G's Avatar
2GoRNot2G
Removing the transmission in our cars is actually quite easy. I've had mine out a couple of times and can do it in about 4 hours. I believe the listed factory time for clutch replacement is 5 hours. Compare that to the clutch in my Porsche which takes me about 12 - 15 hours (and I've done that one 4 times) and it makes our cars seem very easy.
Old Jan 12, 2018 | 06:21 PM
  #4211
hexotic's Avatar
hexotic
DIY Cheapskate/Mod
Make sure you swap those bendystraw plastic pieces to smooth silicone tubes from Z1 or Mishimoto. You will notice a much bigger difference than just having the pod filters. That is actually where a lot of air gets restricted and silenced.
Old Jan 12, 2018 | 07:16 PM
  #4212
Pearl4door's Avatar
Pearl4door
Picked up suspension components from powder coat shop today.
Attached Thumbnails What did you do to your Sedan today?-resized_20180112_101720_8592.jpeg   What did you do to your Sedan today?-resized_20180112_101238_5409.jpeg
Old Jan 13, 2018 | 04:29 PM
  #4213
slartibartfast
New Centric rotors and Hawk 5.0 pads. The original rotors aren't bad at all. A light skim and they're ready for when the Hawks wear out. 48k miles on the original pads, including two track days.
Old Jan 14, 2018 | 01:38 AM
  #4214
Calg37USMC's Avatar
Calg37USMC
I have the same pads but for me they are really noisy, let me know about your experiences after a couple miles
Old Jan 14, 2018 | 08:12 AM
  #4215
I don't get it. You're using new Centric rotors, or you're refinishing your OEM rotors with 48k miles on them... which is it?
Didn't know there was a HPS 5.0 over the standard HPS. What are your thoughts here, same-as but with a higher temp rating?
