Sedan Chat Thread
Old Aug 28, 2016 | 04:22 PM
  #10951
Originally Posted by Q.Gsxr
Hey Rochester,
found this service bulletin online. Hope it helps
http://www.infinitig37.com/TSB/ITB12-024.pdf
Oh hey, nice find! I need to take my time and read through that.
While on topic of disconnecting the battery... anybody know the technique for resetting the one-touch-up on the windows? I'm an idiot.
Old Aug 28, 2016 | 04:47 PM
  #10952
Q.Gsxr's Avatar
Q.Gsxr
Oh hey, nice find! I need to take my time and read through that. While on topic of disconnecting the battery... anybody know the technique for resetting the one-touch-up on the windows? I'm an idiot.
Yes push window button down and then up and hold the button up for about 5 seconds. That should reset it
Old Aug 28, 2016 | 07:14 PM
  #10953
That did the trick. Thank you!
Old Aug 29, 2016 | 08:56 AM
  #10954
Hey Rochester,
Welp. My VIN is outside the range for the 2011 2WD Sedan, so it doesn't apply. Nice find, though.
From yesterday morning and throughout the day, the ignition behaved totally normal. This was after disconnecting the battery (and resetting the windows and radio.) As soon as it gets weird again, that's when I'm going to crawl into the driver's footwell and study the clutch switch situation.
Old Aug 31, 2016 | 05:34 AM
  #10955
Mik3G37S's Avatar
Mik3G37S
Rochester , good news I finally got my TWM STS from Liam a week or two ago, and waiting for my new shift **** upon arrival today
Can't wait !! Had to wait 3 weeks for the **** to be completed as I requested something Raceseng doesn't currently offer on their website, that is deeper engraving powdercoated in translucent red, which came out really really good!
Old Aug 31, 2016 | 08:45 AM
  #10956
Raceseng is impressing me more and more over the last year, as I troll their website, and more members here do business with them. Good for you, Mike. I believe you still need a boot ring under that ****. You'll see what I mean when it all comes together. (LatheWerks can cut you a ring for a fair price, you know.)
Since Liam's new B&M shifter has its own urethane cup, I see that he sent you the TWM with the OEM cup already pressed into place. That was damn fine and decent of him to do that.
So... you never installed the shifter, waiting on the ****? That's an uncharacteristic display of patience, buddy.
Old Aug 31, 2016 | 04:31 PM
  #10957
Mik3G37S's Avatar
Mik3G37S
I'll see how I like it without the boot ring, I know you've suggested this to me before but it never really bothered me much or actually at all, but I will definitely look into it, yes Liam sent me the TWM with OEM cup pressed in place indeed, since he didn't need it, so that was just a bonus.
Yeah I never installed the shifter knowing after I got it, it'd be a matter of 2-3 more weeks before the shift **** would be done and ready, that is indeed an uncharacteristic display of patience, I think I've learned to manage that a bit better over the past 3 years
Old Aug 31, 2016 | 04:41 PM
  #10958
slartibartfast's Avatar
slartibartfast
Had the Vibra-Technics trans mount installed. Yup, it fits the 7AT. Also treated the car to its first interior detailing since I bought the car in 2011.
Old Sep 1, 2016 | 05:09 PM
  #10959
dmudd's Avatar
dmudd
I hate to do it but I got a fitment question. I won't even act like I understand camber offset etc. I came across a set of clean tsw thruxtons for 475..they are 19x8 in front 19x9.5 in rear. He said he believes the offset is 20. Said they were on a 350z. Would they fit without modifications on an 09 g37x? If so what's thickest tire I could run
Old Sep 1, 2016 | 05:19 PM
  #10960
Nico-derm's Avatar
Nico-derm
https://www.myg37.com/forums/wheels-...fat-tires.html
Old Sep 1, 2016 | 05:20 PM
  #10961
A +20 offset on the G Sedan will look like the Flintstone car.
And a 1.5" stagger is no bueno for the AWD system.
Pass on those wheels, Mr. Mudd.
Old Sep 1, 2016 | 05:24 PM
  #10962
Nico-derm's Avatar
Nico-derm
way better response ^^^
Old Sep 1, 2016 | 05:51 PM
  #10963
dmudd's Avatar
dmudd
Thanks for the straight answer.
Old Sep 1, 2016 | 06:07 PM
  #10964
2GoRNot2G's Avatar
2GoRNot2G
I wouldn't be so hasty. If they're really a great deal then you may want to consider them. The +20mm offset if fine for our cars considering that the wheels are fairly narrow. A +20 offset on an 8" wheel is basically equivalent to a ~ +32mm offset on a 9" wheel or +38mm on a 9.5" wide wheel, which is perfectly fine for the front. I'm currently running 20x9.5" up front with a +30mm offset and 255 wide tires without any clearance issues. A +20 offset on the 9.5" for the rear would be a little tighter. That's exactly equivalent to the +32mm on 10.5" wide wheels which I am running in the rear, but you will have to run some negative camber and/or stretch the tires a bit. I was running 265's and 275's in the rear with around 2.2° negative camber. The staggered wheels aren't an issue per say, but as John mentioned running staggered tires on an AWD car can cause issues, so you would either need to run a square tire set-up or make sure to get tires with equal/nearly equal rolling diameters. I've owned a couple of different AWD cars that had staggered set-up's and no issues. It can be done, but you just have to be careful with the tires sizes.
Old Sep 2, 2016 | 01:40 AM
  #10965
sptl99's Avatar
sptl99
I've seen the person on here somewhere but i can't remember who it was. Who has the fastest NA sedan and whats their build thread link.
