Old Feb 20, 2017 | 02:52 PM
  #2191
the93owner's Avatar
the93owner
Finally installed rear toe arms on my sedan. Freedom to adjust the rear camber back into spec at last!
Old Feb 20, 2017 | 03:44 PM
  #2192
2GoRNot2G's Avatar
2GoRNot2G
Originally Posted by h3spencer11
Installed the rear Hotchkis sway bar on my g37x sedan, purchased from user jfisher, great dude and good sale as I know he is parting out.
as for my initial impression, to echo what everyone here seems to say, if you have an "x" just do it, without question the best mod i've done to this car, the in-corner handling is night and day. the endless body roll and understeer is just gone. Perhaps a placebo but I swear the car feels more on center as well, flipped off the TC and the controlled oversteer is fantastic.
No pics as I did in a time constraint but I figure most here have seen the bars by this point
EDIT: On the front sway bar, which setting is the firmest? innermost or outer hole? thanks
Originally Posted by Nico-derm
Inner most hole would be the firmest... ie. the hole closest to the actual sway bar.
Originally Posted by VIVID
Same with the rear?
Sean
As Nico mentioned, the outermost hole offers the most leverage to twist the bar making it the softest setting. The innermost hole would be the firmest setting. Oddly, my Hotchkiss front sway bar only has one setting, but my rear has three settings. I'm running the rear in the softest (outermost) setting which gives me a bit more lean but WAY more rear traction. Can anyone confirm that the newer Hotchkiss bars have multiple settings for the front bar? My car was the sedan test mule for the Hotchkiss bars, so maybe they've change them since the original prototypes?
Old Feb 20, 2017 | 07:19 PM
  #2193
Daddy Fat Sacs's Avatar
Daddy Fat Sacs
I bought mine brand new about 5 months again and my front bat only had 1 set of hole as well. Rear 3
Old Feb 20, 2017 | 07:23 PM
  #2194
hotdawwgman's Avatar
hotdawwgman
I mounted these up a few weeks ago
  #2195
hotdawwgman
Old Feb 20, 2017 | 08:32 PM
  #2196
93owner, hopefully your tires didn't get too worn w/ that toe being out, how long were you driving it that way? Specs look great now
hotdawg, wow, quite a dramatic setup you've got there, those wheels are tight!
Old Feb 20, 2017 | 08:40 PM
  #2197
the93owner's Avatar
the93owner
My toe was definitely within spec before today, because if I had been rolling with that much toe for the last 18 months, my tires would have been roasted long ago. Camber was around -3 though.
Old Feb 20, 2017 | 08:52 PM
  #2198
Yeah, I wasn't sure what your alignment settings had been prior to that sheet you posted, that was pretty heavy there^^^
Old Feb 20, 2017 | 09:02 PM
  #2199
the93owner's Avatar
the93owner
Yeah I'm not sure why the computer was reading that much toe in the rear, I was in spec for sure. oh well now I can stop worrying about too much camber wear
Old Feb 21, 2017 | 11:16 AM
  #2200
the93owner's Avatar
the93owner
Just got back from the exhaust shop. I had my Vibrant resonators paired up with my Tanabe axleback, and I must say, I should have done this way sooner. Definitely beefs up the Tanabe exhaust without introducing much rasp or drone. Still relatively mellow at the lower RPMs, but when you open it up it's a whole different story. If anyone is still on the fence about this, stop thinking and JUST DO IT! You will not be disappointed!
Old Feb 21, 2017 | 01:45 PM
  #2201
iCrap's Avatar
iCrap
Where did you go / how much did they charge?
Old Feb 21, 2017 | 02:09 PM
  #2202
guy from norcal's Avatar
guy from norcal
I have been preaching this for about 4 years now.
Glad you like it.
Old Feb 21, 2017 | 02:29 PM
  #2203
the93owner's Avatar
the93owner
Tony's Custom Exhaust in Glen Burnie. The labor was $125 and I bought the resonators separately from JM auto sports.
Glad you like it.
Thanks! I'm pretty sure I heard it first here from you!
Old Feb 21, 2017 | 05:29 PM
  #2204
2GoRNot2G's Avatar
2GoRNot2G
Ok. That's what I thought... Rear's adjustable, but front is not. Thanks for confirming, DFS.
Lookin' REALLY good, Mark! Really liking those wheels. They are very different but suit the car perfectly.
Old Feb 21, 2017 | 05:45 PM
  #2205
2GoRNot2G's Avatar
2GoRNot2G
Glad you like it.
I'm curious, are you guys just adding the Vibrant resonators to your OEM mid-pipe or are you having a complete custom mid-pipe made? Reason I ask is because a while back I added a modified Invidia mid-pipe with Invidia resonators to my Tanabe axle back. And although it did sound really good, it still had a bit too much drone for me at highway speeds. Might have been better in a car with 7AT, but in mine with a 5AT I'm running well over 3K RPM's on the highway and that set-up droned a bit too much for my tastes.
