Old Jun 28, 2017 | 10:39 PM
  #3226
iCrap's Avatar
iCrap
I did some searching since I figured this has been tried before. Sounds like it's separate from the AC system and is really just a fan
Oh yea, its pretty much just a fan. I found some kits which include the perforated material and the fans. You remove the leather seat cover and install the pad. From there, I figure it's probably not too hard to somehow duct the AC from the rear seats. I dunno.
Old Jun 29, 2017 | 09:20 AM
  #3227
hexotic's Avatar
hexotic
DIY Cheapskate/Mod
Just keep in mind that you'll most likely also need to get the hoses/adapters and/or baffles needed to connect the seats to your cooling vent lines under the front seats. Also not sure where the switch is for the cooled seats in the 'vert model, but you may want to check and see if the wiring is already there for the extra switch.
The vert switch is in the same place as the heated seats.
Old Jun 29, 2017 | 09:38 AM
  #3228
Entcee's Avatar
Entcee
Originally Posted by JustROLLIN
Is that street legal? Looks good, but I thought there had to be amber in the turn signals? I honestly cannot recall any longer though.
White turn signals are legal, at least in NC. White or amber in the front, red or amber in the rear.
Here is another state's (CT) laws: Link
What is actually illegal in CT (and probably many more states) is the little light on top being white since that can be seen from the side, it has to be amber.
Originally Posted by Nico-derm
There will be amber in the turn signal, it just doesn't work as a parking light anymore
You are right, my they do not work as a park light anymore, but they do light up white and not amber. Was thinking about changing the turn signals to amber, but we'll see.
Old Jun 29, 2017 | 02:47 PM
  #3229
2GoRNot2G's Avatar
2GoRNot2G
One work for you.. Switchbacks. Or is that actually supposed to be two words? LOL
Old Jun 29, 2017 | 02:54 PM
  #3230
Nico-derm's Avatar
Nico-derm
Hmmm... I would have thought you kept Amber for turn seeing as they are not permanently on as parking light
Old Jun 29, 2017 | 04:51 PM
  #3231
Entcee's Avatar
Entcee
I actually prefer the parking light delete, but if I wanted park lights (and amber blinkers) I would def use switchbacks.
I might switch them to amber, I prefer white blinkers, but amber is more visible, especially being that close to the headlight... I will be deciding this weekend.
Old Jun 30, 2017 | 08:46 AM
  #3232
4doorfury's Avatar
4doorfury
Ordered whiteline bushings. Will be rocking the 3.69 diff in the next week or so. Then tuning time
Old Jun 30, 2017 | 08:55 AM
  #3233
Swapping the diff, or just the gear & pinion? And why the 3.692 instead of the 3.916 gears from the Vert?
I ask because my old 3.692 gear & pinion are collecting dust in the attic, and I've been wondering if I should try and sell them to a RWD/AT owner who wants to upgrade.
Old Jun 30, 2017 | 09:14 AM
  #3234
4doorfury's Avatar
4doorfury
Diff. I sourced one from a 2008 5spd a long time ago, just been collecting dust until now
Old Jun 30, 2017 | 09:30 AM
  #3235
Still a 10% increase in the final drive ratio. And assuming it bolts directly, it's a heck of a lot easier to swap the diff than the gears.
I have no idea how that will affect the drive in a MT car, but I'm sure the change will be significant. G'luck!
Old Jun 30, 2017 | 09:33 AM
  #3236
4doorfury's Avatar
4doorfury
It's a direct drop in. Even the abs tooth count is the same. I did my homework lol
Edit: slight lie, the axles use bolts and nuts rather than just bolts. I have to drill out the thread on the current axles. I sourced the OEM nuts and bolts though for cheap. Should be easy enough. Worst part is the bushing
Old Jun 30, 2017 | 10:47 AM
  #3237
xpcgamer's Avatar
xpcgamer
I want to install the Sport rear diff in my 7AT at one point. May to stick with the 7AT Sport diff since I dont want to have to swap flanges. On a side note had my bumper off to install the Takeda intake and now my car's horn sounds like it has a stuffy nose. Polarity is correct on the top horn seems like it did not like being removed and reinstalled. Maybe its time for a Hella horn upgrade :0).
Old Jun 30, 2017 | 11:06 AM
  #3238
The RWD/AT Sport rear diff will net you LSD that you don't currently have, but the gear ratio will remain the same. If however I'm reading you want to upgrade your gear ratio from 3.357 to 3.692...
...then by all means, make me an offer.
Old Jun 30, 2017 | 11:20 AM
  #3239
bridgengineer's Avatar
bridgengineer
New wheels, tires, rotors, pads and painted calipers....Feels like a different car coming from the stock 17's!
Attached Thumbnails What did you do to your Sedan today?-photo40.jpg   What did you do to your Sedan today?-photo383.jpg
Old Jun 30, 2017 | 11:25 AM
  #3240
JustROLLIN's Avatar
JustROLLIN
Are those 19s or 20s? I am assuming stock ride height? Just trying to get an idea of what different size wheels look like at stock ride height since I am in MN and would rather not lower my car down.
